Old 11-17-2004, 12:12 PM   #1 (permalink)
buster's Avatar
Goodyear Wrangler SR-A to BF Goodrich All Terrain?
Not sure if this question has been posted:
I have a 2004 Crew Cab SE with Big Tow Package. Wheels are 18" and I don't want to replace them.
Can I replace the stock Goodyear Wrangler SR-A (265/70R/18) with BF Goodrich All Terrain (285/65R/18) ......... without having to lift the truck?
If not, what would be the minimum I would have to lift it?
Thanks for the info.
buster is offline   Reply With Quote
Old 11-17-2004, 12:32 PM   #2 (permalink)
GETSOMZ28's Avatar
Go ahead, since they are the same height. Both are 32.6" tires. They should fit exactly the same as the stockers.
Scott
Old 11-17-2004, 01:00 PM   #3 (permalink)
buster's Avatar
"should fit" ?
What about the width?
I spoke with a local tire dealer and he said it may or may not work. He said he wouldn't know for sure until the BFG's were put on. Seems to me a tire dealer should be able to tell me for sure. I'd rather have a 100% confrimation before I order the BFG's.
Has anyone done this?
Old 11-17-2004, 02:10 PM   #4 (permalink)
11.22 vs 10.43 section width difference, both are 32.6 inches tall. With 3/4 of an inch difference in width there would not be a problem. I will be installing the same tires when mine wear out. I want the higher load range and thicker side walls.
95steel is offline   Reply With Quote
Old 11-17-2004, 03:41 PM   #5 (permalink)
guys i put 35" by 12.50 wide tires on my titan with only a 2" lift. they rub just a smidge in a full turn so i would say the 11.22 inch tires would work
neworleansmike is offline   Reply With Quote
Old 11-17-2004, 03:42 PM   #6 (permalink)
Wake County Titan's Avatar
How are these tires the same height? Does the 70R and the 65R indicate/measure the tire profile? A 70 would have a larger profile than a 65 thus increasing the overall height of the tire...correct? I'm not a tire expert, but I thought the first number indicates the tire width, the second number the tire profile, and the third number the size rim. I do agree to get an expert opinion before dropping $$ on a new set. Another thing I just thought of...Won't changing the profile of a tire effect the speedo accuracy? These are all questions I would ask a tire expert. Please reply back to this thread as I think this would be a cool tire to switch to when the time comes to replace. Thanks.
2004 Nissan Titan LE - KC, 4x4, Smoke, Big Tow
Mods:
Flowmaster 70 Dual In/Out Exhaust w/X-Pipe, 3.5" Straight Rolled Tips
ARE LSII Bed Cover
4x4 Off Road Decals
JVC KD-G830 Receiver w/USB port
Rockford Fosgate Punch Stage 3 10" sub & P3002 amp
Polk db6500 & db650 speakers & Lightning Audio Bolt 300.4 amp
Wake County Titan is offline   Reply With Quote
Old 11-17-2004, 05:30 PM   #7 (permalink)
70% of a 265mm width vs 65% of a 285mm wide tire is the same. (in height) the 285 is a little wider 3/4"......
04 Radiant Silver SE 4X4 Crew
Popular W/Capt's
Big Tow, Banks
03 Maxima 6 speed...traded for:
06 BMW 325 6 speed manual, sport pkg and xenons.
KL99SEA is offline   Reply With Quote
Old 11-17-2004, 05:32 PM   #8 (permalink)
buster's Avatar
3/4" wider overall difference - 3/8" on each side so there will be no rubbing at all?
Any reason why switching to BFG's would void warranties? Or cause unsafe conditions?
PS:
neworleansmike
please post a picture.
Old 11-17-2004, 08:24 PM   #9 (permalink)
I have pics of my truck posted under the suspension category...."just finished the lift with 35" tires" thread
