The pics from SEMA are in, and a Vortech kit with an aftercooler is in there. The kit should be good for about 150-160HP at the crank on a stock engine at 9psi with the aftercooler. Vortech kits generally run around 4k-5k, so this is good news if they do produce it!
With an exhaust it'll probably push the Endurance to about 500HP or 400rwhp. That's not bad.
Should we be hearing about this kit soon, I hope
Share the wealth of knowledge and go as fast as you can.
IRC Member "International Racers Club VK56"
TESTING: GTech/Pro RR, AutoTap, Auto Enginuity Enhanced, UpRev, Audio Spectrum Analyzer for Knock Sensors Monitoring, HP nx9420 Notebook PC T7700, Sprint Mobile Broadband
MODS: Custom PGM 90mm Throttle Body, Custom PGM Throttle Body Spacer, Custom Throttle Body Intercooler, Custom Ram Air, Custom 160 degrees Thermostat, Custom CAI, Nismo Headers, Custom B-Pipe NO Cats in line and NO Simulator without CODES (LOL), Custom MagnaFlow Exhaust, Custom Tune, Flex-a-Lite 27 Electric Puller Fan #295, Jim Wolf Technologies Camshafts, Detroit TruTrac LSD.
Sounds good. I'm in if they produce it!
04' KC Popular w/RF, Truxedo Lo Profile, Deepwater "Blue",
is this the same kit vortech showed at last years sema?. When i talked to a guy at vortech they said they are not producing this kit, they said it is a joint deal with nismo and you will only be able to get it through NIsmo, AND considering it took Nismo almost two years to come out with an intake i wouldnt count on seeing it anytime soon. Are you saying they are releasing this year at 2005 sema?? Also what is CT?? My 2 cents
chad
__________________ 2004 NISSAN TITAN SE PERFORMANCE:K&N FIPK 77 / COOLANT BYPASS / MAGNAFLOW MUFFLER / RESO DELETE / +2 DEG TIMING ADV. SUSPENSION: STILLEN SWAY BAR / SB DROP KIT / HOMEMADE SHACKLES / EXTERIORSTILLEN DIFFERENTIAL COVER / STILLEN ROLL PAN / FULL XE FRONT END CONVERSION / GRILL CRAFT GRILLES / ANZO L.E.D. TAILIGHTS / BRTMAN INDUSTRIES CF SIDE PILLARS / REFLEXXION CF HOOD / DE BADGED / DIP 20" WHEELS + NITTO NT404 305/45/20INTERIORKATSKIN INTERIOR KIT / BRTMAN INDUSTRIES CF DASH KIT / PAINTED DASH PIECES GLOSS BLACK / MOMO CF SHIFTER KNOB / ECLIPSE HEAD UNIT + FOCAL COMPONENTS
15.026@89 @ 94 DEG & 84 % HUM.
I believe CT is Club Titan which is a nice forum with some good information. I also believe you may be right about the time line for NISMO parts as sad as that may be but at least it may be out in 2007 and that is good news so keep that fine intelligence info comming.
__________________ IRC VK56 Member "BIG CHIEF WANNARACEUM"
2005 XE, "Land Shark",1/4 MILE: 13.851 AT 98.52 Full Street Trim on Snow Tires Record HolderBuild date 3/05
Performance mods: UpRev, JWT cams, NISMO CAI, NISMO True Duals with Dr Gas Xpipe, NISMO Headers with Swain's White Lightning Coating, Suncoast Ram Air Hood, Tru Trac, Burnout mod
Stereo mods: Pioneer Premier DEH-P880PRS head unit, Audison LRX 4/300 Amp, Boston 6x9 coaxials front & Focal 6.5 coaxial rears with JL tweeters in dash.
I posted that. I will talk to Vortech again and see if it will happen or when. If NISMO has it, maybe they will include some sort of tuning software with it.
Hopefully, ATI will produce one (though, I hope a vendor or some tuner takes an ATI head unit and produces a FMIC'ed kit, because let's be honest, ATI kits are not the greatest upon release) and then we'll see pretty big numbers out of a Titan if we ever get some sort of tuning software.
Actually, Vortech head units are good too. For a custom setup, we'd just need an intercooler, IC piping, 8-rib pulley system/bracketry, injectors/fuel booster, and an ATI/Vortech kit. 600BHP (480rwhp) wouldn't be hard at 10-12psi with headers and exhaust on the Titan, but I don't know the limits of the Endurance.
