Old 12-27-2005, 06:26 PM   #31 (permalink)
gr8titan's Avatar
Re: Double solution VS Axle-wrap
Originally Posted by Herbpov
In the drawings that you made, you have the truck going in reverse. Should be axle turning counterclockwise and axle housing and spring force is clockwise. That's looking at the truck from the driver's side.
Correct. We are looking at the truck from the driver's side. However, the truck is not going in reverse. It is only the axle housing that appears to be going in reverse which is opposite to the forward motion of the axle. The directional arrows (shown in the drawings and the photo above) of axle and leaf spring movements are in opposite reaction to the axle movement which is to go forward. Like you stated, there are two (2) opposing motions involved. I agree 100%. There's the (1) axle direction which is forward and the (2) axle housing direction which rear-ward, both of which are "trying" to counter-act one another. In this topic, we are talking about direction axle housing movement. When this axle housing twists backwards (as a counter-reaction to the forward twisting of the axle), the front half of the leaf spring will bend upwards or lifts away from the ground. Simultaneously, during this moment, the rear half of the leaf spring will bend towards the ground creating an "S shape" leaf spring. Proof of this is when you watch a car launch at the track, it would initially "squat" wherein the rear of the car tries to bottom out. Again this is as a counter-force to the forward motion of the driving axle. But once the vehicle motion (inertia) is initiated, the car will level out.
When the wheels turn to move the vehicle forward, the axles turn the same direction as the wheels which is towards the front. From the point of view of the drawings, the wheels and the axle turn counterclockwise. Using the theory of "action-counter reaction", the axle housing MUST turn opposite towards the back which is from the same point of view (driver's side), it must turn clockwise.
Now, If we view the truck from the passenger side (not drawn), the axle rotation when the vehicle is in forward motion is clockwise. The axle housing then MUST move counterclockwise to counteract this axle movement.
I hope this clarifies your concept of axle vs axle housing directional twisting.
Check out the toys in my garage
Appearance Mods: chrome tailgate handle & tailight sorround, Westin T-304 SS Bull Bar, T-304 SS hitch/ball
raised racks, bed extender, nerf bars, Armada roof rack,
Tires/Wheels, Susp/Brake Mods: 305/50R-20 Nittos on MB Express 20x9, Hellwig Traction Springs,
Cross drilled & slotted 14 inch STILLEN big brake kit, red powder coated dual piston calipers
Rear Differential Mod: '05 OEM aluminum rear diff cover with Nissan Synthetic gear oil
Intake/Exhaust Mod: Hybrid Volant tube with heat shield and Custom RAM air box via front grille
2.5" T-304 SS Ractive X-pipe True Dual Rear-cat delete with custom T-304 bullet reso sections
Bragging Rights: Dyno: 293.61HP & 347.3ft-lbs/ New ET:14.800@92.62 0-60ft:2.075 R/T .081
gr8titan is offline   Reply With Quote
Old 12-27-2005, 06:30 PM   #32 (permalink)
I thought your arrows indicated the axle rotation. I see now that the arrows indicate axle housing rotation.
PRG 2" front lift. 1" rear drop shackles
Wet Okole Front seat covers
Herbpov is offline   Reply With Quote
Old 12-27-2005, 06:40 PM   #33 (permalink)
gr8titan's Avatar
Correct. Because when we talk about axle wrap, it is the unwanted axle housing twisting and it's direct effect to the leaf spring and drive-train angles that we are trying to control not the axle itself.
I'm glad to clear things out. PEACE!
BTW, you still have those lowering shackles available?
