Re: Installing Brute Force CAI tomorrow
You don't have to remove the tire, you can still install the four little bolt that hold the heat shield to the truck's fender by just taking off the liner. Better yet just use double sided tape to attach that part of the heat shield to the truck or like whitewid0w stated, that four little bolt can be skip altogether IMO. You don't need to removed the washer fluid resivoir either, that is to get to the 3rd bolt holding the factory airbox on. Just remove the two bolt you see and yank on the airbox, it will come out.
Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
