Originally Posted by Helinut1970
Mopar, with what you know about engines, You need buy a Titan and show us how its done!! Instead of "got torque" being our new rep YOU could take the place of the "head"
I would love to but I just can't bring myself to buy a new vehicle when if I spent the same money on a classic, it would be so much better!
One of you folks can try this though, it looks like the cam sprockets are around a 50 tooth sprocket, so each tooth would be about 7 degrees of cam timing. I would move the intake cams one tooth in the direction that would decrease the LSA, but I'm not sure which way the motor rotates, so you guys could try this.
I wouldn't move this more than 1 tooth since 7 degrees is not a big deal, but 14 degrees is (2teeth) regarding valve to piston clearance. I'm not sure if this is an interferance engine or not (if the timing chain breaks, will the pistons hit the valve).
But given the formula (ILCA+ELCA)/2= LSA, where ILCA = Intake lobe centerline angle, and ELCA = Exhaust lobe centerline angle, and LSA=Lobe Separation Angle, if ICLA is currently 115 and ECLA is 115, then the LSA is 115.
So if you change the Intake 7 degrees toward a reduced LSA, you would have 108. Then recalculated, 108+115= 223, divide by two and you have around 111.5 for your LSA. I wouldn't move the exhaust unless you are really
hardcore about what you want your engine to sound like because you would end up with a LSA of 108, which would give a lot of overlap and much reduced vacuum at idle, but the mid-range torque would be fantastic.
One last note, once you jump a tooth, before you put it back together slowly turn the engine over with a wratchet to make sure there is no piston to valve interference.
Have fun guys!
1969 Plymouth Roadrunner street/strip 3700 lbs
New Best 1.60 60', 7.25 660', 11.48 1/4,
best mph117.25 65F/2100ft/ 30% humidity, barometer 29.1 through the mufflers in the desert at Las Vegas all throttle no bottle.
**SOLD**1970 Camaro Bracket Racer 3160lbs
10.78 1/4MPH 124.7
1951 Chevy Truck
10.508@127mph, 1.48 60'
400 smallblock chevy
