Old 01-01-2005, 12:49 PM   #1 (permalink)
titan tow mode
I read in a past post that you cant use the tow mode with a column shifter in manual shift mode for people trying to tow in 4th gear.
but my car will let me use tow mode if i push tow mode button first then switch to manual mode..
just want to make sure im using tow mode right. my tow mode button lights up and i push manual shift and switch to 4th gear for towing
thanks
titan711 is offline   Reply With Quote
Old 01-01-2005, 04:30 PM   #2 (permalink)
Mine is the same.
I have to push tow mode first, then turn off the overdrive.
Jason K.
Titan Power is offline   Reply With Quote
Old 01-01-2005, 04:56 PM   #3 (permalink)
honeykeeper's Avatar
Send a message via Yahoo to honeykeeper
Thumbs up
Same here.....push tow/mode button first and then you can shift to any gear you want including overdrive.
honeykeeper is offline   Reply With Quote
Old 01-01-2005, 07:58 PM   #4 (permalink)
does the tow mode make any difference in times at the track?
1st Titan is offline   Reply With Quote
Old 01-01-2005, 08:20 PM   #5 (permalink)
garo1's Avatar
2004 Nissan Titan King Cab SE 4WD
Born: 5/4/2004
Pearl White Ext - Gray/Blk Int
Popular Pkg. w/Bench
Off-Road Package w/E-Locker
Utility Bed Package
Factory Step Rails
Factory Hood Protector
Drop-In K&N
PRG Leveling Kit
garo1 is offline   Reply With Quote
Old 01-01-2005, 08:32 PM   #6 (permalink)
GETSOMZ28's Avatar
It shouldnt since it only holds shifts longer at partial throttle. At the track, you are going WOT and it will shift at redline no matter the mode.
Scott
Old 01-02-2005, 07:20 PM   #7 (permalink)
I thought it made it shift quicker also,It seems to maybe its in my head
Old 01-02-2005, 08:18 PM   #8 (permalink)
the head's Avatar
None. I have tried this on and off several times as my mods have progressed.
Old 01-02-2005, 08:22 PM   #9 (permalink)
My dealer e-mailed a "how do you like your new truck-any questions" diatribe to which I inquired, " can you manually shift a console equippied gated style shifter?" The response was the sound of crickets. Thanks, dealerguy!!!!!!!!
So, is it the same as a colunm shift equipped manual mode persons?
Galaxie Beach is offline   Reply With Quote
Old 01-02-2005, 08:54 PM   #10 (permalink)
GETSOMZ28's Avatar
According to the service manual, the manual mode in the column shifter works similarly to the gated console shifter. However, I wouldnt manually shift for everyday driving (too much heat and wear on the tranny), just when the situation warrants it per the owners manual (hills, towing, etc).
Scott
Old 01-02-2005, 09:18 PM   #11 (permalink)
Right!! Thanks
