Old 02-17-2005, 06:15 PM   #1 (permalink)
Thumbs up Gutted My Air Box
Was just goofing off under the hood and decided to take a look at the air intake system. First off I must say that I am very pleased with how Nissan set up the airbox. I am not sure that a CAI set up any different from this is even worth the time and money. The OEM setup already pulls 100% of its air from the fenderwell, which anyone will tell you the fenderwell is the BEST place to get it. The only gripe I had was with the tube that feeds into the airbox itself. As it got closer to the bottom of the box, it got narrow, leaving only a tiny bit of room for the incoming air to go. Looked VERY restrictive IMO.
I took my Dremmel and cut the tube in half length wise and opened up the tube completely. Now there is nearly 4 inches of opening as opposed to a 3/4 inch (at best) from which to draw in air. After I put it all back together, it became very apparent why Nissan did it their way. NOISE REDUCTION! Under normal cruising and acceration, there is no difference at all. Open it up, COMPLETE different story. The only sound in the universe that I can compare it to is the sound of a an old school Big Block with a 4 barrel carb. I will do a K&N drop in here in a week or so and see if I have any gains in MPG over what I just did.
Cperki1 is offline   Reply With Quote
Old 02-17-2005, 06:23 PM   #2 (permalink)
JaxTitan's Avatar
Send a message via MSN to JaxTitan
Send some pics of what you have done.
I am debateing on whether to get the:
* K&N Drop In
* K&N Full intake
* Volant
Does anyone know the advantages and disadvantages of each?
2004 LE CrewCab 4x2
Dunder Chrome Grille
2" PRG Leveling Kit
20" Boss 309's w/ Goodyear Eagle LS's 275 55 20
Borla XS exhaust with Dual 3 1/2 Chrome Tips
Hood Engine Decals
JaxTitan is offline   Reply With Quote
Old 02-17-2005, 06:48 PM   #3 (permalink)
37L1's Avatar
* K&N Drop In
* K&N Full intake
* Volant
The Volant operates from a closed air box and uses a cone shaped filter that probably allows more air flow than the stock filter. In addition the Volant has a Ram Air Induction Scoop that can be added on that takes additional cold air from the lower bumper area.
gutted-my-air-box-volant.jpg  gutted-my-air-box-volant-1.jpg  gutted-my-air-box-volant-2.jpg  gutted-my-air-box-ram-air-1.jpg
2004 Titan Smoke LE CC
Born 11/18/03
Bed Extender, Overhead Racks
-Gambit
STUPID IS AS STUPID DOES.
-Forrest Gump's Momma
Old 02-17-2005, 08:17 PM   #4 (permalink)
JaxTitan's Avatar
is this system much louder?
2004 LE CrewCab 4x2
2" PRG Leveling Kit
Hood Engine Decals
Old 02-17-2005, 10:32 PM   #5 (permalink)
Armada's Avatar
Your mod is a little more extreme than most of us have done. If you want to do a search on "airbox mod" or similar phrase, you will find tons of info on what has become a pretty standard mod that modifies that internal snorkel without completely eliminating it. This improves air flow considerably while still keeping the noise down. I cut the end of the tube back toward the middle of the box, basically removing all if it from the middle on out, and tapered the new end at about a 45 degree angle so it points upward, but left the remainder in place. It does not seem any louder than stock but shoots the air up into the middle of the filter area. Others have done it different ways and some have even posted photos.
I run the drop in K&N and like it. There are a bunch of threads here which also debate that issue with different opinions. Check it all out, make up your own mind and enjoy your truck.
'04 Armada SE Offroad 4x4
Galaxy Black
K&N Drop In Air Filter w/ airbox mod
Carbotech Bobcat front brake pads at 28K miles (no brake judder, just time to change pads)
Armada is offline   Reply With Quote
