Per the new signature times, the Morosos seemed to have worked out pretty good. Part of it is due to the temps being about 10 degrees lower so factor that in but it dropped about 0.2 secs and gained about a mph. 60' times were consistently 2.20s, which is better and with 3 passes on motor it never ran worse than a 14.98.
For 1/8 mile reference it was a 9.624@73.77 on motor and 9.268@76.97 on the small nitrous shot.
Next mod is on the way already. I picked up a set of the Chevy steel rims (16") for the rear to try some shorter tires. Hopefully that will help pull this heavy pig out of the hole a little better but I also hope that traction doesn't become an issue, either. Until next time...
