Old 06-12-2006, 03:52 PM   #61 (permalink)
Send a message via MSN to Toomnymods Send a message via Yahoo to Toomnymods
Re: Tru Trac is in
Dropped off my baby 30 mins ago to leave overnight to get the TruTrac installed first thing tommrow morning.. 200.00 isn't bad, hehe he wanted 250.00 at first but soon as I told him I would be supplying my own Royal Purple 75w-140 gear oil he reduced the price to 200 since i would be supplying my own gear oil and carrier bearings..
Cant wait to let my baby scream at the track with both tires :P
05' Blizzard White 4X2 KC SE
Foose Speedster 6 22's /w Nitto 420-S 305-40R-22, Hoosier Pro 28x11.50x16 Slicks, McGaughy 2/3" drop kit, Jim wolf Technologies Camshafts, IPT 3400 RPM TQ converter, IPT Valvebody, IPT Built Tranny, AEM Bruteforce CAI, NX Express Import WET kit 125 shot, Stillen Longtube headers, Dynatech 2.5" Powercats, JBA Evol catback, Detroit TruTrac LSD, Flex-A-Lite electric fan conversion kit #295, AirRaid Throttle body spacer, TB Coolant By-pass mod, Line-x spray in bedliner, Trenz 3 Piece framed perimeter billet grille /w matching bumper billet insert, Chrome tailgate cover /w handle, MCulloch HID 6K lows and fogs, Altezza Chrome taillights
BEST 1/4 Times
12.929 @ 103.28 NA FMP 7/18/08
12.8591 @ 106.74 (125 shot) 3/2/08 FMP Before IPT tranny
Dynotech Dyno SAE #'s
N/A Map 330.12 RWHP / 367.59TQ in 96F heat
N20 Map = 430 RWHP / 515TQ
UpRev ECU Tuning!!
Toomnymods is offline   Reply With Quote
Old 06-13-2006, 02:06 PM   #62 (permalink)
Re: Tru Trac is in
Originally Posted by Shadowofnight2001r
the only interesting part of the conversation was the Nissan rep asked if I towed a trailer or not ? I thought that was strange...
Maybe he thought you would confess to towing (pushing) a 20,000 lb. trailer only in reverse in order to wipe out only the coast side of the ring gear?
Old 06-13-2006, 04:08 PM   #63 (permalink)
RB's Titan's Avatar
Re: Tru Trac is in
Well some of you might know and some may not but I was originally going to do a truTrac on my 2.94...but now I'm doing a axle swap with a 3.36 and installing a TruTrac into that one. So my slightly used axle is getting fitted and I get to drive around. Down side is that I had to order the diff cover, bolts, oil, bracket from one of the vendors and they seem to have sold the last one...just hours before...So now my install is delayed until next week.
Hey Baseball my cost just went up a bit from what I mentioned due to swap but...but I really don't think it will be much more since they can work on it in the climate control area.
Randy
IRC CREW CHIEF - International Racing Club VK56
Get your Knock Detected:
http://www.titantalk.com/forums/tita...ion-tools.html
Link to 13.90 @ 99.37 NA street trim video:
http://s93.photobucket.com/albums/l8...t=02269108.pbr
RB's Titan is offline   Reply With Quote
Old 06-13-2006, 04:09 PM   #64 (permalink)
Re: Tru Trac is in
Got my truck back today, and it really pisses me off that it's raining!! So I can't really test it out much.. Although I did launch half throttle at a stoplight just to see if I could hear the locker engage, which I didn't but more on that later.. what I immediatly did notice was it lurched forward much harder and faster.. seems like the wheels are pulling the truck forward harder now Also called Detroit/Eaton this morning to make sure about break in procedures and he assured me that there is absolutely no special break in required whatso ever.. He then asked me what weigh oil I was planning on adding, then the problem arose.. I had already purchased Royal Purple Synthetic 75W-140 with the synerlec additive and he said absolutely don't use synthetic It will make it noisy as hell and lose it's efficieny as a LOCKER He said the synthetic is too thin of a oil and advised me to use a 75w-90 gear oil (petreloum based) and said that this would be much safer for the locker and get optimum street performance.. I then asked what about manufacture warranty stating that 75w-140 synthetic must be used in the rear he said they use that oil spec because of fuel efficiency/ govt regs crud..
I don't know much bout rear ends what do you guys think?? I figure Detroit/Eaton knows what is best for thier lockers, least I hope so, hehe
BEST 1/4 Times
UpRev ECU Tuning!!
Old 06-13-2006, 04:21 PM   #65 (permalink)
kartman's Avatar
Re: Tru Trac is in
I was told the same thing. In the TT manual it says to use the same gear oil you do normally. They really need to get their story consistent
I have been beating on mine hard on the street and in dirt and sand with 75-140 syn with no noise or probs yet.
Rebar Wrangler
Old 06-13-2006, 05:03 PM   #66 (permalink)
Re: Tru Trac is in
Just got my Tru Trac put in at NW differential in Kirkland WA for $370. That included the 145 weight redline oil & additive (they talked me into that set up) and the time to remove/reinstall the swaybar.
Had the motorcycle in the back, so I haven't had a chance to really drive it....but driving normally on dry pavement I couldn't tell any difference.
