My Koyo Rad Install - Nissan Titan Forum
Old 02-02-2013, 02:03 AM   #1 (permalink)
jbowles's Avatar
iTrader Score: 24 reviews
My Koyo Rad Install
Got the Koyo rad and Long TruCool installed tonight. I've never done a radiator install before, so we took our time and enjoyed some brews along the way.
Cracked rad came out well with no issues. Koyo dropped in perfectly. TruCool went in without a hitch. Replaced all the hoses and clamps, no prob. Then we thought we tightened everything down. Warmed her up to temp and checked for any leaks. None. Took it for a spin around the block; stopped and checked for leaks. None. So, after running it for about 30 minutes I opened it from 0-60. Came back home and parked it. Popped the hood to check everything out again and heard something. I was leaking tranny fluid. One of the hoses popped off and blew fluid all over the underside rear section. Retightened all the hose clamps and had to add a quart of fluid after learning how to check the AT fluid. Hopefully everything is good now, I'm tired!
I'll add some pics tomorrow and some more info. It's a good thing I didn't commit to a header install in 2 hours.
Sent from AutoGuide.com App
jbowles is online now   Reply With Quote
The Following 9 Users Say Thank You to jbowles For This Useful Post:
BBtruck (02-02-2013), beachside321 (02-10-2013), Dallas_Titan (02-03-2013), EDDIE FONZARELI (02-03-2013), gweasel77 (02-02-2013), MilenkoGT (02-03-2013), nightowl (02-02-2013), retnavycwo (02-10-2013), tsunamilogan05 (02-02-2013)
Advertisement
Old 02-02-2013, 06:25 AM   #2 (permalink)
MilenkoGT's Avatar
iTrader Score: 5 reviews
Send a message via AIM to MilenkoGT
Re: My Koyo Rad Install
Very nice on the install. When I did my SR4588 install I had a leak as well nut it happend on first start up, that trans pumped out almost 3/4 of a quart in like 6 seconds lol. The line that came loose was that feed line coming up the side of the radiator on passenger side behind that foam insulation stuff, it was kind of a pita to get to.
Can't wait to see some pics of that Koyo. I bet its awesome quality for sure.
Oh and if u would snap a pic of the Koyo rad cap lol.
2008.5 Titan SE CC FFV
'Smoke'
Uprev/Danblp Tune**Custom 4in CAI w/ ram air & TB Bypass Mod,**RP-PERF Stg.2 E-FANs**170 T-Stat**DTLT's-No Cats-CAJUN 2.5in B-pipes, Apexi resonators, Flowmaster Y-pipe 2.5in to 3in to (Japan made) APEXi N1**PML Trans Pan**Transgo shift kit**Long SR4588 Trans Cooler**TruTrac w/ 3.36 gears**NFABWORKS Traction Bars**20x10 KMC XD Rockstars**305/50/20 Cooper Zeon LTZ**R1 Concepts Slotted Rotors w/ Fleet Perf. Pads**Legit Acc. HIDs 5000k with LED Reverse Package**Custom Mesh Grill Mod
Coming Soon FT90 Kit w/ LS7 TB! One of the Last!
MilenkoGT is online now   Reply With Quote
The Following 2 Users Say Thank You to MilenkoGT For This Useful Post:
gweasel77 (02-02-2013), jbowles (02-02-2013)
Old 02-02-2013, 07:04 AM   #3 (permalink)
Supporting Vendor
nightowl's Avatar
iTrader Score: 79 reviews
Make sure to go back and retighten those clamps ever so often like at oil changes. I double clamped mine for chits & giggles. You should have 20* cooler tranny temps now. Congrats!
