Old 12-06-2005, 07:31 AM   #1 (permalink)
Arb Locker For 35 Spline Dana 44
http://www.4wheeloffroad.com/techarticles/131_0406_spl/
Anybody know anything about ARB's? This is for a modified DANA 44 with 35 spline axles which appear to be the same dimensions as the Titan's axles. Maybe the ring gear diameter & bolt pattern is different? It looks like they are part of the way to having a locker for the Titan. Anybody know anything from ARB?
Old 12-06-2005, 10:10 AM   #2 (permalink)
ptgarcia's Avatar
Re: Arb Locker For 35 Spline Dana 44
ARB makes top shelf equipment. Their lockers and bumpers are cherry ****. They come out of Australia and demand a hefty price, but if you have the money its worth it.
As far as the Titan goes, don't we have 32-spline axles?
Pauly
Old 12-06-2005, 10:56 AM   #3 (permalink)
Sammy Sandbag's Avatar
ARB is definately nice stuff, but there are a few downsides. It's air actuated, so that requires a pump and air line plumbing. If you have a leak and lose pressure, or the pump dies, then you're out of luck. They also require you to drill and tap the case and bearing cap for the air lines to run. They work well, but have been know to become inop from small particles in the diff oil. Petersen's 4 Wheel and Offroad's Ultimate Adventure K10 had an ARB that broke on the trail because of slightly too much sealant used on the differential cover. And they're expensive.
Tractech (now owned by Eaton) makes a Detroit Electrac which is a TrueTrac LSD and a e-lock all in one. I know they have it for standard D44 applications, and would be nice if they came out with it for the Titan.
-Counsel Yourself
2009 Blizzard Pro-4X
Old 12-08-2005, 10:03 AM   #4 (permalink)
The Detroit Electrac is garbage, there have been numerous failures since it's release.
If you want a selectable locker go with an ARB or an Eaton E-Locker. The Eaton is a much better product than the Detroit Electrac.
If you want a selectable locker for the Titan though, I would say the factory unit is the only way to go.
04 Smoke Titan CC LE on 20's
redrock4x4 is offline   Reply With Quote
Old 12-08-2005, 10:08 AM   #5 (permalink)
That's too bad, it had potential. That's the first I've heard of any problems, well the first I head of any useage actually. Last time I had read up on it, it was just being released. I'm suprised it's not doing well since Eaton now owns Tractech, you would think it'd use the same technology as the Eaton e-lockers. Of course no one has mentioned the OX cable locker. I haven't heard much in the way of field reports though.
-Counsel Yourself
Old 12-08-2005, 10:13 AM   #6 (permalink)
The Eaton is completely different, much better piece of equipment. Both lockers were on the market long before the companies had merged. I wouldn't be surprised of they drop the Electrac alltogether and focus on producing more of the Eaton E-Lockers.
In regards to Ox, I'd recommend an E-Locker much sooner than that piece of junk. I had 2 Ox lockers in my Jeep, they never worked right from day one, and eventually they blew up. They're now in the garbage in a bunch of tiny pieces. Ox offered no support, and the company basically disappeared off the radar for 2 years to avoid the numerous warranty claims they had.
Now the company is running again under new ownership. The product may be a bit better now, but the company is just too shady to deal with.
FWIW, I now have 2 ARB's in my Jeep and I couldn't be more pleased.
Old 12-08-2005, 10:32 AM   #7 (permalink)
ARB hands down. I installed front and rear in my Land Cruiser. My dad has it now and still works great. BTW, "I" meaning me installed them both, no special tools and the only hole I had to drill was through the diff housing. I ONLY took the vehicle in to have the front spacing checked (you should have special tools) after 50+k miles I guess I got the rear pretty close
Yomama -
2005 4x4 Canteen Crewcab SE with BT, OR, Utiltrak and Popular Package.
Ziebart rust proofing
A.R.E. Z series topper
Myron and Davis DVD for the kiddies, DDX7015 for me Kenwood amp and lightning amp on 8" polk sub. Audiovox remote starter (with satellite link)
Zoomers (No Drone) exhaust
AEM intake
Stillen Headers
2002 Hyundai Santa FE (The wifes)
2001 Polaris 700 Twin ATV
1996 28' Bayliner Cierra Sun
http://www.yomama.net
Yomama is offline   Reply With Quote
Old 12-08-2005, 10:42 AM   #8 (permalink)
Austin's Avatar
Mmmmm... ARB.... When I set up the order for my Dana 60, I spec'd it with an ARB. They're the bee's knees.
ARB:
Titan:
MY04 SE King Cab 4X4 SOLD!
Old 12-08-2005, 10:49 AM   #9 (permalink)
Austin, is that Titan cross pin bent or is that just an optical illusion?
-Counsel Yourself
Old 12-08-2005, 11:03 AM   #10 (permalink)
Austin's Avatar
Nope, straight as an arrow.
Old 12-08-2005, 11:07 AM   #11 (permalink)
Austin's Avatar
Yes, we do. Beefier than a normal 44.
Old 12-08-2005, 11:22 AM   #12 (permalink)
Sorry, I ment the pinion shaft (aka cross shaft, aka axle shaft, etc.)
-Counsel Yourself
Old 12-08-2005, 02:27 PM   #13 (permalink)
scr38's Avatar
Those machined ARB side gears sure look better than the Titan's powdered metal ones.
Old 12-08-2005, 10:37 PM   #14 (permalink)
Austin's Avatar
Hmmm... I really don't think so, but you're right - it does look a curved in that pic. I'll check and get back to ya tomorrow.
Titan Dana axle article Smoke05 Titan Engine, Transmission & Drivetrain 0 11-21-2005 06:34 PM
Dana 60 Rear End Conversion! Armada Titan Performance Modifications 8 04-29-2005 03:44 PM
Detroit Locker, ARB air locker, Easton e-locker pluckyew Titan General Discussion 43 11-29-2004 04:53 PM
E-locker? CI338 Titan General Discussion 3 02-20-2004 05:28 AM
Dana Axles in Titan outahere Titan General Discussion 1 02-13-2004 11:04 AM
