Old 08-01-2005, 02:43 AM   #1 (permalink)
triplet_2004's Avatar
Tire Rubbing?
I recently bought a 2005 Titan SE 4x4 Crew Cab that came from the
dealership with a 6" Fabtech suspension lift with LT325/65/18 tires on it
already. I experienced some pretty severe tire rubbing on the edges
of the fenders when turning. After taking it back to the dealership
(with a bad attitude) they did some minor body modification to remedy
the rubbing (I talked them out of aftermarket nerf bar side steps
too). I was wondering if anyone else has had any tire rubbing
experience with lift kits/bigger tires?
Evan
triplet_2004 is offline   Reply With Quote
Old 08-01-2005, 06:52 AM   #2 (permalink)
92TripleBlack's Avatar
Surprised you had the rub with the lift. I had a little rubm but my tires are an inch narrower and an inch and a half shorter. I solved mine with a heat gun. Check the tire section regarding this. Maybe they had the incorrect offset? Good luck with the setup..
Trucks are for raising, cars for lowering!
Post softly and carry a big stick!
'05 Armada LE 4x4, Red Brawn, Graphite, Tech Pkg, DVD, Bench, Nitto Terra Grapplers 305-55-20, MB Motor Express 20x9 rims, 6000k HID lows, Silverstar 9005 Highs and 893 Fogs
'92 Vette Vert-All Black,6-Spd,Sport Seats,ACC,K&N,Custom CD w/sub,Chrome GS Rims,Mich Pilot Sports(275-40-17F,315-35-17R) GS fender flares,Pwr Effects Exhst,Z06 Brakes,Hawk Pads,lowered,camberbrace,Hurst,Stage 3 Clutch,single mass alum flywheel,'96 glass wind top,HAL Qa1 Shocks
'04 G35 Sedan-All Black, Sport pkg, wing, every opt.
'02 Jetta GLS 1.8T Girlfriend's
'04 Kawi STX-15F JetSki
92TripleBlack is offline   Reply With Quote
Old 08-01-2005, 03:59 PM   #3 (permalink)
EPTITAN's Avatar
Location: some where between bum f&*$ Egypt and you got a pretty mouth
Evan
I have the same lift and same size tires, mine rubbed slightly but I also have the leveling kit on with the lift. Check the front of the wheel wells, there is a little fin part in the center, trim that fin down a little. That helped take care of mine, I thought it was rubbing in the rear of the wheel well.
EPTITAN is offline   Reply With Quote
