Old 10-03-2005, 09:12 AM   #1 (permalink)
lenj33's Avatar
Send a message via AIM to lenj33
Come onnnnnnn Borla!
My borla exhaust shipped last Thursday. UPS says it left sunny California...
Watching the UPS tracking of something from california to virginia can be EXCRUCIAITING!!!
Come onnnnnnnn, exhaust!!!
I'm most likely going to have a shop install the borla catback.
Do you guys have any gotchas or advice for the install procedure?
I plan on being there
THanks!
Len
'05 Loaded LE, off road, big tow, preferred package, utilitrack, overhead racks, captains chairs, DVD for my girls and Nav for my girlfriend
lenj33 is offline   Reply With Quote
Old 10-03-2005, 11:16 AM   #2 (permalink)
i had to cut off about 1 inch from the end left tube (inner side) to even out the two exits
love the sound
Alkhowaiter is offline   Reply With Quote
Old 10-03-2005, 01:13 PM   #3 (permalink)
I installed the Borla system this past weekend and had no problems at all. True bolt-on with minor adjustments to get tip alignment even. Start to finish from stock removal to starting it up with the Borla was about 2 1/2 hours.
SDog is offline   Reply With Quote
Old 10-03-2005, 01:20 PM   #4 (permalink)
mopar's Avatar
Send a message via AIM to mopar
Len it can be installed in 60 minutes (2 hrs if your slow and have beer breaks)with out jacking the truck up and a buddy so your not dragging the pipe around. just shoot all the bolts with penetrating fluid( I used PB blaster from walmart) the night before. I just used hand tools no cutting just unbolt the old one and pull off. mount the rear tip hangers(just 2 bolts) slip the new one on line up and the tighten all the clamps. Unless your shop charges you $50 or less I think its better to save the money for other mods. If I was close by I'd come give you a hand maybe some member close by could come by. I did mine at 7 when it was getting dark and had no problems.
Borla
Sean
RLTW
05 Galaxy Black SE CC 4x4 w/Big Tow Born on 01/05
Borla Cat Back--------AVS Taillight Blackouts
ARE Z series cap------Wade InChannel Ventvisors
OEM Step Rails PC Black-----Weathertech extreme floor liners
K&N 77series CAI------Tailgate mod
Rubber Bed Mat----Custom Bed rug
PRG 4" Perfomance lift--OR Skidplate PC Black w/holes
KMC Backseats 18x9---Procomp Extreme AT 325 60 18
mopar is offline   Reply With Quote
Old 10-03-2005, 05:48 PM   #5 (permalink)
RockyMtnTitan's Avatar
Ditto on soaking the bolts. I soaked mine overnight, and still had to hit them with my torch to get a couple of them to break loose. Couldn't believe how seized up they were, especially since the truck only had about 6K on it at the time.
Most of these kits are an easy install. I did mine myself in about 3 hrs, although my back was killing me for days afterwards. Definately use the buddy system if you decide to go the DIY route. If you find a good shop, they shouldn't charge you more than 1.5 - 2 hrs labor, including welding the joints...if you want them to.
Performance Mods:
Airaid TB Spacer
TB Coolant Shut-Off
Active Tuning Grounding Kit
Int/Ext Mods:
SE Pwr Mirror Upgrade
Factory Step Rails
17" OR Wheels
SE Sunvisors Upgrade
20% Window Tint
Old 10-03-2005, 05:53 PM   #6 (permalink)
lenj33's Avatar
Good advice!! Seeing as my back can be suspect at times and time is at a premium with my daughter, I'll let a shop do it.
Any advantages (other than the obvious strength and permanence) to welding the joints?
Len
Old 10-03-2005, 06:10 PM   #7 (permalink)
mopar's Avatar
I wouldn't weld it, the Borla clamps are excellent and this way you can take it off later if you need to. If you want to keep the stock exhaust say for a 07 trade in or something let the shop know my buddy had a shop cut the stock exhaust up and when he had to turn in his leased prelude type sh they charged him for the non stock exhaust he could have put the stocker back on and sold the performance exhaust so lessoned learned.