Old 12-27-2005, 07:09 PM   #34 (permalink)
got_titan's Avatar
all i need now is someone to translate all this to english...lol...lol
04 cc 4x4 w/big tow...........silver
volant cold air , oem sirius tuner, Zoomers exhaust, wade in channel visors, chrome tailgate piece ,05 finned diff cover,leather console lid, tailgate torsion bar,22 inch akuzu bounce, 305/45/22 nitto 420 extremes, mccullough hid's,05 active headrests , truxedo low profile,stillen front sway bar, painted lund interceptor, cr lawrence rear power slider,armada painted front spoiler, dr coilovers, t rex vertical billet grill, zoomers exhaust, prg traction bars, brake pros monster brake kit, prothane front swaybar bushings, volant vuelights(led), odyssey deep cycle battery, trutrac on order.....(INSTALLED)
STILLEN SUPERCHARGED 425rwhp 431rwtq (before headers)
Old 12-27-2005, 07:26 PM   #35 (permalink)
gr8titan's Avatar
A picture translates a thousand words. Posts 22 & 25. LOL
Old 12-27-2005, 07:36 PM   #36 (permalink)
No shackles.
Old 12-31-2005, 09:02 AM   #37 (permalink)
Doesn't this limit how well the suspension works (aka restricts travel/makes travel more difficult)
2005 CC 4x4 SE
AKA
Chunky Ass Whore
All Time Favorite TitanTalk Quote (in response to what type of Gasoline is best):
I personally prefer whatever's cheap. I'd club baby seals to death and squeeze oil from their limp little bodies if I could save a buck - Mr B
chunko is online now   Reply With Quote
Old 12-31-2005, 10:57 AM   #38 (permalink)
anyone notice if this is a 2wd vs 4wd problem? I've got an 05 KC 4x4 w/ offroad and BT and haven't noticed it being "that" bad, it does happen but doesn't seem like it is horrible.
Bryan
Silver 05 SE 4x4 KC OR BT
PRG Leveling Kit
Bilstein's in the rear
Volant SS Exhaust
AFE CAI
Billett Grille
Nissan All-Weather mats
15% tint on the front
techracer is offline   Reply With Quote
Old 12-31-2005, 02:53 PM   #39 (permalink)
Send a message via AIM to Batman229
http://cgi.ebay.com/ebaymotors/Spect...ayphotohosting
What the hell are these?
'05 Red Alert King Cab SE
4x4 w/Off Road Package
Prg 2+1
Line-X Bed
Throttle Body Spacer & Grounding KIt
Flowmaster Super 40 w/Dual Pipes
Batman229 is offline   Reply With Quote
Old 01-01-2006, 05:37 AM   #40 (permalink)
gr8titan's Avatar
Originally Posted by Batman229
They are also traction bars or sometimes called "anti-hop" bars for axle over spring vehicles (AOS). The 60s-70s era muscle cars owners loved to use them for increased traction for the street and strip. They are normally installed below the leaf spring with the rubber bumper towards the front of the vehicle.
They will not work for the Titan because the axle is located below the spring (SOA).
Old 01-01-2006, 05:49 AM   #41 (permalink)
gr8titan's Avatar
I did not notice any impairment of the vertical movement (travel) of the suspension. The ride quality is still basically the same but the "bounciness" when I hit small bumps is markedly improved.
Old 01-06-2006, 02:03 PM   #42 (permalink)
I removed my JT helper springs and installed a set of the Hellwig Traction Springs. I like the set up alot better. Does not lower the rear like the JT helper springs did. In fact they may even raise the rear about 1/4 inch. Nice ride too. Good find GR8TITAN.
Old 01-07-2006, 07:26 AM   #43 (permalink)
Would this type of setup be benificial for towing. I own a 04 Armada with a new rear end at 10,000 miles. I also own a 05 Titan that I now use to tow my camper with instead of my Armada.
Ramon is offline   Reply With Quote
Old 02-11-2006, 09:19 AM   #44 (permalink)
Galaxian's Avatar
Did using both helpers lower the rear end?
Galaxian is offline   Reply With Quote
Old 02-11-2006, 12:35 PM   #45 (permalink)
gr8titan's Avatar
There was no change in the rear height.
There was also less "bounce" when I pull my 5K lb boat+trailer.
