Old 05-28-2005, 07:11 AM   #1 (permalink)
Banned
wmtom's Avatar
Question need an idea
hey guys, sorry this probly isnt perf. related but i need to borrow your brains, i use my titan to transport my quad alot, i just got on of those tri-fold ramps, and because of the bed height of the titan, the ramp angle is very steep, hard to get up and stop without killing myself, so... is there an easy way to temp. lower the bed of the truck without spending alot?
thanks
wmtom is offline   Reply With Quote
Old 05-28-2005, 07:36 AM   #2 (permalink)
If possible, maybe you can back the truck up to a hill, so the ramp goes from the hill to the truck, and won't be so steep.
Old 05-28-2005, 07:41 AM   #3 (permalink)
Banned
wmtom's Avatar
i thought of that too, but where i have to park when i go riding the area is level.
my luck, lol
Old 05-28-2005, 07:43 AM   #4 (permalink)
try to sell your ramps and buy a set thats longer. This will decreace the angle getting into your truck a little bit.
SpeedFreak is offline   Reply With Quote
Old 05-28-2005, 07:50 AM   #5 (permalink)
I have the same problem and usually look for a spot that is not level. The next time I load, I am going to fasten a block & tackle to the front tie down rail and pull it up instead of driving.
dhaessig is offline   Reply With Quote
Old 05-28-2005, 07:59 AM   #6 (permalink)
Banned
wmtom's Avatar
thats not a bad idea, maybe even a small electric winch.....
might be able to mount an atv winch in the bed
Old 05-28-2005, 08:24 AM   #7 (permalink)
Mike H.'s Avatar
Be careful. You might exceed the load limit of one cleat. If you do it, maybe use two cleats spread apart a few feet on the rail with a V shaped chain or cable to spread the load. Or maybe better yet, use the two permanant corner bed ties with a V shaped chain or cable. The fixed points are pretty beafy.
Mod links (clickable):
Old 05-28-2005, 08:58 AM   #8 (permalink)
many of the loading ramps are little more than 5.5 ft long. Look for one thats around 6.5 to 7ft
Old 05-28-2005, 11:47 AM   #9 (permalink)
Check the following url:
www.discountramps.com
They have many different styles of ramps, one might serve you well.
Also, if you get an ATV winch, why not mount it on the ATV so you could use it in the field as well as to winch your scoot into the truck bed?
You could also run an extension cord to the ATV from the Titan's power socket in the bed, if yours is so equiped.
Ralph
Ralph Featherstone
'05 Titan SE KC 4X2
rdfeatherstone is offline   Reply With Quote
Old 05-28-2005, 04:06 PM   #10 (permalink)
Banned
wmtom's Avatar
Problem solved, i went and got a portable winch good for 2000lbs.
bolted it to the bed floor, works great
thanks for the help guys
tom
Old 05-28-2005, 06:24 PM   #11 (permalink)
Banned
wmtom's Avatar
Ralph
By the way, its a sport quad so no way to mount a winch on it
Old 05-29-2005, 06:45 PM   #12 (permalink)
SarkaZm's Avatar
Send a message via ICQ to SarkaZm
tom
Thanks for the pictures J/K, but they would be nice. Also, where/how much/brand of winch....
More Pic's Here
SarkaZm is offline   Reply With Quote
Old 05-31-2005, 08:25 AM   #13 (permalink)
Banned
wmtom's Avatar
sorry , for sum reason i cant upload the pics i think there too big a file, but the winch i got from walmart for 50 bucks, made by master lock, good for 2000lbs, has mounting holes on the bottom i bolted to the bed up front.
