lol, not too good with pigeon. howlie huh?, I don't recall playing any race cards on any internet site or in real life, very intresting!
I'm actually not complaining about having a big enough truck, this truck is as big as anyone could ever need. I want a truck that can put out as much as the Titan and HONESTLY an F150 or Tundra or Chevy can't do it imo. So that's why I want a bigger truck. Someone on here with a Titan AND F250 said 250 gets better milage. I've been wanting to do the bio diesel thing for kicks for a few months BEFORE I got the Titan. I always have to explain myself everytime someone asks wierd questions or whatnot... I filled my FRONTIER OVER THE ROOF with snow and never really considered the possibility that it may break . Love the truck hate the fact that they're saying it's a one time deal and the are still attempting to void my warranty if I ever bust the rear again or whatever. So, I'll talk about other trucks IF I ever need to relocate, YES it is getting THAT bad. Can I not even check about lifts for other trucks and pursue them and talk about it on here? lol, I just thought I'd add about the lift because I was happy when I checked out an F2... never again will I bring up anything of another "competitor"... walks away... lol .... walks back in :-P
here's the newest -> General Manager-(two weeks ago)-Two weeks your parts will be in...... "today" Service Consultant-you guys need to come in and sign some papers so we can order your rear end....
I called the GM after SC said that to see what he had to say. He was as supprised as me to hear that lol. So he'll be caling me back in the morning, we'll see if I get a loaner for the next two weeks, here we go again lol. so what were you saying? shipping here takes a while? you have no idea lol... I've spent too much energy on it... so I'm done talking about it for now.
In other news I GOT THAT PART NUMBER 913A582
913A582 I repeat 913A582 the owner of the 4x4 shop didn't even give it to me at 1st til I told him you guys were continental us. later
I am going to bite the bullet and get the true trac installed....should be next week,,,,
it will run $ 682.00 installed......but it will be nice to get rid of the one tire frier.......and have a major part that should not fail...also i get to make sure all the settings will be right,, that should make me sleep better,,,,,
DUDE, I'm paying 682 for the part alone LOL. cool beans congrats
So this only works with the 3.35 and not the 2.94? Or does it not matter what the gearing is. I was under the impression that this is independent of your gearing. I just want the limited slip......
__________________ Made by NISSAN, Built by Americans on May 4, 2004!
mine is for the lower gearing so that would mean 2.94 is a different one. Crap I should've specified. I've never heard of higher gears breaking, guess it's kool to have an LSD anyway...
It should work with either gearing...the shop i am having install this said his new catolog shows it fitting 04-05,,no notes on ratio restrictions,,,
Hey Guys!
Has anyone figured out what will happen with the installed ABLS on the 4X2 Titans? Will the brain interfere with the operation of the mechanical LSD?? Can the ABLS be defeated to prevent possible interferrence??
Any good info on this topic will be appreciated.
TIA,
Ralph
Ralph Featherstone
'05 Titan SE KC 4X2
Hey Guys!
TIA,
Ralph
Interesting question. ABLS + Tru-Trac might be ideal. In an ordinary Tru-Trac, with one wheel off the ground or on ice with zero traction, it will just continue to spin. For that reason, Tru-Trac users have developed a technique in which they feather the parking brake just enough to simulate a bit of traction on the spinning wheel. ABLS might take care of that automatically and make the combination the cat's meow.
I just feather the brake pedal, not the parking brake. Can't really feather the parking brake on the Titan. For offroading you need to learn to drive with both feet anyway.
The ECU won't even know you have the LSD, it will just think that your truck is hooking up, and not spinning one wheel...
PRG Performance Kit w/SAW's
Born 9/2004
Damn this forum! It's going to run me to the 'poor house'! If it wasn't for this forum I would be fat, dumb and happy until my rear blew (and then I'd lose my mind.) Because of this resource I just love my truck , in spite of it's shortcomings, and I have to go buy a tru-track! Once that's in then I'm sure an exhaust mod and tires are right around the corner...
__________________ Chris
05 Blizzard LE CC, 4x4, BT, OR, Nav, AB, Sunroof, XM, Ceramic Pads on new rotors & hardware (10.2k+miles,no brake issues to date and very clean wheels), AutoExtreme TBS, TB coolant bypass, Inverted helper springs, Hi-capacity diff cover, Active Tuning ground kit, poly swaybar bushings (front), Axle Vent Mod
Like I said before this is one mod i really want. What type of shop should I go and order from? I figured from above that a Jo-Blo repair shop is not the way to go.
I would make sure that they install Tru-Tracs on a regular basis and that the tech that will actually be doing the work is experienced. I would also inquire about the warranty and get it in writing.
If you look at the part called "flanged body" in the exploded drawing, you will note a circular array of holes extending around the periphery. That part replaces the existing carrier within your differential. The existing carrier is shown in the exploded drawing at the bottom of this page and labeled "case":
So what is going to occur in installation is that they will remove the existing carrier (or "case") including the associated spider gears and replace with the tru-trac, including the "flanged body" and helical gears.
The existing ring gear gets bolted to the circular array of holes extending around the "flanged body" of the tru-trac. The critical part is that the proper alignment of the ring and pinion are preserved after installation of the tru-trac.
