Old 07-21-2005, 09:21 AM   #1 (permalink)
Master Cylinder Brace Available!
My buddy went down to Stillen yesterday to talk to a sales associate and was informed about their new master cylinder brace! He ended up purchasing it and man, the difference is night and day! The M/C had soooo much flex before the install and with the brace installed it hardly even moved! The cool thing is it bolts onto a few unused holes that the ABS bracket has! No drilling or modifying anything! I bet this part will be one of the many upgrades to help the titan overcome it's poor stock braking system. I think he paid like 50-60 bucks for it. I didnt't get a chance to drive his truck but he said it made a big difference considering the price. It might be up on their website....I didn't check.
sean
socalsean is offline   Reply With Quote
Old 07-21-2005, 11:30 AM   #2 (permalink)
TCW
TCW's Avatar
sean
Hopefully I'm not the only one wondering, but how does the new brace help your braking?
Thanks.....
2005 Silver Titan LE CC 4x4
Off Road, Big Tow, Sunroof,
NAV, DVD, Side Air Bags,
Floor Mats, Splash Guards,
Sliding Bed Extender
Mods:
Rancho 4" Lift w/ Fox Coil-overs,
Bilsteins, & Deavers from PRG,
Total Chaos Upper Control Arms &
Stainless Sway Bar End Links - PRG
Window Tint, Banks Monster Exhaust
Black Bib on tailgate painted Silver
AVElectronic NAV Video Switch
MB OffRoad "Gunner 6" - 17 x 8
315/70R17 Yoko Geolander A/T-S
Dunder Dan Chrome Grill
Infiniti Center Console Lid
Active Tuning Grounding Kit
UnderCover Tonneau Cover
TCW is offline   Reply With Quote
Old 07-21-2005, 11:51 AM   #3 (permalink)
goathead's Avatar
just thinking the same thing......more info please!!!
steve
Old 07-21-2005, 11:54 AM   #4 (permalink)
Have someone get in your truck when its parked and have them push on the brake pedal. Push hard...like you're trying to stop in a panic. Look at the master cylinder while your friend is doing this. Notice how the entire master cylinder moves and flexes against the firewall? The force you're applying to the master cylinder to pump the brake fluid through the lines is being "eaten up" since the mount flexes. It'd be like if you were trying to jump up and touch the ceiling but the floor you're jumping off from flexes soooo much that you can never touch the ceiling. Same priniciple. The brake pedal will feel more solid, stiff, less muchy, and the force from your foot pushing on the pedal will get transfered to the mastercylinder instead of just bending it. Hope that made some sense.
sean
Old 07-21-2005, 11:56 AM   #5 (permalink)
37L1's Avatar
Where do you work, Sean?
2004 Titan Smoke LE CC
Born 11/18/03
Bed Extender, Overhead Racks
-Gambit
STUPID IS AS STUPID DOES.
-Forrest Gump's Momma
Old 07-21-2005, 11:57 AM   #6 (permalink)
Send a message via AIM to emerilnut Send a message via MSN to emerilnut Send a message via Yahoo to emerilnut
Thanks.....
Yeah these came out for the Miata years ago, but supposedly, with the pressures involved in your brake lines and the pedal, the brake master cylinder bears the brunt....so in fact, when you hit your brakes when in motion, the master cylinder flexes and even expands silghtly under all that pressure. Supposedly that means that before the pads press on the rotors to stop the car, first the master cylinder has to flex and expand, costing you about 1/2 an inch or so in brake pedal travel. So the theory is to use this brace (mounted up agains the master cylinder) that prevents the master cylinder from flexing so that "all" your foot force actually goes to stopping the truck (moving fluid through the brake lines).
After MUCH discussion of the Miata unit, we decided that it actually can't improve braking at all, what it really does is change the feel of the brake pedal (making it a stiffer pedal with a higher engagement point). But then again, better feedback through the wheels and pedals is always better for the driver, right?
emerilnut is offline   Reply With Quote
Old 07-21-2005, 11:57 AM   #7 (permalink)
I work for my friends construction company in San Diego and go to school part time. Every once in a while I run my fathers Sound Equipment rental company...but thats more of a hobby than anything else. Need a PA system?
