Old 10-13-2005, 08:23 PM   #1 (permalink)
JWLV's Avatar
Banks install question
I just installed the Banks exhaust today. The tip is touching the body, is this going to be a problem?
JWLV is offline   Reply With Quote
Old 10-13-2005, 08:37 PM   #2 (permalink)
phillipyang's Avatar
Send a message via AIM to phillipyang
You mean the tip? That means your muffler isn't installed all the way inside the tube and its not at the correct angle. You should check it out again. I have about 4 inches from the top to muffler on the side. Installation was a breeze with the lift. lol
Nissan Titan LE 4x2 CC
Purchased: Feb 2004
Miles to date: 74,000 (Since Feb, 15 2004)
Mods: Banks Cat Back Exhaust System, K&N with arbox mod, Front Air Dam, Custom bed cover, AC/DC interior conversion, PSP/Ipod Dock
http://www.phillipyang.com
phillipyang is offline   Reply With Quote
Old 10-13-2005, 08:40 PM   #3 (permalink)
37L1's Avatar
It shouldn't be touching the body, do you have the hanger brackets on right? Sometimes the hanger bracket gets reversed on the install.
2004 Titan Smoke LE CC
Born 11/18/03
Bed Extender, Overhead Racks
-Gambit
STUPID IS AS STUPID DOES.
-Forrest Gump's Momma
Old 10-13-2005, 08:43 PM   #4 (permalink)
Yes sir that will become a prob. What I did on the banks was get everything hung left all clamps loose and then position everything till I got where I wanted it and then snuged it up hope that helps.
CraigG is offline   Reply With Quote
Old 10-13-2005, 10:21 PM   #5 (permalink)
JWLV's Avatar
I don't see any other way I could have hung the pipes and I don't see how the hanger bracket would reposition the tip, I guess I'll have to go through it again. If I can't find what is wrong, do you think I can put a spacer on the hanger bracket?
If I leave it this way until Sunday, you think I'll blow up or melt my truck?
Old 10-13-2005, 10:29 PM   #6 (permalink)
Vegas04's Avatar
Not a chance of melting your truck. the only danger is that the metal on metal contact will scratch the chrome tip and chip away the paint where it touches the truck.
Galaxy Black 2004 Titan XE CC 4x4 w/ Off-Road Package, Preferred Package.
Mods: PRG Spacers, 17x9" Eagle 187s (+2mm offset) w/ 315 70-17 BFG All-Terrain KO tires, Stillen Diff Cover, Alpine Type-R components in the front, coax. in the rear w/ 50 x 4 Rockford Fosgate Amp, XM, Debadged, and Homemade RCA pre-outs on in-dash changer.
Vegas04 is offline   Reply With Quote
Old 10-14-2005, 06:53 AM   #7 (permalink)
37L1's Avatar
Some people, when first installing the Banks had put the the rear hanger bracket backwards on the Banks supplied adapter plate. That might be what is causing your tip to be at the incorrect angle so that it touches your fender.
Right now I can fit my opened hand between my exhaust tip and the fender.
Born 11/18/03
-Gambit
Old 10-14-2005, 07:46 AM   #8 (permalink)
JWLV's Avatar
So the adaptor plate is supposed to go on the rear hanger?
Old 10-14-2005, 08:16 AM   #9 (permalink)
37L1's Avatar
sorry, my bad. What I meant was the plate goes on the middle hanger. egan installed his last and had to bend it. I don't recall having that problem with mine but it has been 17 months since I put mine on, so my memory isn't really for a recent install. I do remember catching myself and being careful about putting the adapter plate and hangar mount on right the first time.
Anyway here's a link to egan's install with photos so you can easily check his against your install.
http://www.egansworld.com/titan/banks2.html
Born 11/18/03
-Gambit
Old 10-14-2005, 10:39 AM   #10 (permalink)
I think egan did it wrong so I wouldn't follow his isntructions. (he didn't install middle bracket correctly if i rember right and bent everything to **** before he realized it.) Everything should go on right if you carefully follow the instructions. I overlooked one step (remove rear hanger) and it cost me about 1.5 hours of my life that i'm not getting back. Make sure you put the rear hanger on correctly, check the install of your tip and you should be fine....
If that doesn't work snap some pics from under the truck and I'll do my best. This SHOULD go on pretty easy if you follow all the steps and don't get anything going on backwards.
2005 CC 4x4 SE
AKA
Chunky Ass Whore
All Time Favorite TitanTalk Quote (in response to what type of Gasoline is best):
I personally prefer whatever's cheap. I'd club baby seals to death and squeeze oil from their limp little bodies if I could save a buck - Mr B
chunko is offline   Reply With Quote
Old 10-14-2005, 04:55 PM   #11 (permalink)
JWLV's Avatar
I'm thinking I may have put the hanger with the bracket on reversed. I'll check it out this weekend and see if it works. Thanks for all the help.
Old 10-18-2005, 03:20 PM   #12 (permalink)
baseballfanz's Avatar
I know a whole bunch of people just got the Banks system (over 30 with the two GB combined). Here's a close up picture of the front mount, it should go on top. In the picture the red arrow points to the back of the truck. The adaptor plate should go on the front most bracket not middle, the one that support the front section before the muffler.
Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
Old 10-18-2005, 04:52 PM   #13 (permalink)
Send a message via AIM to GreenT
Yep the hanger is supposed to go on top of the adapter plate. That guy is an idiot. A third grader could see the problem and a solution before bending the **** out of the plate. Banks does have an 800 number if he couldn't read simple instructions. Dont follow those instructions.
05 Deep Water Blue KC SE
Rockford pop package w/ buckets, Traction package, Utilitrac w/ bed extender, Banks exhuast, Volant V3
GreenT is offline   Reply With Quote
Old 10-19-2005, 03:57 AM   #14 (permalink)
buzzkillwill's Avatar
If the tip is touching, which mine did too on the dry fit, simply loosen the back half of the exhaust and give it a little twist, turn it slightly downward to get the tip away from the truck-it'll work. If you're not having issues anywhere else, then a simple adjustment should work.
Let us know how it goes....
SOLD**2004 SE CC Radiant Silver 4X4 w/ Pop. Pkg and DVD
MODS: Banks, AEM CAI, 2*, Helper Springs, TBS, Mobil 1 **SOLD
2005 Titan XE KC w/ Preferred Package BLACK
UPREV Generic tune~Injen Intake~Magnaflow muffler w/ 3" piping out~Mobil 1 Engine & Gear Oil~
1/4-14.44@95.77mph
buzzkillwill is offline   Reply With Quote