YOUR CRACKED MANIFOLD ONE STOP SHOP
-CUSTOM BPIPES
-JBA HEADERS
-JBA CATBACK
-AXLE VENT KITS
-2.5" CAJUN Y PIPES
-VIBRANT ULTRAQUITE RESONATORS
-CUSTOM TUNING "NO DYNO NEEDED"
http://www.cajunbpipes.com
UPREV INFO-CAJUNTUNING@GMAIL.COM
nightowl is online now   Reply With Quote
The Following 2 Users Say Thank You to nightowl For This Useful Post:
jbowles (02-02-2013), MilenkoGT (02-03-2013)
Old 02-02-2013, 08:29 AM   #4 (permalink)
baseballfanz's Avatar
iTrader Score: 1 reviews
Good thing you caught the loose tranny hose.
Posted from my Titan.
Titan/Armada Part Numbers
Frequently asked fuse locations
305.5 WHP, 370.4 ft/lbs tq
The Following User Says Thank You to baseballfanz For This Useful Post:
Old 02-02-2013, 09:52 AM   #5 (permalink)
jbowles's Avatar
My Koyo Rad Install
Some pics added. There is an Allen screw at the bottom of the rad. I don't know what it's for but it has a tiny leak in it. It's about 1 drop per hour. Lol! Anyway, I'll probably drop some Loctite on it or something. My T is still recovering from all the tranny fluid from underneath, so I wiped it down as best I could. Gonna have to retighten all of the clamps again. It's a shame such a pretty radiator is completely covered up. If you guys want any specific pics, let me know!
Milenko: there was no rad cap included with mine, but the OEM fit perfect and doesn't leak surprisingly.
Edit: here is the Allen screw I'm talking about; it's right next to where the lower hose attaches. I didn't even see it until the rad was already in. Anyone know what it's for?
The Following 3 Users Say Thank You to jbowles For This Useful Post:
BBtruck (02-03-2013), gweasel77 (02-02-2013), MilenkoGT (02-03-2013)
Old 02-02-2013, 03:47 PM   #6 (permalink)
cjoh101's Avatar
iTrader Score: 2 reviews
My Koyo Rad Install
Is it for the drain valve?
2005 Galaxy Black CrewCab 4X4 FlexFuel
Performance Mods:
OBX LT headers(New Version), Walker bpipes, Magnaflow 14" muffler, Magnaflow ypipe, Air box mod
Suspension/Brake Mods:
08+ Big Brake Upgrade with BrakeMotive Rotors, PowerStop Pads, and Stainless Steel Braided brakelines, Bilstein 5100's on middle setting, 1.5" spacer, PRG end links
cjoh101 is offline   Reply With Quote
The Following User Says Thank You to cjoh101 For This Useful Post:
Old 02-02-2013, 04:39 PM   #7 (permalink)
jbowles's Avatar
My Koyo Rad Install
I don't think so, the drain port is on the opposite side of the rad.
Old 02-02-2013, 05:22 PM   #8 (permalink)
gweasel77's Avatar
iTrader Score: 6 reviews
That KOYO is a work of art!
I believe that's for a coolant temp sensor!
2005 NISSAN TITAN SE KC
IRC VK56 TEAM MEMBER
performance:
UP/REV CUSTOM TUNED
4" Airaid MXP CAI w/ GW77 4" Ram-Air Mod / TB Bypass Mod / FT90 Kit / LS7 TB / '08 IM / CSF Race Rad. / Trans. Cooler / Nismo LT Header's / Berk Tech SS B-Pipes w/ Magnaflow Hi-Flows / 2.25"-3" Flowmaster Y-Pipe / Borla XR-1 Muffler / "Gatorback" Serp Belt / Relentless RPM Catch Can / Detriot TruTrac / ActiveTuning Grounding Kit / Burnout Mod / LP Mod / MT ET Street P295/45R/17 DR's / Mobil1 EP 5W30 / 75W140
exterior/suspension:
Ruff Racing R286 22"x9.5" Chromes w/ 305/45/22 Yokohama Parada Spec-X's / Slotted "cryo" Frozen Rotors / Hawk LTS Brake Pads / High Cap. Diff. Cover / Helwig RSB / Bilstein HD's / SpringTech 2" Drop Shackles / PRG camber bolts / Armada Air Dam / SolarGard Tint / Tow Hooks / Debadged
NEW PB: 1/4- 13.57 @ 98.51MPH w/ my BEST 60' EVER 1.88
New PB Dragtimes Page:http://www.dragtimes.com/Nissan-Tita...lip-25254.html
Need to install: PRG Street Traction Bars!!!
