Old 11-08-2005, 10:57 AM   #1 (permalink)
t22a80's Avatar
Send a message via AIM to t22a80
Wake Up!
Hey guys,
I had an 04 and I traded it in for an 05 because of all the problems i was having with it. I like the 05 much better, they fixed a lot of the annoying quirks that the first model year had. One thing I did notice was that the 05 doesn't seem as quick as the 04 did. It almost seems doggy and slow. Has anyone else noticed this w/ the 05. I know not everyone probably drove both back to back like I did. I was just wondering if you guys knew anything I didn't.
Got any low cost suggestions that could help me "wake this one up"
Thanks!
Chad
t22a80 is offline   Reply With Quote
Old 11-08-2005, 10:59 AM   #2 (permalink)
Sammy Sandbag's Avatar
You might want to try reseting your ECM along with the other adjustments: http://www.titantalk.com/forums/show...23&postcount=1
-Counsel Yourself
Old 11-08-2005, 11:19 AM   #3 (permalink)
Banned
TitanFan59's Avatar
I think it might just be the truck. I drove a lingering 04 before the 05 I purchased and it was the exact opposite for me. I think it just falls into the realm of they are not all alike but as Sammy said an ECU reset could be the fix. When I bounced on the throttle of the 04 it was lagging and jerky (actually felt like a tundra), when I did the same to the 05 it snapped the neck with every depression.
TitanFan59 is offline   Reply With Quote
Old 11-08-2005, 11:50 AM   #4 (permalink)
t22a80's Avatar
Thats why I'm curious if something needs to be adjusted/reset like mentioned. This one will bog down on the hills where the other one felt more powerful, or would at least shift down and power up. I will try the reset and see if this helps. I like this procedure because I don't need to disconnect the battery.
Any other suggestions?
Thanks again!
Old 11-08-2005, 12:55 PM   #5 (permalink)
Well the 04 means you only have to push the pedal 4 inches. You are just used to only having to push that pedal. But the 05 you need to push a little further. You still have another inch to go. Try pushing another inch or so and call me in the morning!
Old 11-08-2005, 01:27 PM   #6 (permalink)
1bigtexastitan's Avatar
Originally Posted by t22a80
Hey guys,
Thanks!
Chad
Did you trade it in for a new or used one? If it was used, maybe it's been around the track, if you know what I mean.
2005 Galaxy Crew Cab SE 4x4 With Big Tow, Rockford Fosgate, Utilitrack System
Mods:
De-Badged
35% Front Tint
Sylvania Silverstars All Around
OEM Foglight Kit
Active Tuning Ground Kit
OEM Rubber Mats
Magnaflow True Dual Custom Exhaust with X-Pipe
1bigtexastitan is offline   Reply With Quote
Old 11-08-2005, 01:30 PM   #7 (permalink)
t22a80's Avatar
umm ok. I'll remember that.
One thing I have noticed is that somedays it seems to run better than others. I haven't noticed a trend with temperatures or humidity but it does feel different sometimes.
Old 11-08-2005, 03:29 PM   #8 (permalink)
nytitan1's Avatar
i noticed same thing with mine the 04 seemed to be a little quicker too, 05 not nearly as fast out of box, then again fast enuff for me i guess my 04 blew engine.
nytitan1 is offline   Reply With Quote
Old 11-08-2005, 03:43 PM   #9 (permalink)
tillery444's Avatar
Hey guys,
Thanks!
Chad
It's well known that 04's are faster then 05's and 6's, especially glxy blk,CC,4x4's!
Glxy Blk, XE/CC/4x4
Magnaflow Exaust
AirRaid Intake
DR Coilovers
PC traction bars & lift
BFG 315/70/17 T/A KO's
PC Extream Alloy 1089 stealth black, 17-9 wheels
[/img]
-[/img]
It's better to have it and not need it, Than need it and not have it!"
tillery444 is offline   Reply With Quote
Old 11-09-2005, 05:20 AM   #10 (permalink)
t22a80's Avatar
HAHA. I'm sure thats true, especially with those tires!
It bums me out that it is noticeable. If i didn't have the 04 before then I'd think that the 05 was plenty powerful but now that I know its potential I for some reason feel this need for it. haha. I guess its just time to start saving my pennies for some mods.
Old 11-09-2005, 05:38 AM   #11 (permalink)
I would tend to bet that it will improve after break in period and you put your first synthetic oil change in.
Old 11-09-2005, 09:58 AM   #12 (permalink)
t22a80's Avatar
I'm at 4k+ miles. Its had its first oil change. It does seem a little better but still not the same. I'm not that worried about it. Just curious for some info.
Thanks everyone.
Old 11-09-2005, 11:10 AM   #13 (permalink)
One of the complaints of the '04 was that there was way too much throttle tip-in. You could barely touch the gas pedal and the truck accelerated too quickly. This had less to do with the horsepower of the truck but more to do with how the drive-by-wire computer was programmed. Nissan may have cut back on the amount of throttle tip-in on the '05.
BayouTitan
4X2 SE Radiant Silver
Popular Package
Utility Bed Package
Born on 12/03
Old 11-09-2005, 11:13 AM   #14 (permalink)
Originally Posted by Bayou Titan
One of the complaints of the '04 was that there was way too much throttle tip-in. You could barely touch the gas pedal and the and truck accelerated too quickly. This had little to do with the horsepower of the truck but more to do with how the drive-by-wire computer was programmed. Nissan may have cut back on the amount of throttle tip-in on the '05.
Wow great point "Bayou" ! That is great how you can make a true statement out of the dumb'est thing I think I have said on this forum! You are a true asset to this site!!!
Old 11-09-2005, 11:49 AM   #15 (permalink)
on a side note...
NICE AVATAR TILLERY!!!
SOLD**2004 SE CC Radiant Silver 4X4 w/ Pop. Pkg and DVD
**SOLD
SOLD **2005 Titan XE KC w/ Preferred Package BLACK **SOLD
2004 Chevy RCSB 5.3/3.42gears/Auto/Whately Tune/ Intake/Exhaust 15.0 @92MPH
buzzkillwill is offline   Reply With Quote
