Old 05-25-2008, 06:11 PM   #46 (permalink)
Re: Drag racing how-to, hints, and tricks thread
Originally Posted by countryboy
ive got an 06 titan with an chip Injectors throttle body spacer and a custom home made 4 inch cold air intake and iam trying to get my truck to get in the low 13s high 12s but iam having problems hooking up got any suggestions
traction bars and wider tires.
danielquave is offline   Reply With Quote
Old 05-25-2008, 07:41 PM   #47 (permalink)
TitanBlue's Avatar
Jet has been basically dismissed by the Titan community, and they don't seem to be developing it for us any longer. Go with Osiris asap and you'll get a free upgrade to the true programmer they are bringing out soon.
2006 XE CC Pref Pkg BT with AEM Brute Force CAI, PowerAid TB Spacer, TB Reversed Valve ByPass Mod, 2007+ Intake, JBA Headers, MagnaFlow 24" Muffler, 2008+ Rear Axle, Stillen: F & R Sway Bars, Black Diff Cover, Engine Dress Up Kit, 4 pc StreetScene SS Mesh Grille, PRG Street Traction Bars and Mini Lift Kit, UpRev Osiris Tuner 93 Performance Tuned, MB Razor Rims, Functional Hood Scoop, Custom Graphics ...
Old 05-25-2008, 07:42 PM   #48 (permalink)
TitanBlue's Avatar
Can you give us more detail on what brand parts you are running to get the performance you have?
What "injectors" , "chip", etc. Doesn't sound like you should be that fast already; not with no exhaust upgrades???
Old 05-25-2008, 09:04 PM   #49 (permalink)
Leadsled124's Avatar
I would like to see what parts you are claiming as well. If ur running an ebay "resister chip" ditch it asap! I find it hard to believe you are running those times without headers and a tune...and if your not 07 or newer Cams.. Im not trying to call BS but look at the drag times. It doesnt fit.
Post up what you got. Crewcab / Kingcab 4x2/4x4 mods, year etc, and well help you meet ur goal. Toomnymods is running a 12.8 with cams and more than you got, and has to run slicks and a 125 shot of juice to get there.
edit. saw you have an 06 like me. Is ur 13.8 a real track time or a performance meter in ur truck you used ( gtech etc)
'06-Uprev/Stillen Longtubes/JBA Kat-bak/Injen/highflows/PGM/Trutrac...
Leadsled124 is offline   Reply With Quote
Old 08-26-2008, 06:05 PM   #50 (permalink)
I was just wondering....I've got the whole Stillen library of performance goodies including the SC....but under full throttle the transmission freaks out and short shifts. Well....that and the motor bogs until about 30-35 than all hell breakes loose.
Could this have something to do with the open diff....starting to think this all has something to do with the vsc and not having a trutrac holding my truck back.
Six-Gun-Todd is offline   Reply With Quote
Old 08-26-2008, 09:38 PM   #51 (permalink)
Well even with the WOT restriction removed you will feel a little increase in power around 40mph depending on tire size gearing etc. Thats just the point where the powerband really takes off.
if your getting a bog it could very well be the open diff. do you see the "slip" light flash on the dash when this happens? If so then it is cutting power to try and get traction. After Trutrac you will never see that nastly light again
Oh also saw you have the blower? Well you do not have wot untill 40 mph then, but thats ok because it will save your trans under boost. I would make sure you are not experiencing detonation though. Get to a dyno or a shop that can monitor. Detonation will cause timming to be pulled and worse case senerio the end of your motor. There have been many cases of this, and every truck need to be tuned differently
Old 08-27-2008, 09:39 AM   #52 (permalink)
Nope...no detonation....here in Michigan 93 octane is at just about every pump and my fuel mix checks out perfect with the wideband.
Funny you should mention the slip light....that baby comes on for quite some time....the vsc flips out and starts trying to compensate. To bad it's not quick enough to control the slipping wheel...my burnouts look like a staggered dashed line. Just wish I knew someone in Michigan I could trust putting in the Truetrac.
