Old 03-11-2006, 04:20 PM   #1 (permalink)
Exhaust noise
I've got the Banks exhaust on my truck and this is the first truck that I've owned. I just want to know if my truck is normal for anybody with an aftermarket exhaust. When the truck is warmed up and I'm driving past 30 mph and I let off the gas the exhaust makes this noise and I just want to know if it is normal or should I take it to the dealer. I have a video so that you guys could see if its normal and I love the sound of the Banks and to me there is no drone. It just annoying sometimes when I'm driving and it makes the noise plus it kinda jerks back like its engine braking or something. Here is the link http://media.putfile.com/titan57. Sorry for the long post.
VK56inFTW is offline   Reply With Quote
Old 03-11-2006, 04:45 PM   #2 (permalink)
baseballfanz's Avatar
Re: Exhaust noise
Kinda hard to tell from the video but check to make sure you have no leaks, all clamp tighten?
Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
Old 03-11-2006, 05:07 PM   #3 (permalink)
Re: Exhaust noise
Well the noise that you hear in the video is the noise that I'm talking about. My foot is not on the gas. It does it everytime that I'm over 30 mph and I let my foot of the gas. When its gets under 30 it doesn't do it anymore.
Old 03-14-2006, 10:02 AM   #4 (permalink)
markislive78's Avatar
Re: Exhaust noise
Hard to put a finger on it in ur video....I had a Banks and it did the same ...when you let off the gas you should hear a slight poping when letting the motor slow you down
markislive78 is offline   Reply With Quote
Old 03-14-2006, 11:57 AM   #5 (permalink)
SoBeGraphics's Avatar
Re: Exhaust noise
did you get out all of those styrofoam popcorn out of the tubes and muffler before installing? Sounds weird - sort of labored - I have banks and if you let off the gas the engine goes to idle and you can barely hear the exhaust and it coasts.
2005 Titan LE Crew - Galaxy - BT - BANKS - AEM - BLACK BOX TUNER - Dyno @ 298 rwhp / 359 rwtq
Weeeheeheeheehee. Click Here
SoBeGraphics is offline   Reply With Quote
Old 03-14-2006, 03:11 PM   #6 (permalink)
Mike H.'s Avatar
Re: Exhaust noise
Sounds 100% normal to me. Mine always rumbled down when I let off the throttle.
I pulled my Banks muffler Sunday and installed a 3" FlowMaster 70. Just got tired of the noise.
Mod links (clickable):
Old 03-14-2006, 03:38 PM   #7 (permalink)
Re: Exhaust noise
Me too... quiet as a church mouse
'04 Titan SE Crew Cab | 4x4 | Smoke | Off Road | Big Tow
Banks Monster Exhaust
AFE Magnum FORCE Stage 2 Cold Air Intake System
A.R.E. LSII Tonneau Custom Fit/Paint Cover
OEM Bugshield | OEM Step Rails
SE Utility Bed Package
Goodyear Wrangler Pro-Grade Tires w/SilentArmor Technology
autostnmn is offline   Reply With Quote
Old 03-14-2006, 05:54 PM   #8 (permalink)
Kronos1965's Avatar
Re: Exhaust noise
I have a Banks and had to retighten up the system once it heated up a few times.
No problems since.
btw: Take off the Banks megaphone and it sounds quieter than stock!
Would an ECU reset help with this noise?
Kronos1965 is offline   Reply With Quote
Old 03-14-2006, 08:05 PM   #9 (permalink)
FlimFlamMan's Avatar
Re: Exhaust noise
Me 3. Only when I'm gunning it up to around 70 and lay off the throttle do I hear a little bit of what your describing.
I couldnt get used to that megaphone diesel tip. I went and had Midas weld a 3" inlet 3.5" outlet Magnaflow SS rolled edge tip. Looks much mo' betta' to me.
I'd just give it more time to break in, so to say (dont really know how long you've had it on). Wouldn't hurt to take it out on a long road trip to break it in quicker. Then let it cool down and make sure everything is still tight.
Its hard to tell from your video... almost sounds like you have a leak. Did you use the Banks gaskets or use the OEM ones?
2007 WRX TR (5 speed)
Stage I
The Titan will be missed....
2005 XE CC 4x2
QX56 OEM Wheels
Uprev Tuned
Old 03-15-2006, 03:46 PM   #10 (permalink)
Re: Exhaust noise
Well I've had the exhaust for about a year and a half. Well the other day I finally had the chance to get underneath the truck and I did find a leak but I can't seem to fix it. Its at the end of the muffler. It seems the clamp was tighten too much and its bended the slit inward so it's leaking. I tried to move the clamp to the outward part but it doesn't seem to do much because it's still leaking.
Glowin need exhaust help (custom glasspack exhaust) glowinstrat Titan Performance Modifications 56 03-27-2006 05:59 PM
Exhaust expansion/contraction noise titanmoon Titan General Discussion 3 01-20-2006 10:06 AM
Am I the only one like less noise in exhaust system? Tyltan Titan General Discussion 24 01-18-2005 11:11 PM
Adding exhaust tips on stock exhaust cttitan Titan Interior Discussion 9 06-14-2004 12:36 PM
