I had the same problem w/my 22's and I found that they took so much weight that I would have some fall off fairly easy, and it would throw off the balance. I bet if you go look at the wheels you will see a clean spot on the inside of the wheel where a couple of the stick on weights have come off. Make sure they use de-greaser before they re-balance the wheels.
2004 Armada LE every option in White.
-Vogue 22" Toyo 305 45's(summer)
-Vogue 20" Toyo A/T 315 55's(winter)
-Sherwood Real brushed alum. interior kit
-Denali type grill inserts
-Sirrius plug and play
NOW INSTALLED
-QX 56 fender flares
-K&N intake
-Painted flares, roof rack, and running boards to match body color.
STILL TO COME
-suede inserts for seats and door pannels.
-Stainless taillight covers
-Some sort of custom exhaust w/Magnaflow muffler
