This item makes a big difference in the overall lean of the truck when making any kind of turn and reacts very fast to left-right transitions (or right-left). I thought I was imagining things, but this sway bar really makes a difference. It took me about an hour and a half to install due to interruptions. No interference issues.
That's fantastic.
That's just what I need to keep the XE grounded. I've found here in Jax.(FL) that speeds over 75mph on the Interstate mergers/ ramps are a little tricky. Need a little sticky.
Is that hellwig.com?
Could you take a measurement from the bottom of the diff cover (bolt and seal area) to the swaybar. I am wondering if there is going to be enough room to put the large PMLI cover in with the Hellwig.
I ordered my swaybar today. I am hoping it will clear the large dif cover.
Thanks for the pictures, it looks great!
2004 Titan 4X4 LE Crew Cab
K&N Gen 2 FIPK
2 degree timing advance
Nismo Pedals
Sirius Satellite Radio
Lund Hood Deflector
PRG Mini Lift
Axle Vent Mod
Bed Light Mod
Does that think lower the height of the vehicle? Have the PRG installed and can't afford any loss in the height department. I've got a 1/2" rake right now and don't want to lessen it. Thanks Head.
I too am wondering if there will be enough room for the PMLI cover. I am torn between the two now and am hoping that I can do them both. According to the PMLI diagram the cover extends 4.75 off of the center section (mounting surface). From your picture it looks like there is enough room, although it may be necessary to install the cover before the sway bar. If you (the head) could measure I would really appreciate it. Thanks in advance.
Sold 8/2006
Replaced With 2006 Subaru Impreza WRX
Just Can't Stay Away
It gets to within 4.25" on the left side of the bar as it curves in towards the axle housing. This is roughly right on the edge of the bolt pattern. It's about 5.5" to the bar as it goes around the rear cover.
