Is this thing worth $55? I saw where others have had issues with spongy brakes. Seems like this may help. Anyone have the stiffener and does it work? Seems expensive for a bracket and a u-bolt but it's not like I'm equipped to fabricate one!
There's a couple of places that sell it for $50 out there, but that's about as cheap as it gets. And, I've heard they are pretty nice for stiffining the brakes up.
2006 Titan SE
4X2 Crew Cab
Majestic Blue!
AKA: The Hijack King™
AKA: The Troll Hunter™
not really needed and you cant really feel it unless you have a total upgrade. The force that the master cylinder puts out is going to go to the path of least resistance, this (on a stock system) will mean the brake pads. If you have aftermarket rotors and pads, and still have squishy feeling breaks, replace the brake lines with steel braided lines, this will help tremendously. When the brake fluid pushes aganist the brake pistons there is no where for the fluid to go and the stock lines bulge from the pressure, steel ones do not do this, after all of this if you still have spongy brakes then add the stiffener
Originally Posted by Toomnymods
nevermind blindside he's the village idiot that bashes everyones posts here at TT
Not to be disagreeable but I've got both stainless steel brake lines and the brake master cylinder stiffener on my truck. I would say that the best advice I could give would be to find out the difference it makes for yourself. Open your hood and start the engine, then have a friend or someone step on the brake pedal (of course keeping the truck in park). You can watch the entire master cylinder flex forward and up. This stiffener eliminates all that by mounting to a very solid part of the truck. If you still feel the desire to stiffen up your pedal then I'd recommend going with a set of stainless lines...after all, I'd rather spend 55 dollars rather than 100+ on a set of brake lines...We sell both stainless steel brake lines and these stiffeners so either way I'm impartial.
I don't understand why such a small part is so expensive.
2007 White with Charcoal SE CC 4x4 with off road, tow, SE popular with bench, and utility with bed extender
Mods to date:
6" Procomp Stage II lift, CST Sway bar endlinks, 35x12.5x17 Procomp Mud terrains, 17x8 Moto Metal 954s, Smittybuilt stainless nerf bars, Chrome mirror caps, Color matched Bushwackers, Leer 700 Toneau cover, T Rex 1pc grille, Custom FlowMaster DeltaFlow 50 series dual in single out muffler, Injen powerflow intake, JVC Kw-avx800 7" in dash dvd, 7" DEI wide screen headrest monitors, Sony Xplod 2x250 amp, Infinity Reference 6 1/2" in rear and 6"x9" in front, Prodigy brake controller, Ventshade door sill protectors
2006 Titan SE
4X2 Crew Cab
Majestic Blue!
Correct me if I'm wrong, but don't all 2005+ vehicles have Brake Assist? So they can't even use this stiffener?
-Cyrus
I think it's only on certain models.
2006 Titan SE
4X2 Crew Cab
Majestic Blue!
not worth the 55 bucks...sorry...it wouldnt be hard to make ur own either...I made my own...
like PRG said once and correct me if I dont say it correctly but theres "to much play from the fire wall to really work all that great" or something similar to that
Did you buy a previously driven vehicle? I hate the word used, reminds me of my old girlfriend.
Don't you mean RODE HARD AND PUT UP WET!!!!!! LOL
2006 Titan SE
4X2 Crew Cab
Majestic Blue!
