Well, after having the box in my garage for a week, I finally had installed the Gibson Dual Sport system. I'll that I can say is THIS Fu$&ING ROCKS! I love the deep rumble. The drone is almost completely gone at cruising speeds and at low RPM's while driving in the neighborhood, the rumble is great!
Right after we were done, I took it off of the rack and took a "ride" down the street. The first time I jumped on it, I heard cracking, which I am not really fond of, and then 5 minutes later...no more cracking. The only thing that I may do is take the resonator off. I am going to wait a week first.
Thanks QUIKWHIP! Without seeing the system on your truck, I would not have known what to do.
2004 Titan LE CC
Smoke
Big Tow / Off Road
Utilitrac System (Bed Extender & Bed Divider)
Truxedo Lo-Profile Cover
Gibson Dual Sport (3/17/05)
Very cool! Glad it worked out for you! I also noticed the little bit of cracking/poping on the maiden voyage but it has never done it since then. As for removing the resonator, that will give you the raspy/cracking/poping sound your trying to avoid. But hey, it can't hurt to try it. You can always put it back in. Now, how bout some pics!!!!
Is the gibson a true cat back or does it connect at thr resonator?
Thanks
It depends on how you look at that. On 4x4 Titans there are 4 cats, on 4x2 models there are 2 cats and 2 resonators. The Gibson replaces the Y pipe and back.
Thanks for the info, I am goig to the muffler shop to have the resonator removed, I feel that they are the restriction in the exhaust. I have the Flomaster dual out, but would like to go with a new system, still researching whats out there
Ive only got 2 cats, and 2 resonators........
Happiness Is Beating Bama in Anything, Anytime, Anywhere
"The deadliest weapon in the world is a Marine and his rifle"
I've been looking at getting a Gibson side swept exhaust. Just wondering if the replacement would be a bolt-on job I could do myself in the garage, or is welding required? (I would definately need a muffler shop for the latter) I would appreciate any info on this.
__________________ Travisurfin247
2004 Titan 4X4 King Cab SE, Galaxy Black.
Offroad, Big-Tow, Utility Bed, and Preferred Packages.
OEM Side-Step Rails, Hood Deflector, Sliding Toolbox, and Neoprene Seat Covers.
it helps to have have someone push from the rear when you start tightening the u-clamps. this is so you can get all the joints slid together about 2 inches. don't forget to put the ground strap back on on the drivers side front connection. juma
TY
Got'er done this weekend! Love the sound and performance!
04 Radiant Silver SE KC 4X4, Big Tow, Utility Track
Air Box Mod w/ K&N High flow filter
Gibson Swept side Exhaust
Airaid TBS
TB coolant bypass
Royal Purple all around
Omega 8" Amplified Bandpass Tube
6 Kenwood KFC-P505ie 5-1/4" Midrange with 2 1" Tweeters
Planet Audio Amp
175W x 4
