Can Consult II correct for tire change?
When installing bigger tires, can the ECU be re-programed for the new tire size to correct speedo? Also, where does the Titan pick up it's speed signal?
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
