That's a pretty impressive tranny you guys have. Would be nice if mine was that stout. I guess that is a good question, why does Dodge make their tranny's so crappy? If we had the same tranny gearing as you, game over.
If you had the same tranny gearing we have with your ring gear your milage will be non existant as well as top speed.
Rebar Wrangler
Hemi Man....Sorry not game over if you had the same tranny as us. Our differentials are geared around our trannies thats why we have 2.94's or 3.36's in the back....In other wordz if your dodge had a titan tranny with dodge gears you would burn a **** load of gas and would not be practical for the street you would rev to high.
But I think most Dodges come with 3.77 or 3.73's from the factory right?
2006 SE Crew Cab, Big Tow, Traction Package, SE Popular Package...mods....yup...and they seem to work well together! UpRev Osiris now installed!
RT .079
60' 1.848
1/8 8.792
MPH 77.458
1/4 13.896
MPH 95.996
Horsepower Sells Cars, Torque Wins Races!
ok looks like you know gears kart have a Q: i drive 04 crew xe w/o big tow and its a 4x2 w 38'' toyos is true track and gears some thing i need to look in to want to get back to the performance i had befor the lift and tires or do i need to just wait and hope for gears to come out i am not sure need help and were do i get a setup and how much i am lost when it comes to gears
Yeah and if we had the viper engine... lol
or better yet if we had a jet engine and no tranny.
The TruTrack does not change the actual gears. It makes the rear end a true limited slip. It will use your curent 2.96 gears....and I called Nissan....the 3.36 gears are not for sale...must buy the entire rear end. Unless you can find one wrecked....which I have seen!
RT .079
60' 1.848
1/8 8.792
MPH 77.458
1/4 13.896
MPH 95.996
thanks you just burst my bubble of hope this s**ks you know we are like the bastard son's its just getting to dam hard to find after market parts it is BS when you go in to a shop and ask for some thing for your truck and thay don't make it or are on back order for six mo.and there is a ton of GM and FORD crap all over the walls i was out in LA this weekend on the hunt for a toyo 37x13.50x18 mt that was on back order for 8MO. now no luck SH!T!!!!!!!! OUPS just venting
With them big tires the 3.36 gears would be nice. There are several members that have wrecked there Titans. You may search it out and find out where there trucks are at and ask about the rear end gears.......worth a try.
RT .079
60' 1.848
1/8 8.792
MPH 77.458
1/4 13.896
MPH 95.996
Given 2 identically designed rear ends with different gear ratios, the one with the lower gear ratio will be stronger. So in theory, the 3.92 in the Dodge should be stronger than the 3.56 in the Titan.
The same is true of transmissions. The 3.8 1st gear in the Titan should technically be stronger than the 3.0 in the Dodge. The same thing applies to all 5 gears.
Both designs accomplish the exactly the same thing, and one isn't necessarily better than the other. Nissan just decided design more strength into the transmission and less into the rear end than Dodge.
I'm fixing to swap rears out replacing my 2.94 with 3.36 and trutrac....entire rear end.
I think 04runner has a 3.36 axle minus one splined axle so you could use part of yours and his 3.36. Pm him.
Randy IRCCREW CHIEF - International Racing Club VK56
