RB - thanks. Thanks a lot for popping my balloon and stealing my candy! haha. So my numbers aren't that impressive. Although, I did beat out all others that day by a wide margin.
04 Titan 4x2 SE KC, Smoke, Magnaflow Single Exhaust, 05 Diff Cover, Stillen VKPro, AEM Brute Force w/DRYFLOW, Custom Painted Engine Cover , Sylvania Silverstars, Rhino Bedliner, Nissan Bug Smacker, XM Roady2 and iPod (AUX), Sony xplod, 2 x 10" JL 0, and a locking gas cap
Yeah...yours are not SAE corrected... I'll pm you later with the STD vs. SAE on my runs.
Cal Titan ....GOOD NUMBERS!
Thanks. The shop I went to said they had dyno numbers of high 250s RWHP and Low 300s RWTQ for a stock Titan. So I feel fairly satisfied with my dyno numbers running only a few mods to intake and exhaust. I would suspect that decypher44's dyno numbers would be lowered by about 7 to 8 HP and 9 to 10 TQ using the SAE correction. Still very good dyno results though.
__________________ 2004 Titan SE KC 2WD Flowmaster 70 Series Muffler, Magnaflow Resonators, AEM Dryflow Intake, Airaid TBS, Uprev Osiris Flash, ECO-3, Big Tow Package, ActiveTuning Grounding Kit, Crown Performance SS/Kevlar Brake Lines, PRG Leveling Kit & Rear Blocks, Nitto Terra Grappler 285-60-18 Tires, Truxedo Lo Pro Tonneau
This was my first time going to the track. What a freakin' blast man!
I ran my beast 4 times. The 1st (15.41) and 3rd (15.59)(3/4 throttle launches) were the best times so thats the slips I'm posting. The 2nd run was my best reaction time.... however I spun the hell out of my tire (WOT launch) and ended up with a 15.8. 4th was 16.01 and figured I was pretty heat soaked by then so I called it a day... plus the tornado sirens started sounding off.
Conditions: 69 degrees and High humidity (tornadic(sp?) activity all around the KC area).
Ran fully dressed.
Stock steelies (245/75/17).
Tailgate and spare on.
Mirrors folded in.
Front tires at 35 psi
Rear tires at 30 psi (didnt want to hear the sensor alarm go off... i hate that).
Talk about a ton of rubber ending up on my tail pipe... jeez!
I'm putting my new wheels and tires on this week so I'll go again in a few weeks. Also, if I take the gate and spare off I just might squeeze into the 14 sec. club. Haha.. wishful thinking.
Anyways... I'm happy with the results.
2007 WRX TR (5 speed)
Stage I
The Titan will be missed.... 2005 XE CC 4x2 Banks Monster Exhaust ~ Volant G3 CAI
Poweraid TBS (w/bypass) ~ Detroit TrueTrac Bilstein Shocks ~ Suspensionmax Shackles
QX56 OEM Wheels Uprev Tuned
- Dynoed her in 3rd gear
- 87 Octane gas
- Conventional Oil 5w-30
- BFG AT 315/70/17
- MagnaFlow performance muffler with MagnaFlow tip, Stock piping
- Volant Gen3 Intake
- PowerAid TBS
- 55.57 Degrees Fahrenhiet
- 23% Humidity
Here is what I got after 4 runs (All 4 runs were within only 2HP and 10ft/lb Torque):
245.15 Max HP, 288.64 Max Torque.
Anyone knows if there is a det detector in the Titan to advance the timing for higher octane fuel? My dyno guy seems to think there is one. He see's spikes in the graph that indicate timing is being retarded (someting in the lines of those words, don't quote me).
I might do a test with syn oil and 91 octane in the summer to see how much higher octane and syn improves the results.
My dyno guy also believes the big BFG AT's are the biggest factor in limiting my numbers, not only are they a lot heavier but the tread on them create a lot drag that really hampers the performance. Says I might gain 20HP by just going to smaller and smoother tire, no way am I doing that though as I need the BFG's for snow and going in the dirt, and going smaller tire is no choice as I love the look of 35" tires on my truck.
Here is the picture, and pictures don't lie
2006 CrewCab LE 4x4 Galaxy Black
Born: 12/05
Purchased: 01/19/06.
