Old 10-22-2005, 10:11 AM   #1 (permalink)
brentburgess171's Avatar
Catalytic Converters required?
Has anyone gutted the catalytic converter on there Titan? I tried it on my previous ford and the results were amazing. WV doesn't require an emissions test for inpection. The only thing that concerns me are possible computer problems.
brentburgess171 is offline   Reply With Quote
Old 10-22-2005, 10:19 AM   #2 (permalink)
If you have a 4x2, you have 2 cats. If you have a 4x4, you have 4. People have removed 2 of the cats on the 4x4 with sucessful results (no codes). As for removing all, I'm not sure.
-Cyrus
Vyrus is offline   Reply With Quote
Old 10-22-2005, 10:23 AM   #3 (permalink)
Send a message via AIM to GreenT
You could do it but you will get an SES light. You would need to use 02 simms to trick the ECU into thinking the 02 sensors are getting the correct after cat readings.
05 Deep Water Blue KC SE
Rockford pop package w/ buckets, Traction package, Utilitrac w/ bed extender, Banks exhuast, Volant V3
GreenT is offline   Reply With Quote
Old 10-22-2005, 10:23 AM   #4 (permalink)
Which two did they remove? Thanks for the info.
Old 10-22-2005, 10:29 AM   #5 (permalink)
What are 02 simms and where do I get them?
Old 10-22-2005, 10:35 AM   #6 (permalink)
I believed they removed the downstream cats (the later ones) which do not have O2 sensors. Maybe I'm mistaken though, searching should reveal a few threads about people who have done this. Most of them replace with resonators.
O2 simulators are an electronic device which sends a signal to the ECU where your O2 sensor would have been. They are pricey, but you can pick them up on Summit Racing or Jegs or any other performance shop.
-Cyrus
Old 10-22-2005, 10:54 AM   #7 (permalink)
-Cyrus
Old 10-22-2005, 10:58 AM   #8 (permalink)
02 simms shouldn't be that expensive. About $25 a piece or so.
Old 10-22-2005, 02:28 PM   #9 (permalink)
gr8titan's Avatar
Remove the "downstream secondary" or rear-cats on a 4x4. No ECU problems. I've replaced them with "straight thru resonators" and no regrets. Click on my links below my SIG for install/fabrication pics.
gr8titan is offline   Reply With Quote
Old 10-22-2005, 02:50 PM   #10 (permalink)
Why not gut the factory cats and reinstall the empty chamber?
Old 10-22-2005, 07:54 PM   #11 (permalink)
QShip's Avatar
He suggested that in one of his earlier threads about his exhaust.
2004 SE KC 4x4 Titan
B & B Exhaust
Volant CAI
Stillen S/C
Stillen Headers
TruTrak
IPT VB
IPT TC
Uprev ECU
QShip is offline   Reply With Quote
Old 10-22-2005, 09:39 PM   #12 (permalink)
its hard to say on the o2 sims. when I got some for my civic they were about 100 bucks and still threw codes so its a hit and miss kind of thing
motoman139 is offline   Reply With Quote
