Old 05-17-2006, 11:14 PM   #1 (permalink)
kartman's Avatar
Phx area timing advance mod
Ok I have a dealer that will do the advance mod for us and possibly the AF ratios as well. It will be setup on a specific day within the next few weeks. I will post more info as its is released.
If you are interested in getting it done reply here. The more we get the better.
Rebar Wrangler
Old 05-17-2006, 11:15 PM   #2 (permalink)
MikeB's Avatar
Re: Phx area timing advance mod
I might be interested. What side of town?
2006 CC Titan SE 2WD BT. Injen Powerflow, TB Coolant bypass, JBA Evol Exhaust with Maglaflow 24" muffler, Bully Dog Power Pup, Leveling kit, $22 helper springs.
MikeB is offline   Reply With Quote
Old 05-18-2006, 08:20 AM   #3 (permalink)
SmokedTiresITAN's Avatar
Send a message via AIM to SmokedTiresITAN
count me in
Visuals:
4 piece chrome billet grill * Stillen Rollpan * 22" x 9.5" Ultra StarGazer Chrome Wheels wrapped with 22" Nitto 420S tires * Rear end lowered 2" * Blacked out tail lights * 15% tint all around with 50% tint on windshield * Keystone Good Hood
Performance:
UpRev * TB-Bypass * TB Spacer * Stillen LT Headers to High-flow cats to JBA Evol Exhaust * Volante CAI with scoop
Futures
JWT S2 Cams * Detroit TrueTrac * PS Pulleys (needs to be installed)
Audio:
4 Diamond Audio D3 10" sub-woofers powered by a Rockford Fosgate T10001bd Amp * Kenwood Excelon KVT-815 In-Dash DVD * Kenwood DV4100 Navigation with a Kenwood LZ-800W in custom mount * Infinity Kappa Perfect 6.1 6.5" Component Speakers powered by a Rockford Fosgate T3002 Amp
SmokedTiresITAN is offline   Reply With Quote
Old 05-18-2006, 08:43 AM   #4 (permalink)
Supporting Vendor
P's Titan's Avatar
not to hijak your thread but speaking to a Service Manager, he said you will need to use Premium Gas for this to work right.
my mods list
USE DISCOUNT CODE FOLGER
FOR 10% OFF EVERYDAY @ www.adamspolishes.com
CrankyWhore™
Blah Blah Blah Whore™
TequilaWhore™
Old 05-18-2006, 10:25 AM   #5 (permalink)
He's wrong.
2 degrees bump in timing won't cause your to have to use premium, also the A/F change will bring your Titans A/F mixture closer to stock that it is running now if you have CAI and Exhaust.
Our trucks have knock sensors so the truck will pull timing (as much as it needs to) if you start getting detonation. I have seen quite a few print-outs pulled from the up-rev cipher softwarwe over on the other Titan board where folks have the bump in timing and the AF mixture change and it shows no timming pull unless the temps are high with regular fuel. Thus it seems our trucks are more prone to having a problem with heat soak than with with running 87 gas with 17 degrees timing. The knock sensors won't let you run any more timing more than what the gas in your tank will support. I will have the Cipher software this summer so if you want we can meetup (I live in Tucson) and do some data logging to see if your trucks pulling timming with regular fuel and we can test it when it's cold and hot)
Kartman
Keep me in the loop. I'd hate to miss this but I'm a single Dad and it may be hard for me to make it up there on a specific day.
I know for a fact I can make it this comming Monday through next Thursday, then the 3rd-8th of June, and then the 20th-22nd of June. Those are the days my daughters dead beat mom has agreed to spend time with her.
05 CC LE Red Brawn
Nissan Bug/rock guard
SilverStar Low Beams
Gibson Side Swept Exhaust
Volant V3 CAI
PRG Mini Lift
18x9 MotoMetal wheels w/285/65/18 BFG AT's
Cobalt is offline   Reply With Quote
Old 05-18-2006, 10:32 AM   #6 (permalink)
phrainq's Avatar
Send a message via AIM to phrainq
I don't have CAI or exhaust, would I still benefit from the timing advance?
hey great first post numbnuts. Welcome to TitanTalk. -37L1
phrainq is offline   Reply With Quote
Old 05-18-2006, 10:48 AM   #7 (permalink)
Yes, the A/F change is the best option for modded Titans
05 CC LE Red Brawn
Volant V3 CAI
PRG Mini Lift
Old 05-18-2006, 02:19 PM   #8 (permalink)
Is there instructions for the A/F change so I can give the dealer?
