Old 02-21-2006, 10:56 AM   #1 (permalink)
FlimFlamMan's Avatar
Banks causing rattle at approx 1800rpm's
I've had my Banks on for around 60 miles. Really dig the sound!
However, I just started getting a rattle (pretty sure it isnt a leak) today at about 1800rpm's (noticed while at lunch).
So I start at the back and notice the tip is kinda loose. I put it up as far as I could on the collar because I didnt want it sticking out so far. I live pretty close to work, so I cruised home and moved the tip out farther and cranked it down good. It won't be moving anytime soon.
I was hoping that would be the problem but it wasnt. With the back slider down I can hear it much better. Like something in the bed area has been rattled loose by this fierce catback exhaust system. lol. I don't have the utility bed package... only the factory sprayed liner.
I can't think of what else it could be so thats why I'm asking for help. All the other clamps are secure and torque'd to spec's.
Any idea's?
2007 WRX TR (5 speed)
Stage I
The Titan will be missed....
2005 XE CC 4x2
QX56 OEM Wheels
Uprev Tuned
Old 02-21-2006, 11:00 AM   #2 (permalink)
Re: Banks causing rattle at approx 1800rpm's
Forgot to mention...
Another thing I noticed was that I couldnt reproduce the sound while parked.
Stage I
2005 XE CC 4x2
QX56 OEM Wheels
Uprev Tuned
Old 02-21-2006, 03:45 PM   #3 (permalink)
markislive78's Avatar
i had a rattle only under acceleration at around 1800-2200 rpm after putting in my banks. Turned out being my overhead console around the courtesy lights/sunglass holder. I had to line the inside a lil peice of dynomat to resolve. This was really driving me krazy 4 a long time. I found it by accident under acceleration while clicking on one of the cortesy lights at night....every time the rattle would start i would touch the windsheild side of the overhead console and it would stop.
markislive78 is offline   Reply With Quote
Old 02-22-2006, 05:15 PM   #4 (permalink)
Well... my rattle is definitely coming from the exterior. I haven't had the time to get under it to take a good look yet.
The first thing I'm going to check is the heat shield for the muffler. I had an old honda accord that basically made the same rattle, but it was a heat shield in the manifold area if I remember correctly.
I can hear it much better with the rear slider down. Yet... it doesnt always do it. But when it does its at around 1800 rpms. Grrrr!!!
Stage I
2005 XE CC 4x2
QX56 OEM Wheels
Uprev Tuned
Old 02-22-2006, 05:50 PM   #5 (permalink)
Check the exhaust hangers.
sc186 is offline   Reply With Quote
Old 02-22-2006, 06:30 PM   #6 (permalink)
CoachBoone's Avatar
But they're welded, and they have rubber grommets.
2004 Nissan Titan SE 4X4 Crew Cab
with a bunch of stuff on it.
"Straighten that tie, son."
Old 02-22-2006, 07:37 PM   #7 (permalink)
37L1's Avatar
But the bolts that hold them on might be loose or the mount bracket that is supplied by Banks might have been mounted incorrectly, a few of our members have had this problem. Also if all of the hangers somehow have not been slipped into all the mounts, this could also cause vibration at RPM's.
I would also check the metal heat shields that are mounted on the bottom of the truck that are over the exhaust.
2004 Titan Smoke LE CC
Born 11/18/03
Bed Extender, Overhead Racks
-Gambit
STUPID IS AS STUPID DOES.
-Forrest Gump's Momma
Old 02-22-2006, 07:43 PM   #8 (permalink)
Kronos1965's Avatar
There's a good deal of expansion when the system heats up. Check the last bracket to make sure that the metal hanger is not in contact with anything.
I had to reverse mine to keep it from coming into contact...
Good luck.
Kronos1965 is online now   Reply With Quote
Old 02-22-2006, 08:09 PM   #9 (permalink)
Someone over at CT took an excellent picture/tutorial of that bracket installed. So I know I got it on right.
Definitely going to check the heat shields you are talking about. I've had a similar noise on a prior vehicle and it was a heat shield.
Stage I
2005 XE CC 4x2
QX56 OEM Wheels
Uprev Tuned
Old 02-22-2006, 08:48 PM   #10 (permalink)
Dr_Combustion's Avatar
Yet another example of the Bank's drone at the resonant frequency. Not only do we hear it, but so does your truck! This resonant fequency (at approx 1600-2000rpm) will cause a vibration throughout the truck. The only way to "cure" it is to move the frequency to an RPM range not often seen while you are driving.
2005 "ARREST ME" Red Alert SE Crew Cab 4x4 w/Popular (Captains Chair) Package, Off-Road, Big Tow, Bedliner, Bed Extender, Heavy Duty Rubber Mats and Underseat Storage. Mods: Airbox, Polished Borla Duals, Top Dawg Hard Tonneau, Chrome Off-Road Wheels, Chrome Tailgate Trim, Billet Grill, Bugshield, Helper Springs, Westin SS Bars, Bushwacker Flares, Hella Driving Lamps, TomTom, Escort, Scanguage, Cipher, Mini-Lift and 315/70/17 BFG T/A All Terrains.
Dr_Combustion is offline   Reply With Quote
Old 02-22-2006, 10:08 PM   #11 (permalink)
You probably wont be able to change the pipe length enough to create an antinode in a broad enough RPM range. So you move the tailpipe length a few inches and remove the drone for 25 RPM until the frequency changes. The end-all-be-all would have to be a variable length exhaust system with a way to re route exhaust through another length of pipe at the resonant frequency. Like a cutout attached to a wavemeter programmed to close off the main exhaust into say a dump pipe in the 1500-2000 RPM range.
Or you could turn up the radio.
Old 02-23-2006, 10:40 AM   #12 (permalink)
I have found that there are other ways to move the frequency (RPM) besides changing piping length. It all has to do with the system resistance. Adding or subtracting piping is one way of changing system resistance.
Old 02-23-2006, 10:51 AM   #13 (permalink)
I just had the same problem fixed today. You should be able to notice it when trying to power brake it.
I noticed right after I had my rear axle replaced, so I thought it was related. I took it back to the dealer today, and they tightened up the the nuts on the driver's side flange where the banks bolts on to the cat. It is completely fixed now.
GotMyTruck! is offline   Reply With Quote
Old 02-23-2006, 09:00 PM   #14 (permalink)
Frequency is a function of oscillations and time, not resistance. The only way to "change" it is to alter the length.
Old 02-24-2006, 08:29 PM   #15 (permalink)
I found the rattle.
It's the heat shield that goes over the pipe between the cat and resonator on the passenger side.
I haven't fixed it yet... but at least I know what it is now.
Stage I
2005 XE CC 4x2
QX56 OEM Wheels
Uprev Tuned
Help me with rattle Scarab Titan Problems & Dealer Service 21 04-27-2006 01:38 PM
Cruise Control Causing Throttle Pulsing Driving Downhill Titan4RV Titan Problems & Dealer Service 4 02-14-2006 05:58 PM
Wet Floor causing headaches oktex88 Titan Problems & Dealer Service 8 12-11-2004 11:49 AM
Aftermarket Nerfs causing squeeks? NorCalTitan Titan Problems & Dealer Service 7 08-23-2004 05:16 AM
Another Rattle Fix... titanized Titan Problems & Dealer Service 2 04-22-2004 03:34 PM