OEM: BigTow Pkg, OffRoad Pkg, Side Airbag Pkg, Navigation, DVD, MoonRoof, Utilitrack w/ Bed-Ext.
AfterMarket: S50 Sirius Radio, UnderCover Tonneau, UWS Stainless Step Bars, VolantGen3 Intake, PowerAid TBS, Rancho Lift Kit, Helo Maxx6 17x9" Wheels, BFG All Terrains KO's 315/70/17, MagnaFlow Custom Exhaust, Security System: Sig P229 .40 cal
Save your stocker wheels and tire for the strip and dyno and the winter!!
__________________ Sean
RLTW 05 Galaxy Black SE CC 4x4 w/Big Tow Born on 01/05
Borla Cat Back--------AVS Taillight Blackouts
ARE Z series cap------Wade InChannel Ventvisors
OEM Step Rails PC Black-----Weathertech extreme floor liners
K&N 77series CAI------Tailgate mod
Rubber Bed Mat----Custom Bed rug
PRG 4" Perfomance lift--OR Skidplate PC Black w/holes
KMC Backseats 18x9---Procomp Extreme AT 325 60 18
Sorry guys, I will update the list when I get back from Iraq (sometime in July).
Thank you for your service Get Some Z Man and I mean that in more ways than one. See you soon!!!
Randy IRCCREW CHIEF - International Racing Club VK56
Black Box installed - Dyno 288/339 hp before - 293/352 hp after
Stock Titan Big Tow vs AEM Banks Black Boxed Big Tow Titan
****Why post using STD smoothing ????thats kinda cheating.....pls use corrected numbers (SAE) so we can all relate...look at what i make using STD 5...makes a big diff
Went to the track today in Fayetteville, N.C
This was a Test&Tune Day plenty of time for me to run my beast till she begs for mercy there was only 50-60 cars there and I ran my truck 14 times down the track (mainly to get practice at the christmas lights)
Best times where:
14.8123@93.83
14.9955@92.52
15.05@94.06
The worst time my truck did was a :
15.2385@93.54
Most of the runs where 14.9+ to a 15.1 though
Temps where in 70's with low humidity perfect clear skies, etc..
Mods at the time of racing where as follows:
Stock tires on 18" rim, Tailgate on and in locked position, Removed spare
Flex-A-Lite electric fan conversion
Banks Monster exhaust
Aem Brute Force intake
Throttle Body bypass mod
Eco-3 Fuel system enhancer
Helper spring mod from JetTech of Titan Talk ( $22traction bars)
2 degree timing advance
1/2 tank of Super Unleaded gas
05' Blizzard White 4X2 KC SE
Foose Speedster 6 22's /w Nitto 420-S 305-40R-22, Hoosier Pro 28x11.50x16 Slicks, McGaughy 2/3" drop kit, Jim wolf Technologies Camshafts, IPT 3400 RPM TQ converter, IPT Valvebody, IPT Built Tranny, AEM Bruteforce CAI, NX Express Import WET kit 125 shot, Stillen Longtube headers, Dynatech 2.5" Powercats, JBA Evol catback, Detroit TruTrac LSD, Flex-A-Lite electric fan conversion kit #295, AirRaid Throttle body spacer, TB Coolant By-pass mod, Line-x spray in bedliner, Trenz 3 Piece framed perimeter billet grille /w matching bumper billet insert, Chrome tailgate cover /w handle, MCulloch HID 6K lows and fogs, Altezza Chrome taillights
BEST 1/4 Times
12.929 @ 103.28 NA FMP 7/18/08
12.8591 @ 106.74 (125 shot) 3/2/08 FMP Before IPT tranny
Worst time was like 15.93. Terrible launch... spun the crap out of my tire.
2nd run was better. 15.36
3rd run was best. 15.29 (smoked a Chevy SC/SB)
Things that helped/hurt other than mods listed in my signature are:
front tires - 34psi
rear tires - 28psi (for 3rd run)
1/2 tank of 87 octane
tailgate and spare on
jettech leaf spring helpers
weigh a little over 5100 lbs
Best times where:
14.8123@93.83
14.9955@92.52
15.05@94.06
15.2385@93.54
Very Very Nice....what does your ride do on the dyno? How was traction @ the track?
