A good possibility but no worse than any functional "hood scoop". I'm still brainstorming and researching an additional internal design on how to trap water without reducing the ram air benefit. I also think it is safer with less exposure to water and rain compared to an intake located below the bumper (Volant 2nd gen).
An additional info I've found: there is a 3% HP loss for every 20 degree F increase in ambient air temperature. So if this is prevented or better yet reversed so the air intake is 20 degrees cooler, a 278 HP Titan can (possibly) gain 8.34 horses instead of losing them. Is this math right? This does not take into account the positive pressure of the "ram" effect forced into the box (unmeasurable unless in motion).
This has a lite spring and will open from the weight of the water.
The arrow goes to the side your air box, ram air will keep it closed.
A small looped tube 3' long out the buttom will allow the water to drain.
Share the wealth of knowledge and go as fast as you can.
IRC Member "International Racers Club VK56"
TESTING: GTech/Pro RR, AutoTap, Auto Enginuity Enhanced, UpRev, Audio Spectrum Analyzer for Knock Sensors Monitoring, HP nx9420 Notebook PC T7700, Sprint Mobile Broadband
MODS: Custom PGM 90mm Throttle Body, Custom PGM Throttle Body Spacer, Custom Throttle Body Intercooler, Custom Ram Air, Custom 160 degrees Thermostat, Custom CAI, Nismo Headers, Custom B-Pipe NO Cats in line and NO Simulator without CODES (LOL), Custom MagnaFlow Exhaust, Custom Tune, Flex-a-Lite 27 Electric Puller Fan #295, Jim Wolf Technologies Camshafts, Detroit TruTrac LSD.
Looks good.. but when driving fast, utilizing your new mod, can you wash the bugs off the windshield so you can see? lol
Curious to know if you got the replacement washer resivoir done.
UPDATE:
I've found a "coolant reservoir" for $12 from R/S Strauss. I used this for the windshield washer reservoir after some minor fitting work. I removed the OE fittings from the OE windshield reservoir and using the original holes as templates, I perforated the "R/S reservoir" with the exact dimensions and relocating the pump and the fluid level sensor was very easy.
Now, I can see!!!! LOL
Here's some pics. I just have to find a way to make that "cheap red cover" look a bit presentable.
Is there any reason that the sealed box wouldn't work for a non-sealed intake such as AEM . k&N ..etc? I like the idea but already have an intake (AEM).
I don't think the OE box is large enough to accomodate the larger "cone filters". However, with creativity, anything is possible.
Remember, we are looking for frontal (grill area) air directly into a sealed air box for "ram air effect"
Dry ice is solid carbon dioxide. When it "melts" it goes directly back to its gaseous form CO2 gas. This is heavier than air and does not act like pure oxygen. In fact, CO2 gas is what is used in fire extinguishers. Also the heat of the engine and the dry ice sitting on you plastic intake box/ filter make it go snap! So in closing, you probably go slower and then your airbox would crack.
Sorry, I am a scientist and I have to geek out on occasion.
__________________ Oddly enough, my daughter just made this same face!!!
My Truck: Born April 17, 2004, Purchased June 3, 2004
LE Canteen Crew, 4X4, BT, OR to which I added: SS Brake Lines, Advanced Folding K-Cover ,SS Lund deflector, Black Prism DunderDan grill (I hope it's coming soon), 4" Prerunner Greg Performance Lift, The first Zoomers SS exhaust ever shipped, Volant Gen III CAI, and Chick's Hulk engine cover, custom A-pillar with 1in guages (coming soon).
As Money Allows: Nismo Headers, Dynatech 2.25" Powercats (Damn Missouri and your air quality) Osirus, Trutrac, Stillen (sway bar, big brakes, diff cover), and PrerunnerTraction Bars.
question: it looks like you fabricated an entirely new box. Could you have just used the volant box and cut a hole in the front with a tube to the hole you cut in the rad. support area?
Yes, I could have done that but there will be a little problem.
This project requires the removal/relocation of the "windshield washer fluid reservoir" and of course, it needs to be moved somewhere. By moving the custom box forward, a space is created behind it for the relocated reservoir. Besides, I wanted to use every available space for the custom box.
