Old 02-28-2006, 09:50 AM   #1 (permalink)
Thrust_Titan's Avatar
All Titans run rich at WOT
My .02 cents if it helps
All Titans run rich at WOT when you go into open loop. The ecu pre-sets are rich about 11:1 if you get a Adjustable Fuel Pressure Regulator, Adjustable from 30 to 75 psi. You will be able to adjust the fuel pressure down so at WOT you get 12.5:1. Your LTFT and STFT A/F in close loop will adjust to keep it at 14.7:1 for cruising. Mods will not change the way the LTFT and STFT A/F mix works in the ecu. The regulator return can T into the rubber hose from the gas fill to the tank. Start fuel pressure at 51 psi and with a Wide-band Air/Fuel Ratio Meter, drop the fuel pressure until you are up to 12.5:1 in WOT best to do this on a DYNO
Now all of us can adjust for any mods and better gas mileage and the price is right.
This will hold us over until a PROGRAMER comes available.
Share the wealth of knowledge and go as fast as you can.
IRC Member "International Racers Club VK56"
TESTING: GTech/Pro RR, AutoTap, Auto Enginuity Enhanced, UpRev, Audio Spectrum Analyzer for Knock Sensors Monitoring, HP nx9420 Notebook PC T7700, Sprint Mobile Broadband
MODS: Custom PGM 90mm Throttle Body, Custom PGM Throttle Body Spacer, Custom Throttle Body Intercooler, Custom Ram Air, Custom 160 degrees Thermostat, Custom CAI, Nismo Headers, Custom B-Pipe NO Cats in line and NO Simulator without CODES (LOL), Custom MagnaFlow Exhaust, Custom Tune, Flex-a-Lite 27 Electric Puller Fan #295, Jim Wolf Technologies Camshafts, Detroit TruTrac LSD.
Thrust_Titan is offline   Reply With Quote
Old 02-28-2006, 10:48 AM   #2 (permalink)
Titano24's's Avatar
Send a message via AIM to Titano24's
Re: All Titans run rich at WOT
i'm guessing you did this? did you see a big difference on the dyno?
2004 CC 4x2 Titan LE (White)
Engine : AEM Brute Force, Airraid TBS, TB Coolent bypass, Deleted Resenators, Banks Monster Exhaust
Looks : 22" Giovanna Aburzzo's, 20% Tint, Painted Armada Front Lip, Truxedo Lo-Pro Bed Cover, 2" Rear drop, In-channel Vent Visors, OEM bugshield
Entertainment : Kenwood DDX-7015, JL Audio 1000/1, JL Audio 450/4, JL XR 6.5 Components, 2 x JL Audio 8"w7's, Audiocontrol 6XS, Kinetik 2000 and 800 batteries, *coming soon Iraggi 220amp alternator*
Titano24's is offline   Reply With Quote
Old 02-28-2006, 11:22 AM   #3 (permalink)
Wiscdave's Avatar
Dude, let me know how you mpg and dyno results are!! I'll be up for doing this mod if it helps.
old ride - 04 XE CC 4x4 traded at 62k
Wiscdave is offline   Reply With Quote
Old 02-28-2006, 11:58 AM   #4 (permalink)
I did this months ago among other mods (CAI) and I didn’t think anything of it I just assumed no big deal my CAI were working fine and the air / fuel was right where I wanted it to be, oops my bad as my kids would say. Sorry, no I did not do a dyno on just the regulator it is part of a bigger picture in which I am going back to work on.
Old 02-28-2006, 06:57 PM   #5 (permalink)
GETSOMZ28's Avatar
That is strange, my Titan (when bone stock) showed 12.5 at peak tq and 13.0 at peak hp on the dyno. Granted the wideband was the tail-sniffer kind, but it wouldnt be off more than .5. I dont know what the A/F ratio is now that I have mods.
Scott
Old 03-02-2006, 04:27 PM   #6 (permalink)
Thats great to hear GETSOMZ28 from what I have seen your one of the first, maybe its your ECU software ver. or all that I have seen is with mods. Maybe its time to get the tail-sniffer out to recheck, if it's off and rich consistently, then maybe this may help you. It's working for me and all I'm trying to do is share some info.
AFE and running rich sctitan05 Titan Performance Modifications 12 12-29-2005 04:56 PM
TSB for lean/rich sensor TallTexan Titan General Discussion 7 08-08-2004 09:24 PM
Newer Titans and Older Titans! lizardking Titan General Discussion 15 05-31-2004 09:22 PM
Early Titans VS Later Titans lizardking Titan General Discussion 7 03-25-2004 12:03 PM
