Originally Posted by bestatchess
You can find this with the SEARCH button.
Or I can tell him my experience.
I have an SE that did not come with Fog Lights. I bought the Fog Light kit and installed it myself. The kit is available on either Courtesy Parts.com or NissanParts247.com. Everything is pre-wired, so all you need to do is remove the hole plugs, pop in the lights, secure them each with one screw, then install the turn signal switch that has the fog light switch on it. The instructions are self explanatory, and I had fun installing it; very simple.
Just FYI, the turn signal switch that came with mine also had the Auto light switch, but since I don't have the sensor, that function does not work.
I recommend the fog lights, since it looks better and provides better lighting at night.
