Old 11-27-2004, 12:18 PM   #1 (permalink)
Rear leaf springs
I want to lower the rear of my 4X4 about 2 inches. I just wonder if I could install the 4X2 leafs in the rear of the 4X4. Anyone know what the rear ride height is on the 4X2 as compared to the 4X2.???
Herbpov is offline   Reply With Quote
Old 11-27-2004, 02:50 PM   #2 (permalink)
Sammy Sandbag's Avatar
I believe the springs are the same, I don't see why they wouldn't be. My 2wd sits the same height as 4wd.
-Counsel Yourself
Old 11-27-2004, 03:20 PM   #3 (permalink)
I think the specs say the 4wd OR is about .8 of an inch higher than 2WD, although maybe that is just from different tires. I don't know if OR has different rear springs or not.
Old 11-27-2004, 05:53 PM   #4 (permalink)
Phedge's Avatar
Send a message via AIM to Phedge
It says on nissan's site Overall height (4x2/4x4) 75.0/76.6. Although I don't think that the leaf springs are differnt I think that it is more of front highth change and rear. I put the prerunner lift in the front of mine 4x2 and it is taller than a std 4x4.
Titan SE KC w Pop. pack Bench, Radiant Silver.
30% tint front windows, 40s Flowmaster, K&N Drop in, Spray in liner, Custom Stereo (2x 10" MTX in custom box under rear seat, all new door spks, 600w amp, and 5ch EQ). Prerunner 2.5" lift. More to come when I get more $ to spend
Phedge is offline   Reply With Quote
Old 11-28-2004, 08:45 AM   #5 (permalink)
Thanks for the info. Looks like I'll maybe get some made at the local spring shop.
Old 11-28-2004, 08:55 AM   #6 (permalink)
honeykeeper's Avatar
Send a message via Yahoo to honeykeeper
I believe Jet Tech spring helpers bring you down about 3/4"....and a shell cap another 3/4"....and some stuff in the bed..1/2"= 2" with stock springs and better ride.
honeykeeper is offline   Reply With Quote
Old 12-03-2004, 06:09 PM   #7 (permalink)
Just Had Third Leaf From Top Removed It Droped The Rear 3inches Also Handles Much Better. I Have A Crew Cab 4x4 Le Off Road
ktmstarr is offline   Reply With Quote
Old 12-03-2004, 06:51 PM   #8 (permalink)
Whats that do to the shocks??????? Any changes needed there too??"??
Old 12-04-2004, 11:09 PM   #9 (permalink)
Unless Im Wrong We Didnt Change The Overall Range Of Suspension We Just Lowered Where The Axel Sits In The Range.
Old 12-05-2004, 05:00 AM   #10 (permalink)
gr8titan's Avatar
ktmstarr, If you don't mind how difficult is the removal of the 3rd leaf? Steps for the removal? Thanks. PEACE
Check out the toys in my garage
Appearance Mods: chrome tailgate handle & tailight sorround, Westin T-304 SS Bull Bar, T-304 SS hitch/ball
raised racks, bed extender, nerf bars, Armada roof rack,
Tires/Wheels, Susp/Brake Mods: 305/50R-20 Nittos on MB Express 20x9, Hellwig Traction Springs,
Cross drilled & slotted 14 inch STILLEN big brake kit, red powder coated dual piston calipers
Rear Differential Mod: '05 OEM aluminum rear diff cover with Nissan Synthetic gear oil
Intake/Exhaust Mod: Hybrid Volant tube with heat shield and Custom RAM air box via front grille
2.5" T-304 SS Ractive X-pipe True Dual Rear-cat delete with custom T-304 bullet reso sections
Bragging Rights: Dyno: 293.61HP & 347.3ft-lbs/ New ET:14.800@92.62 0-60ft:2.075 R/T .081
gr8titan is offline   Reply With Quote