DPTEXASTITAN is offline   Reply With Quote
Old 05-18-2006, 02:23 PM   #9 (permalink)
Hellions's Avatar
Send a message via AIM to Hellions
Cobalt,
Have you seen the instruction anywhere to change the A/F using the consult machine? Is the general consensus that the 106% map is the best for CAI and exhaust? I know I can get my dealer to do it but only if I bring them a cheat sheet.
Thanks,
Hellions
"Diplomacy is the art of saying 'Nice doggie' until you can find a rock". W. Rogers.
2006 Titan CrewCab. 22" Boss 313's with 305/45/22 Cooper Xeon's. Towing and Traction package. 40 Series Flowmaster Duals (true 2.5" duals with Resos removed). 2" drop in rear. Throttle Body Coolant Bypass. Volant CAI. Volant Ram Air. 2 Degree Timing Advance Mod. H/X Pipe. DunderDan Spider Grill. Myron & Davis 9" DVD System (integrated with factory wiring). UpREV Cipher v1.02.
1/4 Mile Best 15.34s @95.0mph
Looking for a TBS and a Lowering Kit (leafs and coils) if you have one.
More Pics and Details HERE.
Hellions is offline   Reply With Quote
Old 05-18-2006, 02:38 PM   #10 (permalink)
Cheat sheet?
Old 05-18-2006, 02:39 PM   #11 (permalink)
Originally Posted by Hellions
Cobalt,
Thanks,
Hellions
I haven't seen it here but I'm pretty damn sure it's posted on the "Other" Ttian site whos initials are CT. Do a search for posts made by "shailey". I know he's done it and knows how to do it also. If you PM you he may be able to get you a link or provide you the instructions but I don't want to speak for him.
05 CC LE Red Brawn
Volant V3 CAI
PRG Mini Lift
Old 05-18-2006, 02:52 PM   #12 (permalink)
f00dstamps's Avatar
Send a message via AIM to f00dstamps Send a message via MSN to f00dstamps
Originally Posted by DPTEXASTITAN
Cheat sheet?
during my education years, we called those "study guides".... not cheat sheets.
2005 CC Titan 4x4 Blizzard White *** SE Popular Package w/ Captain's *** Utility Bed Package w/ Bed Extender *** Offroad Package *** Big Tow Package *** Valentine 1 (hardwired) *** Clifford Matrix RSX 3.5 Alarm + Remote Start *** Amsoil Synthetic motor & gear oil *** 20% Sun-Guard *** Weathertech front floor liners *** Truxedo Lo Pro *** Husky rear floor liner *** HID 4300k Denso/Koito/Philips *** Vulite LED taillights *** Luminarc yellow foglight bulbs *** Scangauge II *** overhead racks w/ kayak attachment *** DR coilovers *** DR rear 4x4 shocks
WANTING TO SELL: bed extender adapter for tonneau covers (i.e. Truxedo)
f00dstamps is offline   Reply With Quote
Old 05-18-2006, 03:42 PM   #13 (permalink)
ReconTitan's Avatar
Count me in Kartman. I get off the rig and fly home on the 26th of May, after that I am home for 3 weeks except for the 30th May to the 2nd of June (camping in Flagstaff). Just let me know when you want to meet up.
"Uncommon valor was a common virtue" SEMPER FI
ReconTitan is offline   Reply With Quote
Old 05-18-2006, 04:11 PM   #14 (permalink)
AzTitan05's Avatar
I would be interested in this mod as well...Please let me know as soon as you find out details.
AzTitan05 is offline   Reply With Quote
Old 05-18-2006, 05:01 PM   #15 (permalink)
count me in!
pharcyde_titan is offline   Reply With Quote
testing timing advance juma Titan General Discussion 31 06-23-2006 03:38 PM
Improved performance and hp from 2 degree timing advance? sudden urge Titan Performance Modifications 43 06-22-2006 10:43 PM
Dealerships that do timing advance?... Vyrus North East Forum 17 06-06-2006 01:07 PM
My experience at the dealer with the timing advance mod Jamesn Titan Performance Modifications 63 05-23-2006 09:28 PM
Timing Advance Slurppie Titan Performance Modifications 12 07-28-2004 07:37 PM
