Old 03-20-2005, 06:45 PM   #1 (permalink)
Bosch Platinum 4+ Spark Plugs
Has anyone had any experience with these plugs??? Do they live up to the hype given to them?
jeffdawgfan is offline   Reply With Quote
Old 03-20-2005, 06:54 PM   #2 (permalink)
I would say, stick to the oem plugs, I had used those plugs in my s-10 and seen no increase of performance
real_texan77 is offline   Reply With Quote
Old 03-20-2005, 07:46 PM   #3 (permalink)
GETSOMZ28's Avatar
I dont think different plugs will provide any increase in power (if that is what you were going for). With that said, I think the +4s are more hype...the +2's are just as good and quite a bit cheaper. However, if you want a good hot spark and great longevity, look into iridium plugs.
Scott
Old 03-20-2005, 11:05 PM   #4 (permalink)
dragonhead08's Avatar
I only trust NGK or Nippon Denso
dragonhead08 is offline   Reply With Quote
Old 03-20-2005, 11:22 PM   #5 (permalink)
Banned
tortuga's Avatar
went with the 4 tip bosch and the car just didn't run right, so then went with a set of the oem ngks and the car ran smooth. i wouldn't recommend them, they were a waste of money in my opinion...
tortuga is offline   Reply With Quote
Old 03-21-2005, 09:19 PM   #6 (permalink)
Denso Iridium maybe, but I have done several tests of the standard resistor type NGK and Denso plugs in my Turbocharged Civic. With both NGK and Denso plugs (#6 and #7 heat range) gapped at .040", I could easily extinguish the spark and cause a serious power loss at 5500rpm and above with the Denso plugs. The NGK plugs performed flawlessly. The Denso's needed to be gapped down to .033" to keep the spark strong. Whatever the cause, the Denso plugs don't seem to have the spark transmission of the equivalent NGK plugs.
Jim Truett is offline   Reply With Quote
Old 03-23-2005, 08:03 AM   #7 (permalink)
Nissan built the truck with performance in mind. If something as simple as a different plug would boost performance, the Titan would come from the factory with'em.
Desert is offline   Reply With Quote
Old 03-23-2005, 12:18 PM   #8 (permalink)
Thats why I said NGK first.
Old 03-23-2005, 01:14 PM   #9 (permalink)
GETSOMZ28's Avatar
I agree, NGK are some of the best out there. I use NGK copper plugs on my modded Z without any problems, and will put in NGKs on the Titan when it comes time to change them out.
Scott
Old 03-23-2005, 03:51 PM   #10 (permalink)
Justintoxicated's Avatar
Irriduim plugs shuould be good also but too damn expensive!
Old 03-24-2005, 07:36 AM   #11 (permalink)
GETSOMZ28's Avatar
I think iridiums are the best all around solution (hot spark and longevity), but you will pay $$ for them!
Scott
