Re: One Wheel wonder please help.
I think the only lsd released so far was taken back out of circulation due to engineering problems. unitl they make new one you could get some bigger tires maybe. Also, have you ever tried applying the brakes and the gas at the same time when pulling your boat out of the water. It helps you keep all that torque reigned in and it helps an open differential split the torque evenly. It won't hurt anything for a few feet until you get to dry ground.
Good luck!
Galaxy Black 2004 Titan XE CC 4x4 w/ Off-Road Package, Preferred Package.
Mods: PRG Spacers, 17x9" Eagle 187s (+2mm offset) w/ 315 70-17 BFG All-Terrain KO tires, Stillen Diff Cover, Alpine Type-R components in the front, coax. in the rear w/ 50 x 4 Rockford Fosgate Amp, XM, Debadged, and Homemade RCA pre-outs on in-dash changer.
