Originally Posted by Calhoun687
Well i got my Volant in last week and installed it over the weekend and it seemed a little to short ( tube going into the Air box ) so i managed to adjust as much as i can but the Filter came off after the first time of driving it.
Reinstalled the filter after wiping it down real well where it attaches to the tube but after really getting on the throttle yesterday it came off again.
i just appears that the tube from the TB might be too short it is about 1 inch away from the air box it self so there is a gap under the rubber boot of 1 inch which leave you very little room to install the clamp without it slipping back off
has anyone else had this problem ?
No, everything fit perfectly, no problem with the filter fitting on or coming off. Are you sure everything is mounted correctly. Do you have all of the parts? I have a photo of the entire volant system before install in my photo gallery, take a look at it and make sure you got everything you were supposed to get. Maybe take photos of your install and then we might be able to see if there is a problem.
Otherwise:
joe@volantperformance.com
2004 Titan Smoke LE CC
Born 11/18/03
Bed Extender, Overhead Racks
-Gambit
STUPID IS AS STUPID DOES.
-Forrest Gump's Momma
