Old 02-10-2006, 04:48 PM   #1 (permalink)
Articulation with 4" PRG lift and Toyo M/T's
Hey guys,
I just got my 33" Toyo Open Country M/T's on yesterday. I took a few pics of the articulation of the suspension with them and the PRG 4" lift.
http://www.imagestation.com/album/pi...?id=2109280827
06 Titan White Crewcab LE 4X4, Banks Cat-back, Volant CAI, PRG leveling kit, Bilstein rears, PRG Off-road traction bars, 33x12.5x18 Toyo Open Country M/T's, XM satellite, HID headlights and fogs, SE Offroad skidplate, Trutrac Rear Differential..........SOLD
2007 Armada LE 4x4
2007 G35 6spd sedan
g356gear is offline   Reply With Quote
Old 02-10-2006, 10:15 PM   #2 (permalink)
rod_b's Avatar
Re: Articulation with 4" PRG lift and Toyo M/T's
I'm diggin' those tires. How much?
8.04 K11 CC LE 4X OR BT PRG'd
rod_b is offline   Reply With Quote
Old 02-11-2006, 07:04 AM   #3 (permalink)
Chris93Si's Avatar
Send a message via AIM to Chris93Si
Awesome pics! I'm tempted to go w/ 18" wheels just so I can get the Open Country in a 33".
Which coilovers do you have?
Chris93Si is offline   Reply With Quote
Old 02-11-2006, 10:52 AM   #4 (permalink)
They are about $350 a piece.
2007 Armada LE 4x4
2007 G35 6spd sedan
Old 02-11-2006, 10:53 AM   #5 (permalink)
Donohoe Racing coilovers in the front with Total chaos upper a-arms. Bilsteins in the back. I am still waiting for my Deavers so I can install my traction bars at the same time.
2007 Armada LE 4x4
2007 G35 6spd sedan
Old 02-11-2006, 11:18 AM   #6 (permalink)
Mustard's Avatar
How to you like the ride? I am planning on the same setup as you have. I currently have the BFG 315/70-17
Mustard is offline   Reply With Quote
Old 02-11-2006, 11:25 AM   #7 (permalink)
smschulz's Avatar
Thumbs up Re: Articulation with 4" PRG lift and Toyo M/T's
Hey guys,
Hey g56gear ... It looks like my rig will be the same... I have the same parts on order (PRG 4" ~DR TC Bilstein Deaver) ... I am really considering the same tires ...except maybe with different rims ... I know the install is not complete but did you add a rear block ~ or not ~ I am concerned that my rear might be too low? Really like your setup .. makes me really wish the parts were here!
smschulz is offline   Reply With Quote
Old 02-11-2006, 12:51 PM   #8 (permalink)
Overall the truck seems more planted to the ground. It is stiffer but not choppy. The Bilsteins made a big difference in the rear.
2007 Armada LE 4x4
2007 G35 6spd sedan
Old 02-11-2006, 12:58 PM   #9 (permalink)
The rear is stock right now with just the tires and the Bilsteins. I did not add the block. I did test fit the same tire in a 35" and the fit and clearance were fine except they did rub on the very bottom of the front plastic liner. I looked at heating it up and re-forming it it but there is the welded body seam joint under there necessitating the bulge. I did not want to start cutting body parts....especially structural ones. With the 33's they clear on a full turn by 1/4". I haven't tried to put my front mud flaps back on yet.
2007 Armada LE 4x4
2007 G35 6spd sedan
Old 02-13-2006, 06:41 AM   #10 (permalink)
MO Titan's Avatar
I could not tell by the pics, did you get the street or off road traction bars?
Oddly enough, my daughter just made this same face!!!
My Truck: Born April 17, 2004, Purchased June 3, 2004
LE Canteen Crew, 4X4, BT, OR to which I added: SS Brake Lines, Advanced Folding K-Cover ,SS Lund deflector, Black Prism DunderDan grill (I hope it's coming soon), 4" Prerunner Greg Performance Lift, The first Zoomers SS exhaust ever shipped, Volant Gen III CAI, and Chick's Hulk engine cover, custom A-pillar with 1in guages (coming soon).
As Money Allows: Nismo Headers, Dynatech 2.25" Powercats (Damn Missouri and your air quality) Osirus, Trutrac, Stillen (sway bar, big brakes, diff cover), and PrerunnerTraction Bars.
MO Titan is offline   Reply With Quote
Old 02-16-2006, 12:19 AM   #11 (permalink)
Supporting Vendor (Gold)
PrerunnerGreg's Avatar
g356, try driving it without the sway-bar end links attached. The ride is much better on uneven terrain. The DRE use a stiff enough coil that sway is not really an issue. I run mine sans swaybar, and its great. Its a free thing to try, and you can always go right back if you dont like the different feeling.
Old 02-16-2006, 06:12 PM   #12 (permalink)
I have the offroad ones but I was waiting for my backordered Deavers to arrive so I could install everything in the back at once while it was apart.
2007 Armada LE 4x4
2007 G35 6spd sedan
Old 02-16-2006, 06:13 PM   #13 (permalink)
Thanks Greg....I will give it a try.
2007 Armada LE 4x4
2007 G35 6spd sedan
Old 02-16-2006, 06:30 PM   #14 (permalink)
Sammy Sandbag's Avatar
First of all, great looking truck. But, I'm a bit confused. I thought that Greg's 4" lift was DR+a special spacer to attain that extra inch (IIRC the DRs top out at 3"), and of course the TC arms and blocks or leafs in the rear. But, when looking at your truck, it still appears as though you have a slight rake, or perhaps evenly leveled. If it were 4" up front with stock in the rear, I would expect the rear to be lower. What caught my attention was that your truck appears to have a very similar stance to mine, which has spacers in the front and 1" blocks in the rear. I also have 33x12" tires, and the wheel well gap looks identical. Do you have the DR's cranked down low? Regardless, it's still a sweet looking ride, I'm just wondering about the 4 inches.
-Counsel Yourself
Old 02-16-2006, 07:42 PM   #15 (permalink)
Supporting Vendor
P's Titan's Avatar
nice ride, seeing the 4" lift I may end up going upto 6"...
my mods list
www.adamspolishes.com
CrankyWhore™
Blah Blah Blah Whore™
TequilaWhore™
still selling my 14" lift! 20" rims 37" tires liftedtitan Buy/Sell 24 03-07-2007 11:45 AM
toyo 35x1250R18's on stock wheels fit CST 8" lift!! redlands titan Titan Wheels, Tires & Brakes 16 11-30-2005 10:55 PM
Toyo Open Country M/T Tire Size for Stock 18" Rim? vw1972bugs Titan Wheels, Tires & Brakes 19 11-29-2005 06:46 PM
18" MKW Chrome Wheels w/ Toyo Tires Justin311 Buy/Sell 6 04-26-2005 01:22 PM
2.5" lift Rough Country Lift for sale GETSOMZ28 Buy/Sell 0 10-26-2004 12:57 PM
