how come the brake lmited slip (ABLS) didnt kick in in this vid??? my only guess is that maybe his didnt have it. I wonder how the burnout would have gone if his truck had it (ABLS)??
Thats my truck... its a 2004 4x2 LE no OR or BT... does it suppose to have ABLS???
HA, one more reason I couldn't of been burning rubber when my rear end went LOL. I TOLD THEM I WASN'T. farkin tards I swear. I suppose I could've found this "mod" and unplugged the thing or something. SO, you have to have the car running when you unplug it? Don't newer cars/trucks not start unless in park? and you have to put it in gear or neutral to do this? not that I want to do that since I'm voiding my warranty apparently before doing anything like this idiot dealership I swear. Can't wait to argue that fact LOL.
05 xe 4x4
Go: aFe stg2, TBS, TB coolant bypass, flowmaster Y pipe w/borla pro XS muffler, BD PP, DT LT headers
Ext: 2.5" leveling kit, Fabtech add-a-leaf, PRG UCAs, SAW Piggybacks in rear 3" body lift, 35x12.5 toyo MTs on 20x9" +18mm offset ultrawheels titan 6 black, ventshades, headlight covers, 5% tint all around and n-fab steps, PRG traction bars
Int: wet okole seat covers front and back, custom 7" screen cut into last fold down pocket of over head console. active 3 way front stage 8" Peerless SLS woofers in doors, 4" xtant XSC/morel mids at a-pillars in glass pods (gloss black painted) and (Blau VC100 rainbow cal25 based) tweets run off an audio art 260.6xe, preamped via arc audio eq
substage always chaging, single Storm neo/neo 3hp motor'd 10" with FI soft parts in 2.5cubes ported after displacements 6" PSP port tuned to about 38hz.
Well that's not entirely true, not all Titans have the ABLS, mine doesn't.
How do you tell which ones do have it? I know mine does, it will barely spin a wheel even with VDC switched off.
I dissconnected the switch at the brake pedal....here comes the smoke!
PRG Performance Kit w/SAW's
Born 9/2004
Cut my wires at the lower brake pedal switch. My wire looked Red w/Brn, it may have been Red w/Grn, but it was hard to tell under there.
I mounted my toggle switch under the LH dash behind the hood latch handle. There is a good flat piece of plastic behind there that is out-of-site, but easy to reach.
I noticed that if I left the switch in the burnout position and drove around, the "slip" light came on and stayed on until I turned the key off and back on with the toggle switch in the "normal" position. Switching back to normal before driving kept the "slip" light from coming on.
As far as the burnout, I'm going to try to take some video later this week.....smoke-city!
Very cool mod ! I’m going to give it a try but for a different reason than burnouts. I have 4 wheel ALBS on mine which seems to be ok if your moving at a clip (above 5-6mph). It leaves a lot to be desired when trying to get things rolling. My old Trooper has pulled itself from a slippery dead stop with a medium amount of brake pedal and a healthy dose of throttle many times. The power application and the ABS seem to work as a pseudo ALBS but from a much lower speed. I’ve tried this in the Titan but it doesn’t seem to interested in co-operating and if you can’t get it moving the real ALBS can’t work.
__________________ Chris
05 Blizzard LE CC, 4x4, BT, OR, Nav, AB, Sunroof, XM, Ceramic Pads on new rotors & hardware (10.2k+miles,no brake issues to date and very clean wheels), AutoExtreme TBS, TB coolant bypass, Inverted helper springs, Hi-capacity diff cover, Active Tuning ground kit, poly swaybar bushings (front), Axle Vent Mod
Here is what it deos for you.
Here is a vid with the mod.
INSANE!!!!! http://www . club titan . org/postt8667.html
Of course you have to copy and paste the link and take out the spaces.
Just a correction....the wire you speak of coming directly off the lower brake switch is a R/G not R/W, for anyone wanting to break the circuit there, instead of at the ecm....which is where the R/W wire is located.
And to give credit where it is due...Mossy Chris is the one who "elightened" us Titan owners to this mod, and Tom and Slurppie took it to the next level, if you will.
For the life of me I don't see any green in this wire. It looks red/black. I think this is the one but can you tell from the pic I'll post?
05 2x4 KC SE
Prefered pack
Big Tow
Bed Package
20% tint
Borla cat back Exhaust and AEM
Fog lights
Billet 4pc Grill[/i]
Grounding Mod
"I got a fever...and the only prescription is MORE COWBELL!"
If you look at the pic I've attached (thanks scr38), you'll see diagrams for both switches. The one on the left is for the lower brake switch. It shows a R/Y and a R/G. The R/G, which usually means red w/ green tracer, is the one you want. From your pic, I can see the R/Y, but can't make out the other one. I haven't looked at these myself, as I cut the R/W wire at the ecm, plus I have a column shifter, so I have 4 wires on that switch. Shouldn't matter, as the R/G wire should be common on either type of shifter.
The upper switch does have a R/B (red w/ black tracer), are you for sure looking at the lower switch?
Performance Mods:
Airaid TB Spacer
TB Coolant Shut-Off
Active Tuning Grounding Kit Int/Ext Mods:
SE Pwr Mirror Upgrade
Factory Step Rails
17" OR Wheels
SE Sunvisors Upgrade
20% Window Tint
The black plug is the one I am looking at. It is the one closer to the floor. I'm pretty sure it's that wire but I sure don't see any green in that stripe.
05 2x4 KC SE
Prefered pack
Big Tow
Bed Package
20% tint
Fog lights
Grounding Mod
Looked at mine, red with yellow stripe and red with green stripe.
2004 Titan Smoke LE CC
Born 11/18/03
-Gambit
The wire at the switch is red/green. It runs to the BCM. Between the BCM and the switch there is a red/white wire connected to the red/green wire. This red/white wire runs to the ECU. It is better to put the switch in the red/white wire. If you install the switch in the red/green wire near the brake switch it will also disable the brake lights when turned off. This is why you get a brake warning light.
It is easier to find the red/white wire in the harness that plugs into the ECU, under the hood. With the switch in that wire you won't disable the brake lights.
Attached is a drawing of the harness plug where the red/white wire is located. It is pin 101, in red on the drawing.
