sounds cool, but I wonder what kind of numbers it makes over just what an intake could give. Its like when people spray their intercoolers. I think the new STI's come with the spray. Or was that the Evo, can't remember.
I believe it says 3.5 minutes if you energized the solenoid contiuously until bottle emptied--this isn't how you would use it, though. They say it should be good for 5 or 6 drag runs.
Obviously, you'd have to mount it upstream of the MAF for it to read the denser air charge. The MAF should recognize the density change immediately and make appropriate adj. Also, a huge advantage is that it cools the fuel charge too, not just air charge. And, yes, it would be a pain refilling the 10lb bottle of CO2 every 5 or 6 runs, but at least CO2 is cheap. The part I wouldn't be too crazy about, is splicing the fuel rail. Like Head said, if you're willing to go this far, might as well just go nitrous and have some serious power. I wouldn't mind experimenting with just the air-side heat exchanger, though, as this would still give you a nice dense charge on a hot day w/o a lot of modding....could easily be put back to stock if you had an extra inlet tube.
Performance Mods:
Airaid TB Spacer
TB Coolant Shut-Off
Active Tuning Grounding Kit Int/Ext Mods:
SE Pwr Mirror Upgrade
Factory Step Rails
17" OR Wheels
SE Sunvisors Upgrade
20% Window Tint
it is the Evo but it sprays H20 on the intercooler to cool the air charge but Nos would be mutch more effective .
__________________ 06 Red brawn SE CC: Armada front air dam, Nissan foglight kit,Big tow mirrors,tow hitch,splash guards,side steps,20% tint,Gibson extreme dual exhaust,Nismo intake
05 Blizzard white KC(sold)