Sean
RLTW
Old 10-07-2005, 03:57 PM   #8 (permalink)
mopar's Avatar
You get it yet??
Sean
RLTW
Old 10-07-2005, 04:37 PM   #9 (permalink)
PHX_TITAN's Avatar
I just had mine installed last week by a local shop... absolutely amazing! I thought about the DIY route, but for $85 it was well worth having them do it. Everything went on easy; very well engineered. In any case, I just love my new exhaust, you just can't help but burn a little extra gas now and then reving the hell out of the engine... sweet sound.
Rob
2004 SE Crew Cab
- 4x2
- Big Tow
- A.R.E. Tonneau
- Borla Dual Exhaust
- Westin Nerf Bars
- SIRIUS Satellite Radio
PHX_TITAN is offline   Reply With Quote
Old 10-07-2005, 08:17 PM   #10 (permalink)
lenj33's Avatar
I got it... I keep pulling it out to look at it.. I'm going crazy without installing it!!!
I'm going to my buddies (pnuematic tools) house sunday to install the PRG levelling kit on the front... I think I may put the exhaust in the back and see how much energy he has
He's my good friend with the ram hemi i've been razzing pretty hard so he may tell me to go f*** myself
I love the way the tips look, very cool.
I'm not that crazy about how the drivers side pipe passes in front of the rear differential. I may get a custom pipe bent for me to take it up and over the axle it if turns out to be something that bothers me more than I think it will...
I can't wait to hear it!
Old 10-08-2005, 07:28 AM   #11 (permalink)
titan3spot's Avatar
lenj33...
As per another thread, I work with a guy that runs a truck shop here in Katy and he actually called nissan for me to see what their preference was on a leveling kit. They told him that they see future problems with installing the PRG as it is "metal" and that they would prefer something that uses polyeurathane. He would have loved to sell me PRG (metal) as it is pricier than Daystar (poly), but said that Nissan preferred Poly and he would get me one for $400 installed. He also mentioned that he had to get the springs compressed/uncompressed (not sure), to get it to be right.
hhhmmm
2004 White CC 4X2 SE
Functional Ram Air Hood, AEM Brute Force CAI, Banks Monster Exhaust, Hellwig Rear Sway Bar
OEM Gray Skid-Plate, OEM Gray Step Rails (free!), OEM Gray Bed Rails, OEM Gray Bed Extender
Rockford Fosgate, Tow Package, Extreme Bed Liner, Silverstar Low and High Beams, Rear Light Chrome Bezels, Chrome Gas Door, In-Channel Visors, White Front XE Grille
We don't stop playing because we grow old...we grow old because we stop playing.
titan3spot is offline   Reply With Quote
Old 10-08-2005, 07:41 AM   #12 (permalink)
lenj33's Avatar
I thought about the metal vs poly issues but figured the metal will be more durable and I plan on keeping this truck till it dies (a pattern with me) anyway so it's all good.
I wouldn't think you need to compress the springs for the install as they're coliovers and integrated in to the front shock assembly. Lifting my buddies jeep was an issue since the coil springs were seperate compnents from the shocks and when released were much longer than the shocks.
Old 10-08-2005, 02:58 PM   #13 (permalink)
how much you pay for the borla and from where?
peninsulatitan is offline   Reply With Quote
Old 10-08-2005, 11:29 PM   #14 (permalink)
lenj33's Avatar
I got it for 695.00 from greg at mossy.com
Old 10-09-2005, 07:04 AM   #15 (permalink)
QShip's Avatar
That's a great price!
2004 SE KC 4x4 Titan
B & B Exhaust
Volant CAI
Stillen S/C
Stillen Headers
TruTrak
IPT VB
IPT TC
Uprev ECU
QShip is offline   Reply With Quote
