Old 04-30-2006, 11:10 AM   #16 (permalink)
Dr_Combustion's Avatar
Re: Improved performance and hp from 2 degree timing advance?
The site for the Cipher software also indicated about 5-6 HP increase (dyno runs) with the 2 degree advance.
2005 "ARREST ME" Red Alert SE Crew Cab 4x4 with Captains Chair Package, Off-Road, Big Tow, Bedliner, Bed Extender, Heavy Duty Rubber Mats and Underseat Storage. Mods: Airbox with Fram AirHog Filter, BullyDog Programmer, Polished Borla Duals, Top Dawg Hard Tonneau, Chrome Off-Road Wheels, Chrome Tailgate Trim, Billet Grill, Bugshield, Helper Springs, Westin SS Bars, Bushwacker Flares, Hella Driving Lamps, TomTom, Valentine One, Scanguage, Cipher, Mini-Lift and 315/70/17 BFG T/A All Terrains
Dr_Combustion is offline   Reply With Quote
Old 04-30-2006, 11:36 AM   #17 (permalink)
I plan on getting mine done next Saturday at the NJ meet.
Some have said they've noticed an increase in performance, some not. If I can get it done for free, I'll give it a try. I also plan on adding a TBS, so I won't be able to evaluate it alone.
SOLD**2004 SE CC Radiant Silver 4X4 w/ Pop. Pkg and DVD
**SOLD
SOLD **2005 Titan XE KC w/ Preferred Package BLACK **SOLD
2004 Chevy RCSB 5.3/3.42gears/Auto/Whately Tune/ Intake/Exhaust 15.0 @92MPH
buzzkillwill is offline   Reply With Quote
Old 04-30-2006, 11:42 AM   #18 (permalink)
SoBeGraphics's Avatar
You will probably get more gains from a CAI - Volant or AEM instead of that TBS.
I think the peole that noticed better gains from the timing advance were probably people that that had their timing off a bit.
2005 Titan LE Crew - Galaxy - BT - BANKS - AEM - BLACK BOX TUNER - Dyno @ 298 rwhp / 359 rwtq
Weeeheeheeheehee. Click Here
SoBeGraphics is offline   Reply With Quote
Old 04-30-2006, 12:38 PM   #19 (permalink)
Banned
5 hp is nice. what about these concerns of it resettign to a stock base timing anyway, like when it pings or you remove power from ecu. is this a concern?
Titan1219 is offline   Reply With Quote
Old 04-30-2006, 12:41 PM   #20 (permalink)
No concerns about timing re-setting, unless someone reprograms it lower.
Old 04-30-2006, 01:36 PM   #21 (permalink)
m95roadster's Avatar
There is some confusion here regarding timing issues. When the knock sensor retards timing it does not change the base initial advance. The timing on the Titan is constantly changing depending on load conditions. The purpose of the knock sensor is to pull timing back when it "hears" the slightest ping or detonation (we will not hear this).
2005 Mercedes C-Class
SOLD
2005
Smoke SE Crew Cab
Modifications: a few mods.....
More Pics Here
m95roadster is offline   Reply With Quote
Old 04-30-2006, 03:08 PM   #22 (permalink)
The person I know that did the advance timing was/is a Nissan tech, and had no issues with his timing.
I remember someone saying advancing the timing allows the truck to make up for all the electrical components it's running-if I said that right. Other have said it helps with the hesitation issue under WOT from a stop.
So, if I can help my truck by doing it, then I'm going for it!!!
Do I expect to break in to 14's because of it-NO. But what can it hurt at this point.
**SOLD
Old 04-30-2006, 05:01 PM   #23 (permalink)
sudden urge's Avatar
Hey Sobe, that 5 hp gain was on 87 octane or 91?
Old 05-01-2006, 04:50 PM   #24 (permalink)
My baby only drinks the finest. 93 Octane
Old 05-01-2006, 05:36 PM   #25 (permalink)
Banned
if your going to bump it 2 degrees, i would suggest making it 4 degrees. Might as well get full advantage
Old 05-01-2006, 06:04 PM   #26 (permalink)
Too much advance isn't always better. You probably would start to lose some upper end.
SOLD
2005
Smoke SE Crew Cab
More Pics Here
Old 05-01-2006, 06:07 PM   #27 (permalink)
Banned
without a way to measure differences, its a guessing game, or go by feel, but most of my past cars that allowed you to adjust the timing, 4 degrees always provided the best results.
Old 05-01-2006, 06:08 PM   #28 (permalink)
It won't go four. The most anyone's been able to get it to stay has been 2. Will need to crack the ECU (I think) to get beyond 2. But there's probably not additional benefit. Most will handle two without changing to a higher grade fuel.
I might be wrong, but isn't that the difference between the Nissan and the Inifinti-advanced timing and higher octane fuel. Otherwise, it's the same motor..??
**SOLD
Old 05-05-2006, 11:36 PM   #29 (permalink)
RB's Titan's Avatar
Hey Guys I ran some 0-60on Wed/Thursday using Cipher to log the data and time the run.
Test proceedure:
2 runs each direction back to back after the drive home from work. I ran +2, 0, -2
First of all I want to determine:
1. Does indeed without a doubt +2/-2 timing stick through the rpm range when using Cipher.
2. Do my times suffer?
3. What effect does 87 vs 93 have?
First question please....
The answer is YES without a doubt there is timing through the rpm range as it should after adjustment.
Second Question:
No times are as expected with increased timing there was shorter ET's.
The best of 2 using 50/50 blend of 87/93 octane:
+2 at 7.20sec
0 at 7.50sec
-2 at 7.76sec
Third question:
I saw slightly richer ratios with the 93 octane according to Cipher. I saw a better 0-60 ET 93blend 7.20sec 0-60 vs 7.32sec with 87. I also saw higher RPM and 1 degree more timing at 5500. However when averaging the timing column from both fuels they were nearly identical.
Disclaimer:
These tests are for the performance minded Titan owners that understand that a Hemi with bukoo bolts ons is faster...LOL
Randy
IRC CREW CHIEF - International Racing Club VK56
Get your Knock Detected:
http://www.titantalk.com/forums/tita...ion-tools.html
Link to 13.90 @ 99.37 NA street trim video:
http://s93.photobucket.com/albums/l8...t=02269108.pbr
RB's Titan is offline   Reply With Quote
Old 06-13-2006, 08:02 AM   #30 (permalink)
jaho1979's Avatar
I got this done yesterday for free at a local dealerhip, and the butt dyno tells me it has more grunt in the low end.
I was leaving downtown getting on I-10, and there is a light that leads straight on to the highway. Light turned green, and I punched it to about 70. I could feel a difference in the way it jumped off the line more than anything.
2006 Crew Cab 4x4 LE
jaho1979 is offline   Reply With Quote
testing timing advance juma Titan General Discussion 31 06-23-2006 03:38 PM
Paging Juma; RE: Timing Advance vs. Fuel Grade Steve04SE Titan General Discussion 2 11-07-2004 09:51 AM
Right Angle (90 degree) Stereo Plugs schneid Titan Interior Discussion 0 10-27-2004 06:31 PM
Degree the Cam ?? skromfols Titan Performance Modifications 13 08-02-2004 08:41 PM
Timing Advance Slurppie Titan Performance Modifications 12 07-28-2004 07:37 PM
