Old 12-21-2005, 06:35 PM   #16 (permalink)
gr8titan's Avatar
Re: Double solution VS Axle-wrap
Originally Posted by CJ3FLYR
Doh! I squeezed, wrestled and used a strap to winch the frame towards the axle. I agree about the rear spring helping considerably, the roller contacts the helper spring and really resists allowing the axle to twist. I didn't find the front ones on ebay. What did you type in the search? Thanks
Check post #4 above by bestatchess. There's a link to the retailer.
The "traction spring" was the only item of it's kind when I found it on eBay but you should be able to purchase it from the above link.
gr8titan is offline   Reply With Quote
Old 12-22-2005, 03:19 AM   #17 (permalink)
CJ3FLYR's Avatar
Originally Posted by pi3yeargrad
yes sir...Im getting confused with the 3 names being used here still...the JT solution (JT spring)...helper spring, and the red spring...
Any reference to JT is crediting a guy named JetTech for figuring out that our Titans would benefit tremendously from the addition of a generic helper springs that are readily avail at any parts place. So JT...(solution/spring) = Generic Overload Helper leaf style spring. His initial install had the helper in front of the axle and on the bottom side of the factory leaf spring. The thing we're reading about here is taking the same type of generic helper he used, putting it behind the axle and on top of the spring. And putting this 'newly discovered', red, anti-axle wrap spring in front of the axle (on the top side of the factory leaf). I think the red anti-axle wrap springs have only been avail in the last 9+/- months. They are comparatively new or new to me/us anyways.
Does that clear it up, I'm tryin'
Chris
05 Blizzard LE CC, 4x4, BT, OR, Nav, AB, Sunroof, XM, Ceramic Pads on new rotors & hardware (10.2k+miles,no brake issues to date and very clean wheels), AutoExtreme TBS, TB coolant bypass, Inverted helper springs, Hi-capacity diff cover, Active Tuning ground kit, poly swaybar bushings (front), Axle Vent Mod
CJ3FLYR is offline   Reply With Quote
Old 12-22-2005, 11:35 AM   #18 (permalink)
gr8titan's Avatar
Thanks for the help CJ3.
Old 12-22-2005, 02:05 PM   #19 (permalink)
FlimFlamMan's Avatar
Thanks for the post. Good stuff.
Question. Have you had any squeeking/creaking noises since installing these springs that way?
Thanks,
Flim
2007 WRX TR (5 speed)
Stage I
The Titan will be missed....
2005 XE CC 4x2
QX56 OEM Wheels
Uprev Tuned
Old 12-22-2005, 03:27 PM   #20 (permalink)
gr8titan's Avatar
Question. Have you had any squeeking/creaking noises since installing these springs that way? Thanks, Flim
So far, No squeeking/creaking noises from the leaf spring/suspension assembly. I am very satisfied with the elimination of that split second "sinking feeling" on the bottom of the seat when I step on the accelerator. Now, all I feel is being pushed to the back of the seat everytime I step on the pedal.
Old 12-22-2005, 03:41 PM   #21 (permalink)
I think this is what we are all talking about:
Front spring kit:
http://www.jcwhitney.com/autoparts/I...D:100000276701
Rear Spring kit:
http://www.partsamerica.com/ProductD...rtnumber=18921
Bryan
Silver 05 SE 4x4 KC OR BT
PRG Leveling Kit
Bilstein's in the rear
Volant SS Exhaust
AFE CAI
Billett Grille
Nissan All-Weather mats
15% tint on the front
techracer is offline   Reply With Quote
Old 12-22-2005, 06:17 PM   #22 (permalink)
gr8titan's Avatar
Heres a couple of drawings that may explain further the way these springs will control axle wrap. I tried to use red for the traction spring and black for the "JT" spring for some distinction. Hope this helps
double-solution-vs-axle-wrap-axle-wrap.jpg  double-solution-vs-axle-wrap-axle-wrap-spring-install.jpg
Old 12-27-2005, 09:56 AM   #23 (permalink)
I don't have anydoubts that how you've done your setup works but just a question.
Don't you think the red bar would be better served on the bottom? From looking at the leverage points it appears it would work better on the bottom and the JT bars on the top.
Bryan
PRG Leveling Kit
Volant SS Exhaust
AFE CAI
Billett Grille
Old 12-27-2005, 10:09 AM   #24 (permalink)
pi3yeargrad's Avatar
thanks guys the explanations and pictures clear things up...
...there u old geezers...now STOP COMPLAINING!
pi3yeargrad is offline   Reply With Quote
Old 12-27-2005, 02:58 PM   #25 (permalink)
gr8titan's Avatar
I don't have any doubts that how you've done your setup works but just a question.
The "red bar" is unsuitable for bottom installation because it is used to "reinforce the front half of the leaf spring from flexing upwards during hard acceleration. The downward "hump" of the "red bar" is specific to counter-act that "flexing" of the spring but will not affect regular compression of the spring when there is no aggressive acceleration.
However, you must be thinking of a "ladder bar" or similar (pardon my illustration below. It's a side by side comparison with the "red spring" mod) where it (ladder bar) is securely mounted on the axle housing (or parts thereof) to prevent the axle itself from twisting during aggressive acceleration. Additionally, the leverage point you may be referring to is the location where the other end of the "ladder bar" is anchored in one way or another to the frame of the vehicle. This is the ideal and not so inexpensive way to control axle wrap.
Hope this helps.
double-solution-vs-axle-wrap-ladder-bar-install.jpg  double-solution-vs-axle-wrap-axle-wrap.jpg
Old 12-27-2005, 03:06 PM   #26 (permalink)
MuskyHunter's Avatar
What is the purpose of the rubber roller on the rear spring anyway?
2007 Titan King Cab LE 4x4 : Big Tow: Arctic White : Graphite Leather : Painted Armada Air Dam : Truxedo LowPro Tonneau : Utilitrack Bed Divider : Underseat Storage
www.secretlake.net
Old 12-27-2005, 03:27 PM   #27 (permalink)
gr8titan's Avatar
I cannot think of any suitable relevance of this rubber roller except that it "cushions" the leaf spring from "hyper-extending" during off-road excursions where one side of the rear hangs (hyper-extends) and the other side is hyper-compressed. Any other ideas out there?
When utilized in the axle wrap mod, it helps control the "downward flex movement" of the rear half of the leaf spring when it is directly supported by the "JT" spring.
Old 12-27-2005, 03:44 PM   #28 (permalink)
Hope this helps.
I think you have your axle turning the wrong direction. For ever action there is an equal and opposite reaction.
PRG 2" front lift. 1" rear drop shackles
Wet Okole Front seat covers
Herbpov is offline   Reply With Quote
Old 12-27-2005, 04:43 PM   #29 (permalink)
gr8titan's Avatar
The illustration is correct. We just have to distinguish which one we're talking about. The axle turns towards the front while the axle housing turns opposite towards the back during forward acceleration.
But you're absolutely right with the Physics theory: for every action, there is an equal and opposite reaction. You've just inter-changed the two counter-acting forces: axle rotation vs axle housing rotation.
And we are talking about axle housing direction (which is attached to the leaf spring) during "axle wrap" in forward vehicle movement. PEACE
Old 12-27-2005, 05:31 PM   #30 (permalink)
In the drawings that you made, you have the truck going in reverse. Should be axle turning counterclockwise and axle housing and spring force is clockwise. That's looking at the truck from the driver's side.
