Ok, installed my Active Tuning. I did notice a change in shifting right off the bat.
One thing, during the install the bolt for the last one ( tranny ) did not fit. Also, my dumbass tightined the bolt were the exhaust ground is to hard and snapped the head right off. I had to call my buddy who was a mechanic and went ahead and attached it to the bolt were the heat sheild was above the cats? Is that ok ? I couldn't get the bolt out since it is stuck.
Also, my damn clock disapered since I did this. Anyone else come across that?
Hey P- is your clock still out? I haven't installed this yet, can you take a pic of where you attached the finally bolt to your heat shield just incase I run into the same problem.
Anyone else run into this problem too?
DJ
'04 White SE, CC, BT, Off Road 4x4
• Banks Monster Exhaust • Pro Comp 6" Stage II • PRG Radflo External Reservoir Coilovers w/King Springs
• PRG OR Traction Bars • American Racing Chamber w/Teflon 17" • BFG T/A KO 315/70 17 • Active Tuning Grounding Kit
• FramBoost Air Intake • XM Satellite Radio • Hoppy Assist Tailgate • Grillcraft Black Mesh Grille • 2° Timing Advance
________________________
DJ
Clock is still out.. just don't over tighten. My buddy talked alot of sh!t because of how hard I tightened it. I can take a pic later but you should not have a problem.
pics... I am going to try to get the broken bolt out and place the stuff were it should be. I also read on here by searching that the clock issue was to remove negative cable for 10 mins and that fixed it.
First is new spot I had to use because I snapped the bolt were it was supposed to be.
Is your's a 4x2? Everything fit perfect on mine. Good luck with clock. No problems here.
4x2.. yea I have not read anything about people having problems. Must be my bad a$$ luck.
pi3yeargrad so u guys did notice some improvements? cant wait...I think mine should be in tomorrow
I did notice the quick start up and the changing between gears is very noticable. I have not checked for MPG which I really ain't concerned about cuz this def is not going to change that.
sounds good bro...what u said u got is all I was expecting from mine so hopefully Ill get some good results as well...
i had a problem finding the last two bolts on the transfer case. i have a 4x4! Anyone else have this problem? i just left this off till i find out where the damn bolt goes!
__________________ 2004 KC, Radiant Silver, Off road,bed liner,bed extender, K&N Filter Charger,activetuning ground kit, Lund Bug Shield, Vent Visors, BFG AT KO's, waterproof seat covers, Sirius sportster relpay ( HOWARD STERN RULES!)fold-a-cover tonneau cover, westin bull bar, PIAA series 520 fog lights, gibson extreme dual exhaust. 20" Eagle Alloy series 114 wrapped in 305/50r20 Nitto Terra Grapplers, DRE rear shocks and Radflo 2.0 front shocks
