Cool-Pack Electric Fan Units
• Eliminates factory fan clutch, fan, and shroud.
• Increases horsepower and torque.
• High output, low amp electric fans.
• Adjustable thermal controller.
• Robust aluminum assembly.
• Durable black powder coated finish.
• Classic design enhances engine compartment.
• Simple hand tool installation.
• Pre-assembled and wired.
Features include dual high output electric fans controlled with a 160°F-210°F adjustable thermal switch mounted in an aluminum assembly with a black powder coated finish. A special cross flow isolator, a Perma-Cool® exclusive, maximizes fan efficiency. The Cool-Pack mounts solidly to the existing radiator core support (not the radiator) and uses the stock fan shroud mounting holes and fasteners. Requires no drilling, tapping or modifications.
Installing Cool-Pack couldn’t be easier! Simply remove the stock fan shroud and fan clutch/fan assembly. Next, install the pre-assembled and pre-wired Cool-Pack using the factory holes and hardware. Finally, connect three wires (power, ground and air conditioning clutch.) That's all there is to it!
__________________ Share the wealth of knowledge and go as fast as you can.
IRC Crew Chief "International Racers Club VK56"
TESTING: GTech/Pro RR, AutoTap, Auto Enginuity Enhanced, UpRev, Audio Spectrum Analyzer for Knock Sensors Monitoring, HP nx9420 Notebook PC T7700, Sprint Mobile Broadband
MODS: Designer of the famous PGM 90mm Throttle Body and the PGM Throttle Body Spacer. Designer of the Throttle Body Intercooler system. Custom CAI, Custom Ram Air, Custom 160 degrees Thermostat, Custom MagnaFlow Exhaust, Custom B-Pipe NO Cats in line and NO Simulator, Custom UpRev Tune’s
Nismo Headers, Flex-a-Lite Electric Puller Fan #295, Jim Wolf Technologies Camshafts, Detroit TruTrac LSD, ActiveTuning Grounding.
Mike at Perma-Cool gave me a phone number to a vendor that will give a good price but the vendor was not a supporting vendor so I will wait befor calling
__________________ Oddly enough, my daughter just made this same face!!!
My Truck: Born April 17, 2004, Purchased June 3, 2004
LE Canteen Crew, 4X4, BT, OR to which I added: SS Brake Lines, Frozen Rotor Front rotors with Hawk L/T pads(on their way!!!), Advanced Folding K-Cover ,SS Lund deflector, 4" Prerunner Greg Performance Lift, The first Zoomers SS exhaust ever shipped, Volant Gen III CAI, and Chick's Hulk engine cover, custom A-pillar with 1in guages (no guages yet though).
As Money Allows: Black Prism Dunder Grill, 20" LiquidMetal Magma Mirror Black rims and tires, Trutrac, Stillen (sway bar, and diff cover), and PrerunnerTraction Bars.
I think the major benefit is that your fan has a parasitic effect on your engine, meaning when your fan kicks on it is powered by a pulley powered by your engine. This reduces engine out put or horse power. The fan being electric or engine driven should have no effect on how cool it keeps the engine. The electric fans are just powered by the battery instead of the engine, leaving the piower where you want it.
Those who have used these before, how is the noise from the fans? Quieter, louder, same?
04 Titan 4x2 SE KC, Smoke, Magnaflow Single Exhaust, 05 Diff Cover, Stillen VKPro, AEM Brute Force w/DRYFLOW, Custom Painted Engine Cover , Sylvania Silverstars, Rhino Bedliner, Nissan Bug Smacker, Sirius Starmate 5 and iPod (AUX), Sony xplod, 2 x 10" JL 0, and a locking gas cap
I had flex-a-lite fans on my 4Runner and when they kicked on it would put a pretty good load on the alternator and would slow the idle speed. That I did not like at all. They also made a pretty good mount of noise. I had one on my Ranger which was off a Focus and it worked a lot better. It did not put a huge load on the alternator and was whisper quiet.
Sold 8/2006
Replaced With 2006 Subaru Impreza WRX
Just Can't Stay Away