Next Mods: CAJUN PIPES!!!!
gweasel77 is offline   Reply With Quote
The Following 4 Users Say Thank You to gweasel77 For This Useful Post:
BBtruck (02-03-2013), cjoh101 (02-04-2013), jbowles (02-02-2013), MilenkoGT (02-03-2013)
Old 02-02-2013, 06:21 PM   #9 (permalink)
jbowles's Avatar
My Koyo Rad Install
Thanks buddy! I tell ya', I'd take another header install over doing this. I do not like messing with this stuff.
The Following User Says Thank You to jbowles For This Useful Post:
vilim12 (02-02-2013)
Old 02-03-2013, 12:48 AM   #10 (permalink)
MilenkoGT's Avatar
Very nice, thanks for the info on the cap lol. All that money and Koyo can't add a cap to the top lol.
That koyo is dayum near almost to nice to install lol.
'Smoke'
The Following User Says Thank You to MilenkoGT For This Useful Post:
jbowles (02-03-2013)
Old 02-03-2013, 06:13 AM   #11 (permalink)
jbowles's Avatar
My Koyo Rad Install
That's kinda what I thought about the cap, maybe it was hiding it the box. I'll have to do a thorough search.
The worst part about the Koyo is that it's hidden.
Old 02-03-2013, 06:37 AM   #12 (permalink)
BBtruck's Avatar
Looking good Jbowles. Temp sensor plug is a cool added touch for sure. Notice the fan cowl cover fit a little ill. Mine fitted the same. After seeing pics of Gweasel naked rad, I went naked too.
Look how sexy she looks, plus you save a little over a lbs. at the nose..
L
My Galaxy '05 XE 4x1 modest mods:
Bilsteins HD, PRG adj. shackles, PRG swaybar endlinks, Stillen front and rear swaybar, RAS, Stillen Rad, BD PP, S&B CAI, DT LT's, Berk MP, SS Zoomers catback, Mag-Hytec rear diff cover, CF dash kit.
"The guy who invented the first wheel was an idiot, the guy who invented the other three, he was a genius."
BBtruck is online now   Reply With Quote
The Following User Says Thank You to BBtruck For This Useful Post:
Old 02-03-2013, 06:45 AM   #13 (permalink)
jbowles's Avatar
My Koyo Rad Install
^^^ Sweet! I almost left it off, but decided against it for safety reasons. I'll just have to remember how beautiful she is on the "inside". Lmao!
Old 02-03-2013, 02:11 PM   #14 (permalink)
MilenkoGT's Avatar
oh yeah, i forgot to mention to you as well about removing the OEM fan shroud lol. I would leave it off. Do you have any more pictures of how the OEM shroud fits the Koyo, seems like there is quite a bit of space.
Plus i dunno if the Airaid MXP you have is touching the shroud now, it would be peace of mind to pull shroud off and keep it from rubbing.
Just remember without the shroud, don't go sticking fingers down in there lol.
'Smoke'
Old 02-03-2013, 02:28 PM   #15 (permalink)
jbowles's Avatar
My Koyo Rad Install
The shroud bolted up well, although there is a small gap. Still have about an inch between shroud and intake, so I'm good with it.
Advertisement
Amp kit install! Help! Okc_titan Titan General Discussion 6 12-18-2012 06:06 PM
aem intake install and about to install banks monster 94ttz32 Titan Performance Modifications 0 12-03-2011 10:11 AM
Brand New Koyo Radiator bills1974 Buy/Sell 32 03-31-2011 07:31 PM
Back Rack Install complete (with install progress pics) truckin88 Titan Parts & Accessories 13 01-22-2011 09:33 AM
Koyo Radiator and Exhaust for Sale float_test Buy/Sell 6 08-16-2009 11:20 AM
SEO by vBSEO 3.3.2
