Old 01-09-2005, 02:10 PM   #1 (permalink)
Dual pipes; to the sides, straight back or does it matter?
Is it best to have dual pipes ran straight back or to the sides or is it simply a matter of preference?
Darcity is offline   Reply With Quote
Old 01-09-2005, 02:22 PM   #2 (permalink)
CaliforniaTitan's Avatar
Preference...
Will you be towing with the truck? IF so, you may get some noise bounceback from the front of the trailer with straight pipes..
Chris
Old 01-09-2005, 02:28 PM   #3 (permalink)
I may occassionally tow something, but I don't want to lose any performance.
Old 01-09-2005, 02:30 PM   #4 (permalink)
overdose's Avatar
as soon as I get the chance i'm gonna get the duals to the side (both on the right side). the only reason is because "i" don't like the look of the duals with one on each side.
01/04 SE KC 4X4 Galaxy Black Line-X | Grill |Steprails | Monroe Reflex Shocks | PML DC| AC GK|
overdose is offline   Reply With Quote
Old 01-09-2005, 05:12 PM   #5 (permalink)
SarkaZm's Avatar
Send a message via ICQ to SarkaZm
If your going to but a boat in the water, you probably wouldn't want duals out the back either. But it's mostly preference.
More Pic's Here
SarkaZm is offline   Reply With Quote
Old 01-09-2005, 06:27 PM   #6 (permalink)
goathead's Avatar
i would really like to put duals coming out in front of the rt rear tire (ala lightning) but w/ a cc there is not enough space. i still think ill put two on one side when it comes time for an aftermarket exhaust.
steve
steve
Old 01-10-2005, 08:06 AM   #7 (permalink)
MO Titan's Avatar
I may be wrong about this, but didn't ford change the position of its exhaust when from in front of teh tires to behind them because people complained that the exhaust was destroying their middle hub cap? I guess that wouldn't matter if you had aluminum rims.
Oddly enough, my daughter just made this same face!!!
My Truck: Born April 17, 2004, Purchased June 3, 2004
LE Canteen Crew, 4X4, BT, OR to which I added: SS Brake Lines, Advanced Folding K-Cover ,SS Lund deflector, Black Prism DunderDan grill (I hope it's coming soon), 4" Prerunner Greg Performance Lift, The first Zoomers SS exhaust ever shipped, Volant Gen III CAI, and Chick's Hulk engine cover, custom A-pillar with 1in guages (coming soon).
As Money Allows: Nismo Headers, Dynatech 2.25" Powercats (Damn Missouri and your air quality) Osirus, Trutrac, Stillen (sway bar, big brakes, diff cover), and PrerunnerTraction Bars.
MO Titan is offline   Reply With Quote
Old 01-10-2005, 02:47 PM   #8 (permalink)
caltitan's Avatar
Rear exit exhausts can leave soot residue on whatever you're towing as well as the possibility of carbon monoxide buildup if you have a shell or camper on the back. If you don't tow or have a shell, then there might be a sound difference between exiting the back versus the side. If you're putting in a custom exhaust system then be sure the rubber brake lines are not subject to the excess heat the new exhaust may generate.
2004 Titan SE KC 2WD
Flowmaster 70 Series Muffler, Magnaflow Resonators, AEM Dryflow Intake, Airaid TBS, Uprev Osiris Flash, ECO-3, Big Tow Package, ActiveTuning Grounding Kit, Crown Performance SS/Kevlar Brake Lines, PRG Leveling Kit & Rear Blocks, Nitto Terra Grappler 285-60-18 Tires, Truxedo Lo Pro Tonneau
caltitan is offline   Reply With Quote
Old 01-10-2005, 03:28 PM   #9 (permalink)
goathead's Avatar
here is a pic of the latest lightning you can buy.
steve
Old 01-10-2005, 04:07 PM   #10 (permalink)
GETSOMZ28's Avatar
The L definately has the coolest exhaust as far as trucks go! Definately out the side.
Scott
Old 01-11-2005, 06:24 AM   #11 (permalink)
Looks as if its the sides for me! Thanks everyone.!
Old 01-11-2005, 07:45 AM   #12 (permalink)
MO Titan's Avatar
Don't forget about your side lock box if you have one. Side exits won't work with it.
Old 01-11-2005, 12:00 PM   #13 (permalink)
spitan_titan's Avatar
This is how I have mine, I love it. I usually don't tow anything though. I like the look of the 4" outlets.
2004 Nissan Titan LE CC 4x4, Radiant Silver, DOB 06/04
mods:Flowmaster 70 Series dual/dual, Fram AirHog, Airbox mod
2003 Nissan Altima 3.5 SE, Satin White
1999 Honda Valkyrie Standard, Yellow/Creme
spitan_titan is offline   Reply With Quote
Old 01-11-2005, 12:11 PM   #14 (permalink)
MO Titan's Avatar
Who is it that has theirs going out the back corners with a downward angle?
Old 01-24-2005, 08:49 PM   #15 (permalink)
You can have duals coming out right behind the tires. The driver side is a little tuff due to the lock box. Its also a tight fit over the axle and spare. It looks good with the stainless tips.
smokeum is offline   Reply With Quote
