I got an extra of JBA LT's for a great price but the 02 threads are completely striped. I need to tap them!!
Any one know off hand what the thread size I need to tap are for the 02 sensors?
If the threads in the headers are stripped then there may not be enough material to hold the sensor once you've cleaned up (or re-tapped) the threads. A new bung may be required.
Sounds like a pain in the ***. To cut out, find, and re weld a bung. I guess I could use a high temp loc tight with risking of not being able to replace that sensor...