Six-Gun-Todd
Old 08-27-2008, 11:09 PM   #53 (permalink)
Six-Gun-Todd
Ya im not too familiar with VDC since my truck doesnt have it. I just here people turning it off or doing a bypass switch or somthing. The slip light i would bet on is the main cause.
The Trutrac is not too difficult if you hav good mechanical skills. follow the directions and dont cut corners. theres a write up somewhere around here
Old 08-30-2008, 06:04 PM   #54 (permalink)
Well....I've done everything else myself with no issues....kinda wished I knew more about the headers before I installed those....that just sucked.
But I've got a couple lifts and just about every measuring tool you could think of.....what's the part number for the Truetrac anyway ??
If you could find the link for the install it would be greatly appreciated.
Six-Gun-Todd
Old 09-12-2008, 05:58 PM   #55 (permalink)
No one is perfect for mothers womb, so in order to perform a good driving we need to concentrate what all we do while driving. So there are no special tricks or hints. Practice make a man perfect. There might be a some coach for professionals but it all depends upon how they practice.
ebinezer
california dui
ebinezer is offline   Reply With Quote
Old 07-08-2009, 07:58 AM   #56 (permalink)
madahajimoto's Avatar
Just did my 06 Armada at the 1/8th of a mile last week at Borona Casinos in San Diego County. My best was a 9.4 @ 70 something. Went up against a SS HHR 3 times and lost by about .2 seconds all times, but got closer as the fuel went down. His mods where some stage one upgrade which consists of exahust and some sensors. Mine are JBA Headers and Exhuast, Bully dog, aFe, trans cooler, lighter rims, 400 pound weight reduction and all the little nick nack things everone else has. My reaction times where slow though, around .5. I had no traction problems though, it just takes right off when I floor it. Might be because I have weight over the axles... Hope these tips help for my next run at Qualcom stadium this friday.
madahajimoto is offline   Reply With Quote
Old 07-10-2009, 11:55 AM   #57 (permalink)
bottlerocket's Avatar
Went to Milan Dragway Wednesday night for test and tune night. Wanted to see how the truck ran before I put the Doug Thorley LT's on. I have 2* timing and a S & B cai. Temp was 78 - 80 ,low humidity and had 1/4 fuel and 150lbs of tools,jack and stuff in the bed. I ran 4 times ( busy as pinks all out is Sat @ US 131 ) . My best run was 15.36 @ 89 mph. Best pass was no brake torque as I hooked very well with brake torque but only dropped 0-60 .02s and turned 15.57 @ 88+. Overall I'm please (always want to run faster of coarse). I have a 4X4 08.5 KC with big tow and 4000 miles. Pulling the mirrors in had no effect on trap speed. I'll take it back when I get the headers on....
SMOKE~2008.5 KC~PRO4X~BIG TOW~TRIFECTA~S&B CAI~UPREV~DOUG THORLEY LT~TINT~BED DIVIDER~PRG LEVELING KIT~AIRLIFT BAGS
bottlerocket is offline   Reply With Quote
Old 07-10-2009, 01:46 PM   #58 (permalink)
O-FiveCC's Avatar
Nice runs. I always brake stall, but everyone has their own way of doing things. If you were srtalling for longer than 2-3 seconds then that's why your time suffered. If you do it for longer the ecu pulls timing
http://videos.streetfire.net/video/0...-It_691843.htm
IRC VK56 Pit Crew Chief
13.842 at 96.98--8.78 at 77.75 1/8th 1.92 60' NA FST (pre-PGM)
2005 XE Crew Cab
Performance: Nismo CAI, Nismo Longtubes/NO Cats, Uprev, JBA cat-back, Tru-track, 07 intake, Hellwig Traction Springs
Interior: Nismo SS gauges, 2 Sundown 9" Monitors
Exterior: painted Armada air-dam, 6 piece Billet grille, chrome handles, SE Mirrors, DDM 8000k HIDS, Bilstein 5100's, Springtech 2" shackles, OEM 20's
NY-Trex wet kit, TransGo shift kit
O-FiveCC is offline   Reply With Quote