Any tuners out there listening?
Btw, I did talk to Kooks and Quicktime Performance (QTP) about longtube headers, and Kooks can do a custom setup if I give them my truck but nothing mass-produced. QTP said they were going to look into over the winter, so maybe that's a good sign. Both make high-quality 304SS headers.
Now, if we can get some DOHC cam kits, those 600HP levels can be had at 8-9psi.
2004 Deep Water Titan SE CrewCab 4x4 with Big Tow
Exactly. The Endurance is a very good platform to start with it would seem, so we should all request and inquiry into the status of parts from our favorite manufacturers.
I've been able to find that it has a forged crank and coated pistons, but I don't know if they are forged as well. I have no idea on the rods, but if they are billet and the pistons are forged, we have a Supra/Mustang Cobra on our hands. If the crank is forged, I suspect the other components are as well, since the crankshaft is far more expensive than a set of rods or pistons, so why cut corners on less expensive components?
A mass-produced forged engine that will take a lot of boost will make this engine platform a true aftermarket gem. Look at the Cobra and Supra's aftermarket. Bolt on a new supercharger or turbo and make a load of power for not a lot, or simple BPU upgrades for either. I don't know why the Titan would have an all-forged engine, but if it does, we will be having some fun in the coming months and years as tuners begin to explore it.
wow, forged crank. HA, eat that Hemi's... Do they have forged internals too? lol its all good. I'm hoping this Vortech kits kills the Eaton/Stillen. I know for alot of vehicles the Vortech's are nicer than alot of others. For my little car they are only a little behind turbo's.
I'm still gonna wait for a turbo kit. I want an increase in efficiency, power, and fuel economy instead of just power. I'm still stuck on that STS kit, it looks really cool and without the need for exhaust manifolds. A conventional twin turbo kit would be cool too though....
Although if Nismo came out with one that would retain the FACTORY warranty, then I would consider a supercharger. I'm still trying to figure out how much fuel economy you lose with a supercharger....... anybody know? I would guess because of the extra fuel being introduced in the engine with extra injectors, etc you would lose something.
Also, for some reason I like the look of Roots type superchargers instead of the conventional centrifugal type. The big chrome stillen one is way pertier than this one but you pay for it I guess.
2005 Titan SE 4x4
Floor Mats
Splash Guards
Nissan Drop-in Bedliner
Front windows tinted to 35%
In-Channel Vent Visors
Front Husky Liners
STEREO:
Pioneer DEH-P8MP Head Unit
Wow a Turbo Kit? That'd be the one to get. The supercharger I believe will require the use of higher octane fuel, as well as suck up more gas, and would probably kick in around late 3 grand. A turbo kit sounds nice if they make one, if it's Nismo, even better!
2005 Titan SE Smoke Metallic
AVS Bug Gaurd
Fog Lamps w/Parking light tweak
Volant Gen3 CAI Exhaust Custom Flowmaster 50 series SUV Performance exhaust.Click here to listen. Grill- Mr. Grille Headunit- Kept stock and added Audiocontrol LC6 a must for stock headunits! Power-
Audiobahn 1 Farad Capacitor Fronts-
JL Audio XR650CSi's 6.5 components
Total Mobile Audio 3202 Amp www.totalmobileaudio.com Rears-
Diamond D361's www.diamondaudio.com
Soundstream Reference 200 Amp Sub-
Single 12" Blaupunkt Overdrive
Soundstream Reference 500s Amp
The current crappy Stillen one is under 100 HP and almost $6 grand.
Trucks are for raising, cars for lowering!
Post softly and carry a big stick!
'05 Armada LE 4x4, Red Brawn, Graphite, Tech Pkg, DVD, Bench, Nitto Terra Grapplers 305-55-20, MB Motor Express 20x9 rims, 6000k HID lows, Silverstar 9005 Highs and 893 Fogs
'92 Vette Vert-All Black,6-Spd,Sport Seats,ACC,K&N,Custom CD w/sub,Chrome GS Rims,Mich Pilot Sports(275-40-17F,315-35-17R) GS fender flares,Pwr Effects Exhst,Z06 Brakes,Hawk Pads,lowered,camberbrace,Hurst,Stage 3 Clutch,single mass alum flywheel,'96 glass wind top,HAL Qa1 Shocks
'04 G35 Sedan-All Black, Sport pkg, wing, every opt.
actually, a supercharger has boost right off idle and the turbo will need spool up time since it is running off of exhaust gas.
