Re: Throttle Opening-Put to bed
Is the TPS and throttle motor an integrated unit? I know on many applications that there is something to be gained from tuning the TPS. Most TPS operate on a 0 - 5V signal. The throttle opening signal is 1 - 5V though. So with the throttle blade completely closed you try to adjust the TPS output voltage as close to 0.99V as possible. There is quite a bit of tolerance so from the factory a TPS may output anywhere from 0.88V to 1.03V or so. The amount of adjustment is very small but does make a definite improvement in throttle response.
2000 F-150 XLT SuperCab
370+hp/450+tq SAE and not on the meth...yet...
