Well I managed to best my old time on the 50hp jets. And tried some 100hp jets. I did things a little differently this time around. I was running 93 octane, about 5 gallons or so and also added a gallon of 104 octane unleaded. I did this to help with the 100hp jets not causing detonation or at least curb it. Consequently I only ran a 14.95 best on motor. But the 50 hp jets did indeed wake up a bit.
What was most interesting is the 100hp jets I put in. It ran just slightly leaner than the 50hp jets but was still reading 'rich' on my a/f gauge all the way through the runs. I didn't notice any pinging or anything like that. What I did feel was that the truck definitely pulled harder at the lower rpms but at the upper rpms near the shift points it felt no different than the 50hp jets. In fact, the ETs were about the same as the 50 hp jets but it was running about 1.5mph faster through the traps (best 14.01@98.3). I ran them about 5 times. The first two were progressive runs, meaning I hit it in second gear, let off for the gear change, and then hit it again. Second run was second gear and letting it shift into 3rd with the NOS going, and then the last 3 were all-out, hit it at 3500 rpm in first gear and let the truck shift through it. In no run did the tranny slip, the tires break loose, or anything else out of the ordinary.
If anyone remembers, I also got the same result with the 75hp jets I tried before but thought that it was too rich (fuel). Looking at those results and tonight, I think 50hp jets are about all my truck will take successfully. As far as why that is, I can think of a few things:
1) It is detonating but the computer (knock sensors) are pulling out the timing to keep it from damaging anything.
2) The stock fuel system is getting maxed out at the upper RPM range. Even though I have a gauge, let's face it - it ain't that accurate to tell me what's exactly going on.
3) The stock ignition can't burn everything well enough.
4) There is still some restriction in the exhaust that the spent gases simply cannot overcome to get out and make more power.
Insert your reasons here.
I've ordered some other jets that will be here soon and they include a 60hp jet setting so I'll try that next. I may also try a 40 hp set to see what happens as well. In any event, I may be at the point that I have to add a separate fuel system to deal with the nitrous. Not a big deal, just more $$.
Track conditions were pretty good - 59 degF with some humidity, but there was about a 10 mph cross/head wind that wasn't helping. I did install a bottle heater yesterday to deal with the lower temps.
And if you're wondering, yes - I was getting ready to unbolt my bumpers to get that 13.9 run in, but I'll save it and just settle for when I get my wheels in and different rubber for track use. Timeslip for best motor and 50hp shot for your viewing pleasure.
Until next time...