I even went out to check my daily driver (volvo) and the MC flexes too. I'm going to have to conjour up something to keep that sucker from flexing. Sounds like a worth wild mod IMHO.
Old 08-07-2005, 08:00 PM   #8 (permalink)
CJ3FLYR's Avatar
I am excited and a little PO'd at the same time. I ordered one of these and it doesn't fit. I'll contact Stillen tomorrow and I'm sure they'll make it right. I am discovering that Titans may have some substantial differences with brake systems. I purchased a Stainless Brake line kit (not Stillen) and they modeled the kit on a non-ALBS model. It came through short one line. Now my master cylinder support misses by an eighth of an inch. I can't help but wonder if Brake Assist, ALBS and non-ALBS don't have slightly different dimensions. This thing is not right and I’ve gone out three times with fresh, rested eyes.
master-cylinder-brace-available-p8070005.jpg  master-cylinder-brace-available-p8070006.jpg
Chris
05 Blizzard LE CC, 4x4, BT, OR, Nav, AB, Sunroof, XM, Ceramic Pads on new rotors & hardware (10.2k+miles,no brake issues to date and very clean wheels), AutoExtreme TBS, TB coolant bypass, Inverted helper springs, Hi-capacity diff cover, Active Tuning ground kit, poly swaybar bushings (front), Axle Vent Mod
CJ3FLYR is offline   Reply With Quote
Old 08-07-2005, 08:52 PM   #9 (permalink)
CJ3FLYR, I am interested to know how things go with Stillen. I was about to order the line kit and thought about ordering the brace as well but I may not now. I too have an ABLS Titan and do not want to have a fitment issue. Thanks in advance. On a side note, how many stainless lines does a ABLS Titan need?
Sold 8/2006
Replaced With 2006 Subaru Impreza WRX
Just Can't Stay Away
mysecondnissan is offline   Reply With Quote
Old 08-07-2005, 09:49 PM   #10 (permalink)
yogibm1's Avatar
I can always appreciate better braking
WHAT ARE YOU DOING????
Click here for some good clean fun
Yeah, I didn't like to fight when I was a kid. Mainly because it was always that one guy and his four friends that wanted to kick my butt all at the same time.
yogibm1 is offline   Reply With Quote
Old 08-08-2005, 07:19 AM   #11 (permalink)
CJ3FLYR's Avatar
Mine needs six lines... Where my kit 'fell down' was on the lines from the body to the top of the rear axle. The kit had a single line down that Tee'd off to the right and left side. I have two separate lines. I've been in contact with Goodridge (purchased through RotorPros) and they are making it right. I always thought a single line was a tell tale sign of 3 channel ABS. I thought all Titans were true 4 wheel ABS, oh well, perhaps they modeled the kit based on a prototype.
Chris
Old 08-11-2005, 04:31 PM   #12 (permalink)
CJ3FLYR's Avatar
The guys at Stillen were first class. They admitted they made a mistake with the dimensions. It sounds like I had the right idea with ALBS, Brake Assist and non-ALBS having some effects on the dimesions. They sent UPS to pick it up, they also said a brace that fit would be ready very soon .
I also mentioned my brake line deal on another forum and was informed that the Stillen kit comes through with all six lines.
Chris
Old 08-11-2005, 05:59 PM   #13 (permalink)
Thanks for the update CJ3FLYR. I was about to order the brace and lines but it looks like I am going to have to wait for now. This is what the forum is all about.
Sold 8/2006
Old 08-12-2005, 06:15 PM   #14 (permalink)
CJ3FLYR's Avatar
No need to hold on the lines if you by the Stillen sold/endorsed kit. Their kit had all 6 lines, my kit was from another supplier.
Chris
Old 10-01-2005, 08:57 AM   #15 (permalink)
CJ3FLYR's Avatar
Anyone know if they've updated the master cylinder brace?
Chris
