Installed the Flowmaster dual exhaust kit for the Titan. Very happy with the performance and sound. It bolts on after the resonators and uses a Y-pipe, single in 3", 70 series muffler, dual out 2.5", and SS polished rolled embossed tips.
The rev sound clips of the stock exhaust and Flowmaster exhaust were done using same recorder, same setting, and at approximately the same RPMs. These two clips were done to compare the stock versus Flowmaster exhaust sounds. The Flowmaster interior acceleration sound clip is from a stop heading up a steep hill.
Love it, it's not too much louder than the stock but it is, and such a nice sound. I know whats next on my list. Thanks for the up date.
White LE CC 4X4, OffRoad, Big Tow,Nav, DVD, back up sonar, sun roof, bug and window deflectors, Westin Bull Bar, K&N aircharger, A.R.E. bed cover, Centerline Stingray III's 17X8s, Utility Bed Package, W/ sliding bed extender and divider, Side air bags, all leather, Captain chairs. http://www.nitrousenterprises.com/ 3 inch Lift Kit. BFG 315/70-17 A/T
Very nice. How much was the exhaust kit? I wonder if you could get a sound clip from the interior, cruising at about 65mph?!
I purchased it from summitracing.com for $417.34 with free shipping (they actually had it shipped directly from Flowmaster to me). I'll see what I can do about that sound clip, but I expect it will not have much sound in it. After resetting the ECM and driving a total of about 100 miles, I have noticed that at cruising the interior noise level can be as quiet or a little louder than the stock exhaust. When cruising, I haven't had to raise my voice when talking to my wife or adjust the stereo sound upward. All in all, if you are on the gas, it will be louder than stock, and the higher the RPMs the louder than stock it will get. Hope this helps.
__________________ 2004 Titan SE KC 2WD Flowmaster 70 Series Muffler, Magnaflow Resonators, AEM Dryflow Intake, Airaid TBS, Uprev Osiris Flash, ECO-3, Big Tow Package, ActiveTuning Grounding Kit, Crown Performance SS/Kevlar Brake Lines, PRG Leveling Kit & Rear Blocks, Nitto Terra Grappler 285-60-18 Tires, Truxedo Lo Pro Tonneau
Thanks for the great sound clips and videos. I have found the exhaust for me now.
__________________ Oddly enough, my daughter just made this same face!!!
My Truck: Born April 17, 2004, Purchased June 3, 2004
LE Canteen Crew, 4X4, BT, OR to which I added: SS Brake Lines, Frozen Rotor Front rotors with Hawk L/T pads(on their way!!!), Advanced Folding K-Cover ,SS Lund deflector, 4" Prerunner Greg Performance Lift, The first Zoomers SS exhaust ever shipped, Volant Gen III CAI, and Chick's Hulk engine cover, custom A-pillar with 1in guages (no guages yet though).
As Money Allows: Black Prism Dunder Grill, 20" LiquidMetal Magma Mirror Black rims and tires, Trutrac, Stillen (sway bar, and diff cover), and PrerunnerTraction Bars.
Did you do the install yourself? How long did it take? Sounds mighty fine to me...I think I will be ordering a kit here sometime.
Yes. Jacked up the rear to give me a little more room to do it.
Removing the stock exhaust was very easy and took less than 30 minutes of labor. Removal involved (1) unbolting the flange connection behind the muffler and then sliding the entire tail section out; (2) Unbolting the flanges at the resonators; (3) Removing the hanger closest to the y-pipe; (4) Sliding out the remaining exhaust unit in one piece.
Installing the Flowmaster kit took about 4 hours by myself (including set-up/clean-up). If I had it up on a lift, some power tools, and a helper it would have taken far less time. It utilizes the stock exhaust hangers and includes parts to install one additional hanger. Currently, I only have the slip fittings holding it together but will also be getting the connections welded. A problem I had with the instructions was installing the additional hanger for the driver's side rear exhaust pipe. The instructions were not very detailed as to which direction the hanger was supposed to face after attaching it to an existing hole in the frame. Doing it their way did not seem possible as the spare tire was in the way, so I mounted the hangar on the other side of the frame and that worked (spent some time figuring this out as I did not want to screw it up).
Installing the Flowmaster kit took about 4 hours by myself. If I had it up on a lift, some power tools, and a helper it would have taken far less time. It utilizes the stock exhaust hangers and includes parts to install one additional hanger. Currently, I only have the slip fittings holding it together but will also be getting the connections welded. A problem I had with the instructions was installing the additional hanger for the driver's side rear exhaust pipe. The instructions were not very clear as to which direction the hanger was supposed to face after attaching it to an existing hole in the frame. Doing it their way did not seem possible as the spare tire was in the way, so I reversed the direction of the hanger to the outside of the frame and that worked (spent some time figuring this out as I did not want to screw it up).
Thanks, Caltitan for the pics/vids. Ordered mine from summit about an hour ago....lol! I swore I wasn't going to put more than one aftermarket exhaust on my truck.....but that's what I get for not waiting! I knew I didn't want the Banks, and loved the sound of the Flows, but until now they didn't have cat-back system.
BTW.....summit has this kit on back order until 2/21/05. Cost was same as Caltitan paid, $417 shipped......awesome price, considering it's over $600 from Flowmaster.
Caltitan.....could you snap a pic of the driver-side hanger mount discrepancy you referred to?? It will sure save others time and brain damage who are installing the kit.
Thanks,
Steve
Performance Mods:
Airaid TB Spacer
TB Coolant Shut-Off
Active Tuning Grounding Kit Int/Ext Mods:
SE Pwr Mirror Upgrade
Factory Step Rails
17" OR Wheels
SE Sunvisors Upgrade
20% Window Tint
The 17406 single in, dual out system is the only Flowmaster kit I've seen for the Titan. But not positive, though. If they had one, that's probably the one I'd go with too......I kinda like the sleeper look of a single out.
Performance Mods:
Airaid TB Spacer
TB Coolant Shut-Off
Factory Step Rails
17" OR Wheels
20% Window Tint
I would say, I will send you back my extra pipe and the muffler if you sent me single in single out 70 series muffler. Think they would go for it?