2005 CC LE 4X4 in Canteen
Mods - Volant CAI, Torza Premier Tonneau, PRG 2" front 1" Rear, Bilstein rear shocks
travisreed is offline   Reply With Quote
Old 06-13-2006, 05:08 PM   #67 (permalink)
O4DRUNNER's Avatar
Re: Tru Trac is in
That is whats nice in normal drive mode you do not notice anything,,,, but push it around a corner or in the wet and you will notice it,.,,,,,
O4DRUNNER is offline   Reply With Quote
Old 06-13-2006, 07:10 PM   #68 (permalink)
Re: Tru Trac is in
OK, had a chance to drive with it a bit.
The Good: Hooks up on take off. When you turn the wheels from a stop and stand on the throttle...the back end comes around nicely on dry pavement. Cool.
The Bad: Tire wear. Going around corners at normal speed, with the windows down, you can hear significantly more wear. And turning a single cookie...yikes! way more wear than I was expecting. The side edge of my otherwise new BFG A/T's lugs are thrashed.
For me, getting this done cost nearly $900, and it looks like the on going cost is going to be 30-50% additional tire expense. Totally worth it. Can't wait to get off road and throw some dirt.
Old 06-13-2006, 07:31 PM   #69 (permalink)
Re: Tru Trac is in
I just got back from testing out my trutrac also,lol
I can't even do a brake stand burnout anymore, not sure if it's due to more traction, or less hp going to both wheels vs. 1 wheel only tried 1ce will try again tommrow and use less pressure on the brake pedal.. Going around corners with the bfg kdw's it's impossible to lose traction, I went full throttle thru 3-4 turns and normally it would've set my right tire into a smoking frenzy, all it did was plant the rear end and acclerate
Very nice mod, but boy am I going to look stupid at the track if I can't even do a burnout before advancing up to the staging lights..
BEST 1/4 Times
UpRev ECU Tuning!!
Old 06-13-2006, 08:01 PM   #70 (permalink)
got_titan's Avatar
Re: Tru Trac is in
more traction=better 1/4 mile times...do you have the burout mod? any sound differences with truetrac? thanks, john
04 cc 4x4 w/big tow...........silver
volant cold air , oem sirius tuner, Zoomers exhaust, wade in channel visors, chrome tailgate piece ,05 finned diff cover,leather console lid, tailgate torsion bar,22 inch akuzu bounce, 305/45/22 nitto 420 extremes, mccullough hid's,05 active headrests , truxedo low profile,stillen front sway bar, painted lund interceptor, cr lawrence rear power slider,armada painted front spoiler, dr coilovers, t rex vertical billet grill, zoomers exhaust, prg traction bars, Stillen brake pros monster brake kit, prothane front swaybar bushings, volant vuelights(led), odyssey deep cycle battery, trutrac on order.....(INSTALLED)
STILLEN SUPERCHARGED 425rwhp 431rwtq (before headers)
Old 06-13-2006, 11:53 PM   #71 (permalink)
Hot_Titan's Avatar
Send a message via AIM to Hot_Titan
Re: Tru Trac is in
k im just joining this thread and im sure its already been mentioned a hundred times but where can i get the trutrac locker and how much should i be expecting to pay?
Hot_Titan is offline   Reply With Quote
Old 06-14-2006, 03:01 AM   #72 (permalink)
Re: Tru Trac is in
TruTrac locker for the Titan?
click that link and the info is on page 26 on who to call the quote # and all the good info..
I paid 490.00 for the TruTrac diff and another 30ish for the 4 carrier bearings.. shipping isn't included either.
BEST 1/4 Times
UpRev ECU Tuning!!
Old 06-14-2006, 07:54 AM   #73 (permalink)
FlimFlamMan's Avatar
Re: Tru Trac is in
Just got another install quote. This time its $300 - $400. A little lower than the last guy... but not much. I think the quotes are coming in high because nobody (that I'm aware of) around here has done any diff work to a Titan (except the dealers.. lol).
I also supplied them my service manual RFD and RAX sections along with the TrueTrac Manual so they could see what they were getting into.
My wishful thinking is that the one I choose to install it will end up seeing how easy it is and not charge so darn much.
2007 WRX TR (5 speed)
Stage I
The Titan will be missed....
2005 XE CC 4x2
QX56 OEM Wheels
Uprev Tuned
Old 06-14-2006, 03:53 PM   #74 (permalink)
Re: Tru Trac is in
Do like I did find someone who builds "hot rod, high performance engines" he'll be more than glad to do it, and they are probably more competent than most other shops that do just random work..
BEST 1/4 Times
UpRev ECU Tuning!!
Old 06-23-2006, 07:03 PM   #75 (permalink)
Re: Tru Trac is in
Got my new axle installed yesterday...
Survey-REAR END FAILURES ONLY
... Axle had a build date of 29 DAYS ago...so it's a newborn. Gonna break it in for a little while easy and then go to West Coast Differentials again for the TruTrac install.... pics of the really new axle/diff in the link provided.
04 CC SE 4x4
CST 7" Lift
Bilstein 12" 5150 Crossflow Reservoir shocks
Magnaflow All Stainless Cat-Back exhaust
2 Degree Timing Advance
17x9 Gear Alloy 711MB modified rims
BFG All Terrain T/A KO 315/70/17 tires
Alumistinger 10" drop Super Alloy Drop bar/Ball mount
TrueTrac LSD
DMZ tube rear bumper
PRG Traction bars
PRG UCA's
SAW Coilovers
Shadowofnight2001r is offline   Reply With Quote
Did you know this about the Utili-trac? Nascar Fan Titan General Discussion 3 05-29-2006 10:06 PM
Tru Trac Pokoki Titan Performance Modifications 5 04-11-2006 06:52 PM
Utili-trac on a XE? byrdman Titan Parts & Accessories 2 03-11-2005 08:50 AM
