If you are going to go with a custom exhaust system make sure you are using piping with mandrel bends. You will not find mandrel bent pipe at 99% of the exhaust shops out there. Also, don't confuse the smooth bends you will find with mandrel bends. A mandrel bent pipe will maintain the diameter of the pipe all the way through the bend. This is not what you will get at your typical exhaust shop. You will get a smooth bend but if you look at it closely you will see that the diameter throughout the bend is less than that of the rest of the pipe. A 2.5" pipe becomes a very restricted pipe and your custom exhaust will be worse than what you started with.
You can get mandrel bent pieces from places like Summit Racing or Jegs which you can cut as necessary to fit your application.
As for headers... unless you are going to install a set of long tube headers (not sure any exist yet) you will be wasting your time and money. Shorty headers are of little to no benefit over the stock manifolds. You just can't get the scavenging effects out of shorties that you will out of properly designed long tubes.
The last point I'd like to make relates to the notion of low-end loss of torque with aftermarket exhaust systems. When it comes to anything past the manifolds/cats you will NOT lose low end torque with a free flowing catback setup. I don't know why that notion keeps comming up but unfortunately it does. If you could lock the torque converter and do a before/after dyno run across the entire RPM band you would not see a loss of low end torque. If you did it would purely be due to the air/fuel calibration not being optimum for the new setup not because a free flowing catback inherently causes you to lose anything at the lower RPM band. Header sizing is a different area that can have an impact on torque output but at this point in time it is not something the Titan community has to worry about. Backpressure in an exhaust system is BAD.
Tim
2004 Radiant Silver Titan SE 4x2
